Adding Taco tune's Recurve to factory head unit.
Discussion in 'Audio & Video' started by Rus TRD, Feb 6, 2016.
  1. Feb 6, 2016 at 5:24 AM
    Rus TRD
    Rus TRD [OP] Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    Hi, Does anyone have any feedback on the recurve with there head unit. I'm emailed Josh and he responded he could ship one out write away. Just trying to decide which way to go for my new system. I would like to stay with the factory head unit.
  2. Feb 6, 2016 at 5:37 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    What is recurve you speak of? Model years?
  3. Feb 6, 2016 at 5:39 AM
    Rus TRD
    Don
    Pa.
    2015 DC TRD Sport
    The recurve is a tuner to make your factory head unit to sound better if you are up grading your speakers and putting subs and a amp. Because there is not much adjustments on your factory unit. Check there website for the model years. Taco tunes.com
  4. Feb 6, 2016 at 5:40 AM
    ThomasMore66
    I'd like to retain the stock head unit too.
  5. Feb 6, 2016 at 5:45 AM
    Rus TRD
    Don
    Pa.
    2015 DC TRD Sport
    The nice thing you do not have to splice your factory wires. It's all plug and play. Before I would purchase one I'm trying to get some info on anyone with this in there truck.
  6. Feb 6, 2016 at 2:24 PM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    i have found it's not really necessary. nice for features and plug-n-play but not needed for flat output.
  7. Feb 6, 2016 at 2:32 PM
    Rus TRD
    Don
    Pa.
    2015 DC TRD Sport
    Do you have your system up graded?
  8. Feb 6, 2016 at 6:24 PM
    SlowComa666
    San Antonio TX
  9. Feb 21, 2016 at 6:28 AM
    Rus TRD
    Don
    Pa.
    2015 DC TRD Sport
    I thought I would do a bump up. Not too many responses on this recurve. Most guys must be going with aftermarket headunit.
  10. Feb 21, 2016 at 7:28 AM
    ThomasMore66
    How's it sound?
