Adding rear speakers/ sub to access cab with utility package?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mulage, Dec 4, 2017.
  1. Dec 4, 2017 at 6:33 AM
    mulage
    mulage [OP] Well-Known Member
    Bryan
    Central, North Carolina
    2020 TRD off-road
    has anyone here added rear speakers to there 3rd gen access? i have a utility package and curious as to where i can tap into gain speaker signals for the rear and what size speaker and what grilles to use?
    also anyone added a subwoofer to a access cab w/ utility package? pics?
    mrbetelman likes this.
  2. Dec 4, 2017 at 7:50 AM
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    I have same truck ,Ben wondering about putting 6x9s in the area in front of the 2 cubbies in the floor facing forward . The rear doors mite be hard being you would see the speaker grates . Hope someone on here has done something
    tcBob likes this.
  3. Dec 4, 2017 at 7:56 AM
    mulage
    Bryan
    2020 TRD off-road
    also wondering if the sr with 4 speakers and sr5 with 6 speakers have the same radio? and what the RMS might be?
    they look the same
  4. Apr 8, 2019 at 1:50 AM
    SCRANTON12GA
    SCRANTON12GA Active Member
    Kevin
    Pittston
    2017 Tacoma SR
    235/85/16 Wild Trail CTX Wiper Switch Mod Go Rhino 3.0 Sport Bar TrailFX Bull Bar KC Apollo Lights
    Anyone ever add them ? I added the Subaru tweeters and rockford front door speakers but still miss having surround sound in my cab. Anyone have a easy fix for this?
  5. May 2, 2019 at 11:39 PM
    SCRANTON12GA
    Kevin
    Pittston
    2017 Tacoma SR
  6. Jun 23, 2021 at 10:47 AM
    bbdl47s
    bbdl47s Member
    2018 SR
    Heading to Crutchfield in a few days to see what my options are for the 2018 Access Cab/Utility Package. I need more sound!
  7. Jun 23, 2021 at 11:10 AM
    Dean62
    Dean62 Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    The access cab doors take a 6.5" speaker. MrMarv on here made the sub box I put in my access cab sport.
    I would think the radio can handle powering another set of speakers as they should be the same as the one in a double cab sr and i think they also have speakers in the rear door. you would just have to extend the wires to the rear door from the head unit. if not the best route would be to replace the headunit and then extend the wires to the rear door while adding a set of 6.5"
  8. Jun 23, 2021 at 11:21 AM
    bbdl47s
    bbdl47s Member
    2018 SR
    No speaker grilles in the Utility Package, and they are not available separately. I need to figure out if speakers/subwoofer will go in door(s), rear panel, or under seat(s). The panel (welded plastic) where the speakers would be mounted is curved, just to make things more difficult. Waiting to see what Crutchfield suggests.
  9. Jun 23, 2021 at 12:39 PM
    caribe makaira
    Caribbean, Puerto Rico
    Seems like they molded over the original then covered it. You'd be left with the 6 holes.
    P.S. the speaker are mounted on the door, not the panel.
  10. Jun 24, 2021 at 6:59 AM
    bbdl47s
    bbdl47s Member
    2018 SR
    Yep, I get where the speaker mounts. No speaker wiring with the Utility Package, either.
    Curved surface on door panel would make it difficult to use an aftermarket speaker grille.
  11. Jun 24, 2021 at 7:19 AM
    caribe makaira
    The connector for the speakers shares other circuits, it might have the wires slots to the speakers empty at the door area.
  12. Jun 24, 2021 at 7:33 AM
    bbdl47s
    bbdl47s Member
    2018 SR
    Thanks for the diagram. I'll have to check while I have the panel off.
  13. Jun 24, 2021 at 7:38 AM
    caribe makaira
    The connectors shown are not in the door, they are in cab side near the door boot.
    Greenbean likes this.
  14. Jul 14, 2023 at 12:47 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I need to bump this and ask if anyone has seen the wiring “extension” that Toyota would have used to wire the Access Cab door speakers?
    I would like a clean install if at all possible instead of cutting the open plug off and running my own wires for the speakers.
    TIA,
    GB
  15. Oct 26, 2024 at 11:56 AM
    Ascotta05
    Ascotta05 Well-Known Member
    NC
    There actually are speaker grills under the blank panel, but they have several big ugly holes in them.
  16. Oct 27, 2024 at 9:12 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I have the 4 door, and the rear speakers dont get half the volume that the front speakers do. Not worth getting rear aftermarket speakers for this reason, so what I did was run the speaker wires from the rear speakers (behind the HU), to my under seat 8" Powered Sub. It only requires a low wattage signal. Perfect!
    This helps the oem HU run full volume to the front speakers, and I can control the Sub out volume on the oem HU.
    Sounds great with the front speaker setup. Only thing I would differently, is now they came out with a 10" under seat Sub.
