Adding spacers after lift is installed?
Discussion in 'Suspension' started by bayonet6d, Feb 24, 2014.
  1. Feb 24, 2014 at 2:06 PM
    bayonet6d
    bayonet6d [OP] Member
    Clarksville, TN
    '12 MGM TRD Offroad DCSB
    I'm going to install my 3" OME lift as soon as the weather cooperates. I had the struts pre-assembled with the 886 springs since I have a double cab and plate bumper with a winch to follow shortly. I ordered the small spacers as a precaution in case i drop below 3" when the winch is installed. My question is, if i install the struts without the spacers initially, Do I have to completely remove the struts if I end up wanting to put the spacers in later, or can i just unolt the top and drop em down far enough to slide the spacers in? I'm trying to figure out which way to go on the initial install to avoid too much work in the future. So, Install with the spacers now or without?
  2. Feb 24, 2014 at 5:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Why fuck up a good lift with ANY kind of spacers ? & why do the work twice ?? If you already know your getting a plate bumper w/winch why not just get the upgraded /heavier spring or the right coilover (if money allows) from the start ?....:notsure:
  3. Feb 25, 2014 at 5:50 AM
    bayonet6d
    Clarksville, TN
    I already have the 886 OME springs to compensate for the increased weight. I already have the bumper installed and the winch should go within 6 months. I know it isn't a science, i'm just trying to see from anyone who has experience with this combination or one similar. Will the 886 springs without the 1/4" spacers still give me 3" of lift given the amount of weight on the front end?
  4. Feb 25, 2014 at 6:07 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    First off is your preassembled setup already has the longer studs already installed? If not then you might have to remove the whole setup and if did you should be able to unbolt the top 3 nuts and drop it down and slip the spacer in.
  5. Feb 25, 2014 at 2:21 PM
    bayonet6d
    Clarksville, TN
    Yes, the longer studs were installed already. That's what I was looking for, i was hoping, if it comes down to it, i can just unbolt and slide down far enough to slide the 1/4" spacer and bolt back up, without removing the whole thing.
  6. Feb 25, 2014 at 2:30 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Yea you should be able to just pop them right on top of the shock assembly
  7. Feb 26, 2014 at 4:10 AM
    bayonet6d
    Clarksville, TN
    Thanks everybody. I think i've got it all straight now.
