Adding More Lift
Discussion in 'Suspension' started by ryank 5, Dec 10, 2011.
  1. Dec 10, 2011 at 9:26 PM
    ryank 5
    ryank 5 [OP] Well-Known Member
    Jefferson County, PA
    2006 Radiant Red Taco - Access Cab 4WD TRD
    OME Dakars, OME 884's, 5100's all around (0" setting), SPC UCA's, 17" 4-Runner Trail Edition Wheels with Dynapro's, ABS Killswitch Mod, Extang Tonneau
    If i was to have bilsteins all around with a 2" AAL and new UCA's, what all could i add to provide even more lift? Can i just buy more AAL's for the back? And what would you do with the front? Thanks!
  2. Dec 10, 2011 at 9:29 PM
    Sunner
    Sunner Well-Known Member
    How much lift do you want? And yes on Leaf pack^^^^
  3. Dec 10, 2011 at 9:30 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    New leaf pack for rear. Bilsteins set at 0" and Eibach coils in the front. Or... dom dom dom... body lift.
  4. Dec 10, 2011 at 9:32 PM
    Sunner
    :eek::eek::eek::eek::eek::eek:
  5. Dec 10, 2011 at 9:33 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    885's with the billies @ .85 , Dakars or Expedition packs in the rear
  6. Dec 10, 2011 at 9:34 PM
    ryank 5
    Enough probably to fit 33x 12.5. And can i still keep the extra AAL with the leaf pack?
  7. Dec 10, 2011 at 9:38 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I would ditch the Bilsteins and AAL. (assuming you don't actually have these yet?)
    (keep the Bilsteins if you have them and drop the OME struts and shocks)
    Then go with a full OME kit.
    Front:
    885's + 90000's
    Sway bar relocate kit
    Rear:
    Dakar spring packs
    Carrier bearing drop kit
    N182 shocks
    Get it all at ToyTec
    Edit:
    Forget 33's unless you want to lose flaps and cut plastic.
    Might have to go higher as well.
    The higher you go the more your CV's will hate you :)
  8. Dec 10, 2011 at 9:39 PM
    OZ-T
    Peter North
    British Columbia
    No
  9. Dec 10, 2011 at 10:15 PM
    ryank 5
    Jflan, you da man. 1. Would i need new UCA's with this? 2. Could i get the top plate spacer option with the 885's? 3. I cant find a carrier bearing drop kit
  10. Dec 10, 2011 at 10:16 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    to fit 33x12.5s your gonna need to cut fyi
  11. Dec 10, 2011 at 10:20 PM
    ryank 5
    Can i fit a 12.5 wide without trimming? Im not worried about height
  12. Dec 10, 2011 at 10:38 PM
    jflan
    Vancouver, WA
    1. Yes, most report caster adjustment problems at this height and an aftermarket UCA fixes this.
    Best current deal is Light Racing (SPC) from Amazon for $380 shipped.
    Toytec will price match and they carry the LR UCA.
    The LR UCA is the only adjustable aftermarket UCA.
    The next step up is the Camburg ball joint UCA. It's $375 plus Moog BJ's which are about $26 each. Wheeler's Off Road has this UCA.
    Get the BJ's locally for a better price than Wheeler's if you want to go this route.
    Above that for UCA's you get into the various Uniball offerings that start at about $630.
    2. Toytec will assemble the front struts and install a trim packer on the driver's strut spring seat.
    This special spring seat spacer compensates for the "Taco Lean" phenomenon.
    They have a 1/4" top spacer that will yield a 1/2" in actual lift. This will work with the stock length top plate bolts. If you think that you want their larger top spacer you will have to have longer studs installed at the time of strut assembly.
    Might be best to call in your order so there's no mixups.
    Don't forget to ask for your Tacoma World discount.
    You might also get free strut assembly if you're buying a complete kit.
    I would ask about it.
    Here's the page with the misc. lift parts :
    http://www.toyteclifts.com/index.ph...rt&page=shop.browse&category_id=118&Itemid=72
  13. Dec 10, 2011 at 11:04 PM
    ryank 5
  14. Dec 10, 2011 at 11:05 PM
    ryank 5
    *i dont think
  15. Dec 10, 2011 at 11:13 PM
    jflan
    Vancouver, WA
    There is indeed, I just received delivery of one.
    Go on their "kit" page and work the drop-downs.
    You just add the misc stuff that you want that doesn't appear in the drop-downs.
    You might want to call them so you can communicate exactly what you want.
    They like "phone" if you know what I mean.
    Now these "spacers" are not those nasty tall spacers that the ghetto lifts use.
    They are short and are just used for final trim adjustments after the springs break in.
    You may not need them at all.
  16. Dec 10, 2011 at 11:35 PM
    ryank 5
    I cant quite find the right kit that doesnt have extra stuff. But yeah ill probably have to give them a call. What would you say, around $1500 total?
  17. Dec 10, 2011 at 11:45 PM
    jflan
    Vancouver, WA
    No, not that much.
    I think I was under $1100.
  18. Dec 10, 2011 at 11:47 PM
    OZ-T
    Peter North
    British Columbia
    Including Daks and the LR UCA's ?
  19. Dec 10, 2011 at 11:55 PM
    07NavyTaco
    07NavyTaco Well-Known Member
    Josh
    North Chicago
    07 SR5, short bed, 4x4, bilstein 5100s
    billy 5100s @ 1.75, black grill and lower valence, tinted windows
    jflan, thanks for the info. it helps me alot too. how much total lift did you get?
  20. Dec 11, 2011 at 12:07 AM
    jflan
    Vancouver, WA
    UCA's, AAL and fully assembled struts.
    I worked the Black Friday sale.
