Adding Preload to King shocks
Discussion in 'Suspension' started by Zachs_Tacomer, Jul 24, 2019.
  1. Jul 24, 2019 at 10:05 PM
    Zachs_Tacomer
    Zachs_Tacomer [OP] Well-Known Member
    Zach
    2017 TRD Off Road 4x4
    King Coils W/ adjustable reservoir, Icon UCA, Icon air bump stops, 16" Method NV, 285/75/16 Toyo AT2
    I added a lo pro bumper to my 3rd gen and I noticed my front end is lower than before. I want to turn the collar on the King’s a few times but I’m having issues.
    When I turn the collar, the tool hits the reservoir fitting before I can get to the next hole on the collar to turn it more. Do I have to remove the entire shock from the truck? Also, will it screw up the threads adding preload without compressing the spring?
  2. Jul 25, 2019 at 8:19 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    It's ideal to remove the shock to adjust preload. If you have a local shop with a good spring compressor, that will also save you a lot of time adjusting the collar. We have people come in all the time with their shocks to adjust preload.
    You also are a lot less likely to damage the shock with no weight on the spring. Those collars get chewed up all the time.
  3. Jul 25, 2019 at 8:24 AM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    It’s certainly possible to do without removing the shock. Kind of a slow process and it’s a PITA but it’s possible. I’d recommend removing them just to save the head ache.
    SR-71A, Willbeck and MattCowsmasher like this.
  4. Jul 25, 2019 at 8:33 AM
    Zachs_Tacomer
    Zach
    Seems like everything points to taking them.. what a hassle! What are the odds I get a spring compressor on the spring with them on the truck?
    Also, if I adjust the collar two turns do I need an alignment?
  5. Jul 25, 2019 at 8:37 AM
    AccuTune Offroad
    El Cajon, CA
    They are a #6-700 spring which requires a good compressor to do it right, and safely. I would highly recommend not going the cheap route with a spring compressor. Again, if you have a local shop, give them a call and see if they can do it all for you.
  6. Jul 25, 2019 at 8:39 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Do you have the meat hook looking tool sold by king?
    Willbeck likes this.
  7. Jul 25, 2019 at 8:43 AM
    Zachs_Tacomer
    Zach
    Ya you are right. I have a local off road shop I trust. I’ll have him do it for me. Thanks for the advice!
  8. Jul 25, 2019 at 8:45 AM
    Zachs_Tacomer
    Zach
    I have the tool provided by King. It’s a punch / rod looking tool. I got it to turn alittle and it was a bitch. Then I learned I can screw the threads up without compressing the shock. I’m going to take @AccuTune Offroad suggestion and bring it in!
  9. Jul 25, 2019 at 8:47 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    :thumbsup:When I had Kings I marked one of the collars doing it but was able to get the desired amount of preload. Was a pain in the butt no doubt.
  10. Jul 25, 2019 at 9:45 AM
    Zachs_Tacomer
    Zach
    You would think this should be an easy thing! Stick the tool in, turn, and be done. I’d rather do it right than screw anything up tho.
  11. Jul 25, 2019 at 9:46 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    No doubt the resi fitting is in the most inconvenient location for that.
  12. Jul 25, 2019 at 9:52 AM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I adjusted mine many times without removing them from the truck, and did not damage anything.
    May be a "duh" statement, but make sure you loosen the allen locking bolt in the spring collar.
    Spray Wd-40 or Tri-flow liberally on top of the adjusting ring and ensure it wicks down into the threads.
    With your truck on jack stands (sway bar preferably disconnected) the shocks at full droop should have only a little pre-load on the springs.
    With King's "meat hook" tool, you should be able to always access the next adjusting hole. The bend in the tip is what allows you to do this.
    Should be relatively easy to do. Given i had a first gen with no resi hose in the way, i was able to get more rotation for each turn, you should still be able to get 2-3 full rotations this way in the same amount of time it would take to remove the whole assembly. Especially if you have to take it somewhere to have the spring compressed.
    DocME likes this.
  13. Jul 25, 2019 at 9:53 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Get this: https://www.kartek.com/parts/king-s...g-shocks-516-spanner-wrench-pin-diameter.html
    I also use a straight punch to help. Don't worry about removing from the truck, unless you are super concerned with the appearance of the eyelets on the collar. Jack up truck to remove weight , loosen a couple of turns BUT DO NOT REMOVE the set screw in the collar, use king tool to add or remove the preload. Leave collar in a position where you can tighten the collar clamp bolt. Tighten everything up, set back on the ground, and jump on bumper to settle out the ride height.
    LukeCC and Willbeck like this.
  14. Jul 25, 2019 at 9:53 AM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Also, King does not recommend more than 1" of pre-load. If you need more than 1" to get the ride height you want, they say you need to increase your spring rate.
    SR-71A, LukeCC and DocME like this.
  15. Jul 25, 2019 at 9:55 AM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    This, plus the King tool is the right size and should not damage the adjusting holes. Using a straight punch that's not a perfect snug fit can oval out the holes making further adjustment more of less impossible without additional damage. Then you have to replace the spring collar and that's even more of a pain.
  16. Jul 25, 2019 at 10:02 AM
    DocME
    California
    '07 FJ Cruiser
    I used a punch with identical sizing to the king tool. I bought a kit at HF. It helps when you have the reservoir hose to contend with when the hook on the King tool isn't quite right. I've had mine for 10 years and I've made frequent adjustments. A couple of my holes look a little used, but not bad at all. Most of the damage would happen if you didn't loosen the clamping screw properly.
    Willbeck[QUOTED] likes this.
  17. Jul 25, 2019 at 10:08 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I had this issue with my radflos. I loosen the res mount where it connects to the shock and titled it up which created enough room for my to adjust it. Might be the same with kings!!!
  18. Jul 25, 2019 at 10:39 AM
    Zachs_Tacomer
    Zach
    I’m thinking that tool could be exactly what I need. I’m using the straight tool that fits in the eyelids but I can’t get to the next eyelid to turn more. Maybe that will do it
  19. Jul 25, 2019 at 10:39 AM
    Zachs_Tacomer
    Zach
    Dumb question, but loosening that fitting won’t screw anything up?
  20. Jul 25, 2019 at 10:40 AM
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    hey are you in a jeep? i saw a accutune jeep ahead of mee getting off the 405 this AM
