Adding Power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by firefighter324, Apr 10, 2016.
  1. Apr 10, 2016 at 11:41 PM
    firefighter324
    firefighter324 [OP] New Member
    Devin
    2014 Tacoma TRD Off Road
    3" Pro comp lift, 20x12.5 Fuel Hostages wrapped in 33 Atturo M/T's
    I have a 2014 Tacoma and I'm looking to add more power, spacifically for towing, I have a new camper and it pulls it alright but it could be better. I was going to start with an intake and exhaust and later upgrading my transmission and rears. Any opinions on what's best?
  2. Apr 11, 2016 at 12:40 AM
    eon_blue
    Azusa, CA
    Supercharger is the best bang for your buck (but they are expensive $$$). Like mentioned above, headers, intakes and exhaust will do very little compared to what you'll spend. A supercharger is expensive but you will get a very, very noticeable gain in HP for the cost.
    That said, TRD no longer makes superchargers for Toyota, but I believe the company Magnunson produces them now.
  3. Apr 11, 2016 at 5:38 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Instead of spending a lot of money on mods they a second buyer may walk away from, I would sell the truck and buy something that can pull the load.
    Sugar Silva and Lester Lugnut like this.
  4. Apr 11, 2016 at 7:13 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Ouch! But sometimes the truth hurts. I have the Supercharger it does make a big difference- everything else you do will be small improvements. In contrast to my S/C Tacoma- My wifes F150 ecoboost will out pull me, has more cargo and interior room, and gets better gas mileage. My advantages, I can make u turns and park where she cant and beat that truck off the line. :) all that to say to take a step back and look at the options before proceeding- sometimes a different truck is really the best solution.
  5. Apr 11, 2016 at 7:16 AM
    Pigpen
    Dan
    Northwest Montana
    Gears. Skip the intake and exhaust. Once you regear you'll have the power you want for half the price (or less) of a supercharger.
    Edit: And gears are readily available.
    Just Dandee likes this.
  6. Apr 11, 2016 at 10:28 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
