Adding PID To Scangauge II
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aztex, Sep 18, 2018.
  1. Sep 18, 2018 at 7:27 AM
    Aztex
    Aztex [OP] Well-Known Member
    2013 Tacoma TRD 4x4
    Hi,
    I've been reading and watching and searching but must be missing something;
    How do you add PID's for transmission temp for a 2013 Tacoma?
    I have found pages that have the codes but can find nothing about if they are there and I have to discover them or manually add them. And if adding exactly how...
    Really just want the TFT for towing a trailer......
    Thanks,
    A
  2. Sep 18, 2018 at 7:42 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Subd... I was trying to figure this out the other day and couldn't figure out how to enter them either.
  3. Sep 18, 2018 at 7:50 AM
    Muddinfun
    Muddinfun Well-Known Member
    You have to manually enter the codes for your particular vehicle. It tells how on the Scangauge website. If you can't figure it out, get a teenage kid to do it for you. They may not know which direction to turn a bolt, but they can sure wiz through techy stuff.
  4. Sep 18, 2018 at 5:11 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    What OBD2 reader and app are you using?
  5. Sep 19, 2018 at 7:18 AM
    Aztex
    2013 Tacoma TRD 4x4
    Ummmm .......Scangauge II......
    It's ok! I ask questions like this all the time instead of reading the title :D
    BlkDakDave[QUOTED] likes this.
  6. Sep 19, 2018 at 8:08 AM
    BlkDakDave
    David
    CC TX
    Yes, I saw that after I made the post. When I get back home and in front of my desktop I'll send you the PID that I used for my transmission fluid temperature.
  7. Sep 19, 2018 at 2:32 PM
    SebSA
    SebSA Active Member
    2013 DCSB 4x4 4.0 Auto
    2WD likes this.
  8. Sep 19, 2018 at 3:35 PM
    BlkDakDave
    David
    CC TX
    That's quite a gadget you have there. Once you get it placed and running post some pics have you have it setup. Here's the PID I used for my truck and it seems to be pretty accurate. Hope it works for you too.
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    TFT 1
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((E*256)+F) * (7/100) * 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    TFT 2
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((G*256)+H) * (7/100) * 400)/10)
    OBD Header to use:
    left blank
    Aztex[OP] likes this.
  9. Sep 19, 2018 at 3:53 PM
    atavuss
    atavuss Well-Known Member
    Which sensor is better to use? The pan temp or converter outlet temp? I have the trans temp showing on my scan gauge for my 09 Tacoma but I don’t remember which code I used. On mountain grades the trans temp gets up to 208 to 210 degrees just with the Tacoma.
  10. Sep 19, 2018 at 4:08 PM
    BlkDakDave
    David
    CC TX
    I have a gauge for each sensor set up on my Torque app. As I recall, the converter runs a little hotter. I haven't been really driven my truck much since last May when I drove back to Texas from AZ, which was not on IH10. So my memory is a little foggy on that. From what I understand, the coolant temp and trans fluid temp will be pretty close when the vehicle is under strain, as in driving on mountain grades.
  11. Sep 19, 2018 at 4:31 PM
    atavuss
    I have noticed my trans temp gets to around 208/210 while the engine temp will be in the mid 190’s while climbing a high elevation mountain pass with multiple grades (this would be Monitor Pass highway 89 in California).
  12. Sep 20, 2018 at 9:12 AM
    BlkDakDave
    David
    CC TX
    IMO- that's quite a difference. Do you have a trans cooler, or just relying on your radiator to cool the trans fluid? There could be several reasons why your transmisison is running 20° warmer.
  13. Sep 21, 2018 at 7:48 PM
    atavuss
    My Tacoma has the tow package so whatever trans cooler it comes with is what it has.
  14. Sep 21, 2018 at 9:57 PM
    Aztex
    2013 Tacoma TRD 4x4
    On my 2000 4R my OBD iPhone app would have similar 220° range readings.
    Remember putting in OD will drastically raise trans temp so gear selection a factor.
    I don;'t think engine and trans temps are always the same ...
    A
