additional lift with UCA's
Discussion in '1st Gen. Tacomas (1995-2004)' started by sgeezy, Apr 19, 2011.
  1. Apr 19, 2011 at 9:49 PM
    sgeezy
    sgeezy [OP] Active Member
    Shelton
    PB ARK
    SCRATCH n SNIFF
    2.5" rough country lift, Billy 5100's up front, 31X10.50x15 BFG KM2 tires, 15x7 Black Crager 397 series soft 8 wheels. One 15" kicker L7 Subwoofer in ProBox. 2000 watt volfenhag amp. K&N Cold air intake. And 266K miles
    Will adding aftermarket UCA's allow for additional lift? Can't seem to come across anything. anywhere. Maybe that's a sign? lol
  2. Apr 19, 2011 at 9:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Apr 19, 2011 at 10:25 PM
    DevL
    DevL Well-Known Member
    They allow additional wheel travel, not lift. Lift is governed by CV angle.
  4. Apr 20, 2011 at 6:27 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    x2
  5. Apr 20, 2011 at 4:22 PM
    sgeezy
    Shelton
    PB ARK
    SCRATCH n SNIFF
    say i get longer cv's, would i be able to put a taller spacer in the mix? Or would that put the LCA's at too steep an angle?
  6. Apr 20, 2011 at 4:23 PM
    sgeezy
    Shelton
    PB ARK
    SCRATCH n SNIFF
    longer cv's and the UCA's*
  7. Apr 20, 2011 at 4:23 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
  8. Apr 20, 2011 at 6:02 PM
    DevL
    I dont know since "longer" CVs dont exist. If you meant CVs capapble of more angle, you'd be able to squeeze perhaps a half inch and the cost of hundreds more and more frequent replacement of those high angle CVs which are going to be ultra expensive. If you want more than 2.5-3" the answer is a drop bracket lift for a 4x4 or spindles for a 4x2.
  9. Apr 25, 2011 at 5:41 PM
    sgeezy
    Shelton
    PB ARK
    SCRATCH n SNIFF
    gotcha, could i not do spindles on a 4x4? (btw my truck is a 96 4x4 3.4L) i've been looking at the drop down brackets but my only problem is finding one thats compatible with manual locking hubs. And fabtechs is just so dang expensive.
  10. Apr 25, 2011 at 5:50 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Spindles are also quite expensive as well and none that I know of will work with 4x4
  11. Apr 25, 2011 at 6:06 PM
    DevL
    Spindles relocate the wheel and hub lower. You still need a drive shaft to turn them... so your CV angle stays the same in a 4x4... so it does not work. It works for 4x2 because they have no drive shaft angle to worry about. If you did it with a 4x4 youd have zero down travel left in the CV and as soon as the suspension drooped (if it could even fit in the first place without the front drive shaft hitting the lower control arm) you would blow up your CVs.
    Yes, drop bracket lifts are expensive. If you want more than 2.5" a drop bracket is really your only choice other than an ultra expensive long travel set up. You can ask all the questions you want but that answer will not change. IFS lifts on 4x4s are governed by CV angle up front.
  12. Apr 25, 2011 at 6:09 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
  13. Apr 25, 2011 at 6:21 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    FTW. Was going to post that.
    Drop bracket lifts = no good. Just for mall crawlers. Plus SAS wouldn't be too much more than one probably, after it's all said and done.
  14. Apr 25, 2011 at 7:59 PM
    malander
    max
    01 limited trd 4x4
    Im sure it would be and it probably wouldn't be used to it's full potential anyway
  15. Apr 25, 2011 at 9:11 PM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    Are new uca's needed for a 3" coilover, are they still vary strong?
  16. Apr 26, 2011 at 9:37 AM
    DevL
    You need it for propper alignment and handling. If you don't care about poor alignment specs and handling shitty you can do without. So IMO yes it is needed at 2.5" or more.
  17. Apr 26, 2011 at 11:41 AM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    2inch suspension and 2 inch body is just right
  18. Apr 26, 2011 at 11:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Body lifts of any kind are bad. Your increasing the leverage in which the weight of the body can have over the frame contact point/mounting point. Many folks have had the body to cab point break, and the spacers pop into the cab.
  19. Apr 26, 2011 at 10:15 PM
    Littlebro 5
    Tyler
    Wilsonville or
    Yeah I hate body lifts they look bad too.
  20. Apr 27, 2011 at 9:16 AM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    :eek: nvm mind then i dont think ill be getting one anymore
    what about a one inch body lift ??i want that extra inch for the 33s ill be putting on my truck soon
