Adding Supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by Anthony250, Aug 19, 2017.
  1. Aug 19, 2017 at 3:04 PM
    Anthony250
    Anthony250 [OP] Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Curious has anybody added a supercharger on a high milage 3.4?
    My 99 3.4 Auto has 249 K original miles. Runs flawlessly , but with all the additions I need more power. Worried that some have mentioned adding a SC on high miles motor is risky.
  2. Aug 20, 2017 at 9:20 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    May be risky but I know others have thrown on a SC with 200k+ miles on the 3.4. If you're worried I would do a compression check to see where you're at prior to pulling the trigger.
  3. Aug 20, 2017 at 9:26 AM
    Anthony250
    Anthony
    Rialto CA
    Hmm Hopefully they can share some insight, what Psi numbers should I be looking for?
  4. Aug 21, 2017 at 6:10 PM
    Rockey
    Rockey Well-Known Member
    Hawaii
    04 Manual TRD V6 S/C 4x4
    i got 235k threw a 2nd gen on with nothing else, runs fine just the obvious lean outs, probably depends on your motor and how well you take care, charger does get really hot at times though,
    to add on, im doing 6 pounds, 3.4 manual
  5. Aug 21, 2017 at 6:12 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  6. Aug 21, 2017 at 6:16 PM
    1997tacomav6
    Denver
    As long as you do a leak down test and compression test and your numbers are good, you should be ok.
    Dalandser likes this.
  7. Aug 21, 2017 at 6:46 PM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    Came here to say this. Considering the age of your engine I would strongly recommend fuel mods as well. If you don't want to put the money into the 7th Injector kit, at least add larger fuel injectors and the cooler spark plugs. Even low boost figures put added stress on the motor and you'll want to compensate for that wherever you can.
  8. Sep 4, 2017 at 10:32 AM
    Anthony250
    Anthony
    Rialto CA
    Gotcha gonna do the comp test soon. Do I also have to remove the efi fuse?
    And yes I am doing research on fuel mods as installing it alone will be dangerous. Considering 7th kit but not sure if I have egr and its costly. I have heard I can run larger fuel injectors , such as ones off a certain lexus model car, and 2 step colder plugs, and cooler thermostat/.
  9. Sep 4, 2017 at 10:33 AM
    Anthony250
    Anthony
    Rialto CA
    But still not sure if doing more fuel injectors is enough compared to the 7th kit?
  10. Sep 4, 2017 at 10:45 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    run stock pully and meth injection.
  11. Sep 4, 2017 at 10:46 AM
    Anthony250
    Anthony
    Rialto CA
    Its an option but not sure on getting that smog CA legal,, I mean harder to conceal vs other options.
  12. Sep 4, 2017 at 10:53 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I would have no issues throwing it on. Hell i was going to put mine on my 300k motor. But road salt ate away the lug for mounting the superchargers tensioner.. Pulled the engine apart and it still looked like it could take all you could throw at it with the supercharger.
  13. Sep 4, 2017 at 10:57 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I think the best way to avoid issues with CA smog would be to run larger injectors, next would be to run the 7th injector kit. But it's got a shiny metal braided fuel line that stands out like a sore thumb so it depends on the smog tech I guess. Also make sure that whoever you're getting the supercharger from is throwing in the CARB certification sticker for under the hood or else that could cause issues with smogging it as well.
  14. Sep 4, 2017 at 11:34 AM
    devinzz1
    devin
    2023 aclb trd or mt
    would you not need a fuel control and tuning to run larger injectors? or is there actually a bigger drop in injector available
  15. Sep 4, 2017 at 2:16 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    People use the Supra injectors.
  16. Sep 4, 2017 at 2:17 PM
    Anthony250
    Anthony
    Rialto CA
    With the injectors itself? no computer accessories? I know sparkplugs would be needed and a bigger faster fuel pump
  17. Sep 4, 2017 at 2:20 PM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Urd produced a kit with 6 larger injectors before the 7th kit became available. @Blackdawg has info in his thread if I remember correctly.
  18. Sep 4, 2017 at 2:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Don't be worried for a second. Long as the motor is in good shape. the miles won't matter.
    If you are going to run 6 larger injectors, gor for the AEM FIC6 controller.
    The 7th kit is not bad though and you shouldn't have issues with your year of truck. Shouldn't affect Smog. There are plenty in cali running that kit i think. Its also easy to hide. The injector is on the back of the blower.
  19. Sep 4, 2017 at 2:29 PM
    Anthony250
    Anthony
    Rialto CA
    Hmm haven't heard of that one. That urd 6 injector kit is more expensive than the 7th kit. I'm not worried about my motor too much its running flawlessly and has good power but I added lots of weight.
  20. Sep 4, 2017 at 2:39 PM
    devinzz1
    devin
    2023 aclb trd or mt
    320cc?
