adding light bar and lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ckeeton, Sep 14, 2010.
  1. Sep 14, 2010 at 5:52 AM
    ckeeton
    ckeeton [OP] Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    should i add them to the truck? i make several trips to the mountains and it gets tough to see sometimes esp when it snows. so wondering if its worth it to add some extra lights on the front of the truck and wondering how much extra light it brings with it.
    thanks!
  2. Sep 14, 2010 at 6:14 AM
    Joehs
    Joehs Well-Known Member
    Joey
    AL
    I'll try and get you a night picture of my light bar thus evening, it makes a very large difference if you do it right.
    I say go for it!
  3. Sep 14, 2010 at 6:19 AM
    ckeeton
    Duluth, GA
    thanks man. and you think it would go good with an avid light bar?
  4. Sep 28, 2010 at 5:28 PM
    whtever3
    whtever3 New Member
    Navarre FL
    07 PreRunner Dbl Cab Lifted
    3" Lift Rear Air Bags Mesh grill Light Bar Wheels and tires Running light mod Fog light mod
    I put a CARR light bar with summit racing lights on.
  5. Sep 28, 2010 at 5:45 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    if you're goal is to see better while it's snowing, i would use a light bar that sits lower on the vehicle (front bumper area) and use lights that have a fog light pattern. i have 4 lights on my roof, all are geared for distance rather than wide spread light, thay are fantastic most of thi time, but when it rains heavy or snows, they wash everything out and make it harder to see farther. so in those cases, the fog lights come on and the "fog pattern" lights behind my satoshi as well.
  6. Sep 28, 2010 at 6:03 PM
    ckeeton
    Duluth, GA
    yeah i was gonna put four on a light bar on the grill.
    and thanks
  7. Sep 28, 2010 at 6:27 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    check out the nfab light bars, and the procomp 130's for the lights
  8. Sep 28, 2010 at 9:54 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    With Kragen HIDs...
    One Baja trip and the Kragens (plastic housing) cracked from vibration... epic fail!
    With Hella 4000 Halogen Metal Lamps (pencil beams, 100 watt)
    Regular High Beams...
    Hella 4000 Pencil beams...
    Hella 4000s...
  9. Sep 29, 2010 at 5:20 AM
    ckeeton
    Duluth, GA
    hey thanks david K. yours really helped out alot. was looking for something along those lines to see the difference appricate it.
  10. Sep 29, 2010 at 6:10 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    You may be looking for something a little more professional than this, but being a college student with time and ingenuity over the summer I made my own. Piece of conduit from Lowes' and some thick treated board painted black with some lights that I picked up from the local parts store. Spent a total of $30 and am very pleased, lights are very bright. Just if you wanted to experiment on your own. [​IMG]
  11. Sep 29, 2010 at 9:19 AM
    ckeeton
    Duluth, GA
    Yeah I in college too and that's not a bad idea to tinker with
  12. Sep 29, 2010 at 9:39 AM
    David K
    You're welcome!
    Keep in mind some basics... HIDs are awesome use less than half the power of Halogens and will create daylight in front of your truck... 4,000ºK to 5,000ºK color range. Lower will be yellowish and higher will be blue to violet and give you LESS light!
    However, they are expensive... except for the Chinese made units Kragen and some others are selling. The problem is the ABS plastic housing can break with any long off road drives. The good ones come from companies like Hella, Baja Designs (Solotek), KC, Light Force, Vision X, etc... but will be $300-$500 each.
    The new technology is LED lighting... very small, very low power drain, very expensive... Baja Designs has some.
    Halogens have replaced sealed beams as the standard light... they give more light, are whiter and brighter than sealed beams, and the cost is reasonable. 100 to 135 watts are availabe for off road use. Prices range from $35 to $135 each. Halogens are closer to 3,000ºK on the color chart, meaning they are slightly yellowish... but whiter than sealed beams!
    BEAM PATTERNS:
    FOG: Short, and very wide... used for cornering as well as under fog.... Mount as low as possible on vehicle.
    DRIVING (EURO): Oval and about the same as your standard high beam pattern on the road. Best choice for most conditions. Mount close to headlight height on vehicle.
    PENCIL (SPOT): Long and narrow beam pattern... no wider than the road in front of you. Best for high speed driving and to see distant objects the soonest. Mount as high as possible on vehicle.
    Best set-up would be to have all three types. I have pencils because I use my stock headlights at the same time, and want distance to be increased.
    I do plan to have my light bar modified with two more tabs so I can add my (repaired) driving beam HIDs to the pair of Hella pencils.
  13. Sep 29, 2010 at 9:48 AM
    bane
    bane Active Member
    FL
    09 Tacoma DC SR5 V6 6-Speed
    6" Pro-Comp Lift, 35x12.50R18 BFG KM2's, 18x9 Pro-Comp 7036, All-Pro Front and Rear bumpers, AP Sliders, KC HID lights, Smittybilt Winch
    If you run Pro-Comp lights you can keep the cost down some. First thing you want to do is paint them though. The factory finish sucks. Fades very quickly. Other than that, the performance I've had is fine compared to the KC's.
    [​IMG][​IMG][​IMG][​IMG]
  14. Sep 29, 2010 at 9:55 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    There are several options you can go with. Mine's a smitty-built w/Hella 500s, same design as an N-fab bar.
  15. Sep 29, 2010 at 9:55 AM
    David K
    What kind of lights are the Pro Comps you have, HID, Halogen, Pencil, Driving?
  16. Sep 29, 2010 at 10:51 AM
    ckeeton
    Duluth, GA
    what i was thinking about was having 4 PIAA's 520 driving series on the grill with an avid off road light bar.
    we got a mountain house and esp at night and during the winter its rough to see the trails up to it. have you heard any about the PIAA being good quality? was looking and for four of them it'd be something like $465
    the reviews on the site looked like everyone really liked them. just wondering what you think of the set up and the lights
  17. Sep 29, 2010 at 11:03 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got the PIAAs you speak of and they're great! There's a group buy going on with them now also. I believe it's a 25% off deal and 11.99 shipping flat rate. I only went with 2 520s with the amber driving beam. So far, the quality is great and they light up everything! They have a lifetime warranty also, excluding collisions. The warranty follows the owner also, so you can take them off and put them on your next vehicle and they're still covered. Unless you're really off road, I would imagine 4 is overkill and would be expensive. They're 85 watts a piece so your electrical system is something else to keep an eye on (not sure how much other stuff you run consistantly).
  18. Sep 29, 2010 at 11:26 AM
    bane
    bane Active Member
    FL
    Currently I have 2 Pro-Comp 8" 130 watt with a combo flood/spot lens and 2 KC 6" 100 watt spots. All Halogen
  19. Sep 29, 2010 at 11:35 AM
    ckeeton
    Duluth, GA
    thanks for the input. yeah i was wondering about the electrical side of things for it haha. and the only other thing that'll be running is a police radar. but i could prolly set up the double battery thing if i do indeed decide on getting four.
  20. Sep 29, 2010 at 12:50 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    x2 minus the KCs
