Additional Maintenance During Frame Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Guaco the Taco, Apr 27, 2021.
  1. Apr 27, 2021 at 6:14 PM
    Guaco the Taco
    Guaco the Taco [OP] Member
    2010 TRD Offroad, Standard
    3' Bilstein Lift/Level.
    Hi Everyone,
    This is my first tacoma and I could use some help. Long story short I recently purchased the vehicle and got lucky in the fact that I am getting the frame replaced due to the recall. I have two main questions.
    Truck's specs:
    2010 Tacoma Access Cab TRD Offroad.
    144k miles
    6-Speed Manual.
    4.0 V6
    3' Bilstein lift and level.
    Current issues besides the frame.
    1. Makes a screeching sound when in gear and taking off. I am thinking it is the friction plate as the clutch is pretty much toast and needs replacement. It also could be an issue in the driveline as well which I know there was also a recall for.
    2. Slow leak on right bank cam cover.
    3. Brakes need to be done badly.
    1. What is included in the frame replacement along with the frame itself such as upper control arms, motor mounts, etc.
    2. What additional maintenance should be done during the replacement. I figured the motor driveline and everything has to come out so it would make it less expensive as I do not want to pay for labor twice. I am thinking this could be things such as the water pump, timing chain etc.
    What common problems that you have had to address that I should absolutely tackle now.
  2. Apr 27, 2021 at 6:24 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Screech probably clutch/throwout bearing, take off screech could be a u joint, be cautious sometimes they freeze and have no play but are still junk. Slow leak is timing cover, motor will be coming out and placed on a tire on the floor, so if you want any components replaced on the motor now is the time. Timing cover with motor out will save you lots of money, with that said mines never dripped and only been damp for the last 85k miles. brakes ez pz, make sure they check for frozen calipers, inner pistons like to seize. If you search there is a thread that states all parts COVERED by the frame recall. Do not let your dealer fuck you over and make you pay for them, read carefully. Waterpump wouldnt be a bad idea at 144k miles, timing chain could be done while they reseal the timing cover if you choose to do so. This is usually the time to do the rack/lines, basically ANYTHING thats hidden and looks like a bitch to do.
  3. Apr 27, 2021 at 11:44 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Look at the attached for parts with frame replacement
  4. Apr 28, 2021 at 9:52 AM
    Guaco the Taco
    THIS is exactly what I have been looking for thank you so much! This will help ensure that all the work is completed and they do not charge for included parts.
    MurderedTacoV2 likes this.
