additional shocks for extra weight
Discussion in 'New Members' started by Mtn Buckster, May 29, 2011.
  1. May 29, 2011 at 7:39 PM
    Mtn Buckster
    Mtn Buckster [OP] New Member
    Socal mountains
    2001 Tacoma and a 1978 SR5
    Looking for additional or replacement shocks from stock ones to carry extra weight and not affect driving performance.
  2. May 29, 2011 at 7:40 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    bilstein 5100s would be good with a higher rate spring like eibachs
  3. May 29, 2011 at 7:41 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Shocks do not increase payload capacity. All they do is dampen the rebound of the springs.
  4. May 30, 2011 at 4:54 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    This. You need better springs. But at the same time-That will only help you carry the rated weight more comfortably. If you need to carry more weight than the truck is rated for-You need a bigger truck.
    Cargo capacity is based on a lot of things-Not just the suspension.
  5. May 30, 2011 at 11:21 PM
    Mtn Buckster
    Socal mountains
    Thank you for all your help and support. You probably can see...I'm just a dumb old mountain man. My problem is when I load up like about 12 - 20 cement blocks, the back sags down. I wonder if I am doing any damage to truck by doing this. Thanks again!
  6. May 31, 2011 at 12:06 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    last week i loaded 1/2 pallet of blocks in my truck (30 blocks) and i was way down low. I wouldnt do that again but every once in a while its ok. I do have the dakkar leaf packs. if your stock i imagine you might blow your seals on your shocks and then maybe your leafs might need to replaced.
