adding weight to you truck for winter traction & how much
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1YOTA6, Nov 21, 2016.
  1. Nov 24, 2016 at 9:31 AM
    #41
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Snow tires.
    Plain Jane Taco likes this.
  2. Nov 24, 2016 at 10:25 AM
    #42
    Lthompson
    Lthompson Well-Known Member
    I use to add some cut up utility poles to the back of my 2 wheel drive swb chevy. Probably close to 400 lbs.. Worked wonders... Pretty much never had any issues
  3. Nov 24, 2016 at 12:04 PM
    #43
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    We've got some yankee trees in my area that shed their leaves in winter. I figure I have 2 pounds in my bed. Traction is spot on.
  4. Nov 24, 2016 at 9:52 PM
    #44
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    I put sand in 3 5-gallon buckets with lids and fasten them to my cargo bar over the axle with ratchet straps. If I need the sand, it's easy to get to, doesn't get soaked with water, and are easy to move around. I also keep a 2-gallon bucket with lid in the back with a set of chains, rubber band tighteners, flashlight, kneeling pad, and gloves in case I need them.
  5. Nov 24, 2016 at 10:08 PM
    #45
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Lot of over thinking here, I've managed with 5-lug 2wd in WI, IA and CO for close to 30 years without issue and put 4 70lb bags of sand long way against the front of the bed and get where I need to go. No projectile hazard, lot of imagined horrors.
    If you have 4wd just use it when you need it, weight will only help your traction, which WTF did you get 4x4 for?
  6. Nov 24, 2016 at 10:14 PM
    #46
    idahbro
    idahbro Well-Known Member
    TRD OR AC
    Leer XL Cap, Thule Rack, Weathertech Mats, Sleeping Deck/Bed Storage, Pop and Lock Tailgate Lock
    shell, studs, 4wd, chains. Hey winter, come at me bro.
    truchador and Pigpen like this.
  7. Nov 24, 2016 at 10:16 PM
    #47
    Pigpen
    Dan
    Northwest Montana
    Someone who gets it ^
    truchador and idahbro[QUOTED] like this.
  8. Nov 24, 2016 at 10:27 PM
    #48
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I drive on roads that are thick ice sheets for 6 months of the year. My tools, chains and tonneau probably add up to 100lbs. I just stay in 4hi most of the time, drive slower, maneuver gently and start stopping early.
  9. Nov 25, 2016 at 1:18 AM
    #49
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    extra weight is great for startoff traction but... it also makes you slide further if you actually lose control of the beast...
  10. Nov 25, 2016 at 3:14 AM
    #50
    Fastbilly5
    Fastbilly5 Well-Known Member
    I have bought the small bags of playground sand from Home Depot before to use as bed weight. Cheap and easy, plus potential traction additive on ice as needed.
  11. Nov 26, 2016 at 9:59 PM
    #51
    Thighmaster
    Thighmaster Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    5 x 60lb. bags of sand over the rear axle, wrapped in a tarp and fastened down. Huge improvement in snow traction. We have just had our first round of snow and ice, and the weight is helping mightily until I put the Blizzaks on next week. Then it's really got the grip for winter (living at 9,000' in Colorado with 3 miles of 10% grade just before home)! I can get by without weight in the back most of the time, but it's so much better with it. With my set-up it's easy to remove the sand bags if I need the whole bed for hay or firewood. Last year I was caught off guard one morning when we had a 16-20" dump of really wet snow. I was stuck on the road with my Blizzaks. Two neighbors (approx. 300 lbs. together) jumped in the back over the rear axle and I became quickly unstuck. So...
    MadRiverTaco likes this.
  12. Dec 5, 2016 at 4:53 AM
    #52
    Drif10
    Drif10 Active Member
    Moscow, ON
    '12 DCLB TRD
    My old Ram was bad in the snow. Like two inches and I was flipping to 4wd if I wanted to get out of costco bad. I used the large flat 18" patio stones I had spare in the yard. Laid nice and flat, bolted in a bar to keep them tight and in place. Night and day with that truck.
    I like the suggestion of the horse stall mats, if I think it's needed I'll do that. Have a tonneau, but I carry bikes so that gets removed when needed. The mats will work well with both, I think. Thanks for the tip!
    Just bought a 12 DCLB TRD, pick it up this wednesday. Had a couple runners that never needed weight, guess I'll find out if my new-to-me truck does. :D
  13. Dec 5, 2016 at 5:14 AM
    #53
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    michelindefenderltxmsftmfw
  14. Dec 5, 2016 at 7:21 AM
    #54
    jet123
    jet123 Well-Known Member
    Ft Collins
    2013 DCLB
    :thumbsup: Low tech, no building of anything, can't rip / spill, takes up little room (assuming you have nothing already in the way) and I have thrown them down to get some traction before.
