adding TRAC to 06 TRD offroad?
Discussion in 'Technical Chat' started by mtnTACO2b, Jan 14, 2012.
  1. Jan 14, 2012 at 11:37 AM
    mtnTACO2b
    mtnTACO2b [OP] Member
    Dean
    Colorado
    06 TRD Offroad
    Does anyone know if the TRAC system can be added to a 2006 TRD offroad that didn't have this option from the factory?
  2. Jan 14, 2012 at 7:58 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Because it involves electronics, the computer, spin sensors, the VSC system... I am going to say you need to wait to you get a 2009+ Tacoma (and get the 4WD Off Road because that is what has a hydraulic brake booster to enhance the built in TRAC and create A-TRAC).
    In the meantime, try clicking the emergency brake lever a couple notches to fake it.
  3. Jan 15, 2012 at 1:06 PM
    mtnTACO2b
    Dean
    Colorado
    06 TRD Offroad
    I would love to have a 2009+ Tacoma, but that isn't in my budget right now. As GP3 says in this thread
    2005-2008 4X4 TRD Off Roads - VSC/TRAC/HAC/DAC/ALSD explained
    http://www.tacomaworld.com/forum/te...ff-roads-vsc-trac-hac-dac-alsd-explained.html
    2005-2006 4X4 Off Road trucks have an optional package that equips the truck with VSC/TRAC/DAC/HAC. This system includes the infamous Hydraulic Brake Booster that 2009+ 4X4 TRD Off Road trucks have.
    So if that was an option from the factory, couldn't it be added to a truck that didn't have that option? I know, it might be so expensive that it wouldn't make sense, but it seems like a lot of the systems needed are already in place - ABS, etc. What if I found a wrecked 2006 TRD Offroad that had the VSC/TRAC/DAC/HAC system, pulled it out, and installed it in my truck?
  4. Jan 15, 2012 at 1:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It is cheaper and more effective to put an ARB air locker in the front, but this is only needed if you are a serious offroader.
    I'd spend the money on armor and a winch.
  5. Jan 16, 2012 at 9:34 AM
    David K
    A factory technician is the one to give the best answer... However, as mentioned above, if you want traction... the a REAR LOCKER is the best addition. My 2001 and 2005 Tacomas were Off Road 4x4s, and the rear locker will take you everywhere you should ever wish to go. If it is on highway stability (VSC system), then that is another matter.
  6. Jan 16, 2012 at 9:47 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    his profile said he has a TRD OR so I assumed he already had a rear locker.
    I agree, the front locker probably isn't necessary though unless you're really hardcore.
  7. Jan 17, 2012 at 7:37 AM
    mtnTACO2b
    Dean
    Colorado
    06 TRD Offroad
    Steve O is right - I have a TRD offroad, so it already has the rear locker. I talked to the service department at my local toyota dealer. The service writer thought all TRD-OR's had it - which was my mistake when I bought the truck. He talked to his shop foreman, who said they basically couldn't help me with adding VSC. I'm thinking it would still be technically possible, but stupidly expensive.
    I'm planning to set this truck up as an overland expedition vehicle, so I need good offroad capability. I'm not going to be doing radical wheeling, so not sure that the front locker is necessary, although it would be nice to have. I'm thinking the money would be better spent on armor and a winch.
  8. Jan 17, 2012 at 7:51 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    A lot of people on Tacoma World didn't/don't even know that TRAC/VSC/HAC/DAC/ALSD was available for 06-08 trucks.
    When equipped with the optional TRAC package, 06-08 trucks have the hydraulic brake booster, associated wheel sensors, and have TRAC in 4low. Stock, without modification.
    That's why I created the thread you referenced earlier:
  9. Jan 17, 2012 at 8:45 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    based on your discription of the type of wheeling that you intend to do you would be better of having a high clearance front bumper that will fit a winch just as you said, that should be sufficient enough..although having a front locker is about one of the better mods i have done to my own taco it's not necessary unless you get into the more extreme terrain.
  10. Jan 17, 2012 at 9:32 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    First. Its all parts so its possible to install just not practical.
    Second you goign to be regearing anyway so you may as well add extra for a front locker.
    Third. People add armor because they can not get up things so they need to bash their way through. I take 4wd with F/R lockers over armored truck anyday.
    I would get front locker and good winch first.
  11. Jan 18, 2012 at 7:18 AM
    mtnTACO2b
    Dean
    Colorado
    06 TRD Offroad
    I don't follow - why will I need to regear?
  12. Jan 19, 2012 at 9:40 AM
    TheDan
    TheDan Well-Known Member
    Dan
    Bridgeport, California
    07 Double Cab Short Bed TRD OR
    Billet Grill, Borla Cat-back exhaust, Fog Light Anytime, '09 LED Taillights, ARE CX Cap, 4300K Mini D2s Projectors, LED interior and reverse lights
    I think this would be an interesting thing to do if parts can be acquired from junkyards or wrecked trucks for cheap. I have no idea where to even start, though.
  13. Jan 19, 2012 at 10:23 AM
    GP3
    California
    4X4 TRD Off Road
    Hydraulic Brake Booster Pump and associated Solenoid Valves
    4 Wheel speed sensors
    Motor Relay
    Solenoid Relay
    Master Cylinder Pressure Sensor
    Master Cylinder Skid Control ECU
    Steering Angle Sensor
    Yaw Rate and Deceleration Sensor
    Skid Control Buzzer
    Have fun!
  14. Jan 25, 2012 at 10:29 AM
    mtnTACO2b
    Dean
    Colorado
    06 TRD Offroad
    How much of that is already in place on a 2006 TRD-OR with ABS?
  15. Jan 25, 2012 at 10:37 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    They have TRAC in 4 low? You sure it isn't 4H? The 09+ only have TRAC in 4H unless we do the yellow wire mod to get it in 4L.
  16. Jan 25, 2012 at 10:38 AM
    MonkeyProof
    SoCal- SGV
    X2..
    Plus the actual traction advantages is a night and day difference..
  17. Jan 25, 2012 at 10:39 AM
    GP3
    California
    4X4 TRD Off Road
    Positive. 2005-2008 (when equipped with the TRAC/VSC package) have (A)TRAC in 4high and 4low. Stock/unmodified. Read the thread I linked.
    You are right though: 09+ SR5/Sports only have TRAC in 4H unless you do the yellow wire mod. Even then, TRAC doesn't really compare to a 2005-2012 with the hydraulic brake booster as it seems to be much more aggressive.
  18. Jan 25, 2012 at 10:40 AM
    GP3
    California
    4X4 TRD Off Road
    This^
  19. Jan 26, 2012 at 7:44 AM
    mtnTACO2b
    Dean
    Colorado
    06 TRD Offroad
    Hey - I'm just trying to learn about my truck. I thought this forum was a place to go for information. What's the problem with that?
  20. Jan 26, 2012 at 8:05 AM
    TheDan
    Dan
    I was thinking TRAC might be nice to have when turning as opposed to making tight turns with both diffs locked. I don't have money for this right now, but it may be a fun project to later. Nothing is stopping me from adding a front locker too someday.
