additional off road lighting cheap
Discussion in 'Lighting' started by grubburg, Oct 6, 2018.
  1. Oct 6, 2018 at 11:55 AM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I was looking at a top light bar, but didnt want to deal with wind noise, theft, or that look.
    I then looked at a grill light bar, but it either blocked your license plate or required expensive brackets and stuff.
    Now I'm wondering if I can just get rid of my fog lamps (never use them) and put some lights down there without changing the face of my vehicle or becoming a wiring genius. how much light power for the money can I get? Anyone got a recommendation. Is it comparable to a light bar?
  2. Oct 6, 2018 at 11:59 AM
    ruffridha9
    ruffridha9 Well-Known Member
    West Coast
    2012 Tacoma base
    stock ish
    I have Cali raised amber pods for fogs and while I can’t say they are comparable to a light bar,
    They definitely help.
    I have a 20” behind the grill so I use them to complement one another.
  3. Oct 6, 2018 at 12:03 PM
    grubburg
    2019 TRD OR MT
    Yeah I want to avoid the light bar behind the grill. I do t want to buy a bar, new grill and brackets ($500).
  4. Oct 6, 2018 at 12:04 PM
    grubburg
    2019 TRD OR MT
    I'm looking for something 100% off road only, i.e. no concern of blinding people.
  5. Oct 6, 2018 at 12:11 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    @tetten
    Aren’t you the guy with the low down on inexpensive off brand lighting?
  6. Oct 6, 2018 at 12:21 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    What year is your truck?
    Honestly you could probably but up to 55watt led pods in place of your fog lights and not change wiring (splice into oem wires or buy adapters from Cali Raised for $10) of you have a 2005+ truck. The harder part would be how to mount them, as the only bolt in bracket options are $100+.
    But if you can fab some metal brackets to bolt in place of oem fog lights and hold the new led pods, great.
    Honestly a grill led bar might be cheapest. my 2nd gen has a peice of flat steel bar across the core support behind the grill (like $5 lowes) a 30" Amazon bar ($50?) and a grillcraft mesh grill ($50 amazon).
    With the right light bar and position, you could probably have it shine through the lower portion of any of the 2005-2015 trucks.
    Or most 2016+ third gens have open enough grills for light to pass through.
    If you have a 1st gen, 2004 or earlier, youd probably have to get an aftermarket mesh grill insert.
  7. Oct 6, 2018 at 4:14 PM
    grubburg
    2019 TRD OR MT
  8. Oct 6, 2018 at 4:20 PM
    grubburg
    2019 TRD OR MT
    What "bolt in bracket options" you recommend?
  9. Oct 6, 2018 at 4:21 PM
    grubburg
    2019 TRD OR MT
    Anything less than $300 works
  10. Oct 6, 2018 at 4:22 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    For my money the Hella 500 lights are high quality and not expensive. They aren't trendy LED or light bars, though. I currently have a set of IPF 968, which are similar to the 500FF I think, and find the pattern useful. The middle is slightly more focused than high beams with a little spread pattern are the edges.
  11. Oct 6, 2018 at 4:25 PM
    Sterling_vH111
    Sterling
    socal
    CaliRaisedLed likes this.
  12. Oct 6, 2018 at 4:27 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    BTW, someone did a monster test of lights that fit in the stock location. Not sure if that was a 2nd or 3rd gen truck. Mostly the various designs weren't very well focused as fog lights as I recall. But since you're after something longer range that might be OK. Although that location is really not going to be very good for a driving pattern, so I wouldn't bother personally.
  13. Oct 6, 2018 at 4:29 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Nope, all my junk is the pricey "is this crap even worth it for how much I use it" brands
    T4RFTMFW[QUOTED] likes this.
  14. Oct 6, 2018 at 4:33 PM
    T4RFTMFW
    Dang. There’s a guy who has an avatar where his truck is pointed at a gravel mound and it’s nuts. Like see him from space nuts.
    All his stuff is off brand.
    tetten likes this.
  15. Oct 6, 2018 at 4:33 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Check out Baja designs squadron sports, or pros with "wide cornering" pattern. they are awesome lights.
  16. Oct 6, 2018 at 4:42 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
  17. Oct 6, 2018 at 4:54 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I’m considering the KC G4 LED. About the brightest DOT plug and play LED fogs for the Tacoma.
    Taylor@KC HiLiTES likes this.
  18. Oct 8, 2018 at 8:44 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    We'd love to set you up with Baja Designs Fog Lights for your Tacoma!
    These are designed to replace the factory fog lights with our Squadron Series LED Auxiliary Lights. With the Squadron Sport you can expect at least 3-4x the usable light over OEM. Unfortunately these aren't quite in your budget - with our forum discount the pricing is a little over $300.
    Starting at $364.95 ($328.46 - coupon code: BDForums)
    https://www.bajadesigns.com/Products/Toyota-Tacoma-12-15-Lighting-Kits.asp
    Please let us know if you have any questions
    Baja Designs
    www.bajadesigns.com
  19. Oct 8, 2018 at 9:27 AM
    grubburg
    2019 TRD OR MT
  20. Oct 10, 2018 at 2:22 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I had four Hella 500FF on my 2005;
    They were great and affordable, I watched here on tw and got a N-Fab light bar mount for them..
    I was happy until I got a set of Squadron Sports and they blew the 4 55w lamps away output wise.
    Now I have Squadron Sports and Pros on Fog and Ditch spots;
    If you are looking for cheap it's going to be a LED lightbar, if you want lights that outlast the truck go with BajaDesigns..
    grubburg[OP] likes this.
