Adding more choices to the mud flap no mud flap discussion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 18thstlocal, May 14, 2010.
  1. May 14, 2010 at 7:41 PM
    18thstlocal
    18thstlocal [OP] New Member
    Florida
    2010 Offroad
    I noticed there is quite a bit of talk about which is better, mud flaps or no mud flaps. But not much discussion aftermarket or modified mudflaps. This is my solution to the issue.
  2. May 14, 2010 at 7:44 PM
    glandnut
    glandnut Grease Monkey
    Florida
    09' MGM TRD DC Sport LB(gone), 16' 4Runner Trail
    secret stuff.
    Jason, guys here have been trimming the mudflaps for years. Check the Mods & Tutorials section, and you'll get gobs of other ideas for your truck.
  3. Oct 14, 2014 at 9:20 AM
    joeallen88
    joeallen88 New Member
    Utah
    2015 Tacoma TRD
    Jason, I just bought a 2015 tacoma. Where did you purchase those modified mudflaps? I want some smaller ones for sure and my truck is almost identical to yours, just black not gray.
  4. Oct 14, 2014 at 9:22 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Welcome to TW.
    Looks to me like he cut his down like most of us who offroad have done over the years.
  5. Oct 14, 2014 at 9:31 AM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    The whole idea on the huge stock mudguards, was a result of all the 1st gen & early 2nd gen 2005-2006 complaints of peppered rocker panels and bedsides. Especially in areas where chip-sealing, poor roads, and sand/ salt is used in snowy areas.
    If you are cool with having the paint at your rockers and lower bedside chewed up, cut or remove them. Off-road enthusiast probably don't care anyway, as the truck will get chewed and dinged anyway from frequent usage off highway.
    But if you like to keep your truck as nice as possible, for as long as possible, and not really into the Off-roading thing, I highly suggest leaving them on and at stock length.
    Personally I just wish there was a way to use winged nuts, for a quick removal and re-install after off-road usage. I personally am fairly OCD about my vehicles, so it' not an option to remove them. I did on my old truck, as a try-N-see after adding BFG AT's, but in one day I could hear large rocks hit the rocker on the highway, and had a few new chips and gouges, so they went back on.
  6. Oct 14, 2014 at 9:36 AM
    adamr94
    adamr94 Well-Known Member
    Adam
    Eastern NC
    06 Regular Cab 4x4
    Toyota has been doing those 4WD/4x4 mudflaps for years (80s). But the problem is, especially after 2005, the material is very thick and doesn't bend. I park somewhere that has a little bit a drop, it's not much at all... but enough to take a mudflap off
  7. Oct 14, 2014 at 9:45 AM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Two years old; no problems.
  8. Oct 14, 2014 at 9:58 AM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    They are there for good reason, like your personal mudflap. Don't mutilate them. :eek:
  9. Oct 14, 2014 at 1:48 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    I agree with DoorDing. I go through a couple sets of mudflaps every year, and the best I have found are the plasticolor's with the mountains.
  10. Oct 14, 2014 at 1:57 PM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors AVS Tail-Light Covers TRD High Performance Oil Filter TRD Oil Cap TRD High Pressure Radiator Cap AMI Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers/Badges
    I like RokBlokz rally flaps the best, i feel they offer the most protection while looking the best IMO :)
  11. Oct 14, 2014 at 3:31 PM
    wanna taco
    alan
    SF Bay Area
    My mudflap is better than yours.
  12. Oct 14, 2014 at 3:34 PM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    the stock ones on the 2015 bend just fine...
    but they rub on my 4.5bs wheels with 265/75/16
    I am going to try to trim them slightly shorter, but mostly losing some of the inboard portion as that's where mine rub, right at the mounting point
  13. Oct 14, 2014 at 3:45 PM
    DoorDing
    Bodie, CA
    yes
    Unless Toyota changed them from the design they've used for years, they'll get ripped off or shattered when driving offroad. They have some flex, but an impact from directly below will destroy them.
  14. Jan 11, 2015 at 6:57 AM
    deadbird8
    deadbird8 Well-Known Member
    Dallas, TX
    14 4x4
    Yep- tore mine off yesterday launching the duck boat (we need rain).
