Addressing some common misnomers of the P0420 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caligula, Oct 20, 2015.
  1. Jan 29, 2022 at 1:21 PM
    #41
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Just had this light pop on… yay :goingcrazy:
  2. Jan 29, 2022 at 2:04 PM
    #42
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    I have had this P0420 code for awhile. I have a 2005 regular cab 2.7 4cylinder 4wd tacoma. It came on three weeks after I had my spark plugs changed with NGK iridiums. Truck still ran ok for about six months but eventually developed a misfire/loss of power type feeling. Took it to shop mechanic pulled plugs and they were shot with roughly 18000 miles. Now mechanic says I need new catalytic converters and he thinks I need a new fuel pump because its running lean and fouling plugs. He already changed front O2 sensor and he says it passed fuel pressure test but still thinks fuel pump is bad because I have 266666 miles and have never had pump changed. May have to give in and go to dealership and hope they know whats wrong.
  3. May 2, 2022 at 8:39 PM
    #43
    1ChancetooLate
    1ChancetooLate Member
    Adam
    2003 3.4L Tacoma 4x4 Extended cab 5Speed
    Stock
    Caligula, is there a voltage range that should be seen with the scan tool when looking at said O2 sensors? Let's say a 2003 3.4L V6, at temp and running live data. What should be expected to be seen on the bank 1 sensor, and the bank 2 sensor? I have been trying to track down the actual oem spec for this scenario and have been coming up short.
  4. Jun 8, 2023 at 4:47 PM
    #44
    Lucky_Gargoyle
    Lucky_Gargoyle Well-Known Member
    96 DLX 2.7 4x4 5spd
    Toytec coil-overs, SPC upper, OME CS019 leafs w/ 5110 bilstein, LCE header
    wow I'd get a second on all that.:crapstorm:
    I just washed my cat cause I can and replaced the o2 (which I think is still good so I kept it) on my p0420
    Held for 1000+/- then now every 3 or 4 days just driving to the job site. Never back so I'm thinking a misfire or something from closed loop to open or, is that backwards, after she warms up in the chilly mornings. Hooked up Torque and yep that's when it happens. Now to trace that but still gettin 20mpg on my last fill up.
    JSB10[QUOTED] likes this.
  5. Jul 18, 2023 at 8:37 AM
    #45
    grntruck
    grntruck Active Member
    2002 Taco Double Cab
    OME lift. ARB bumper. Trans cooler, pillar pods, Alpine stereo, backup cam, LED headlights, Fog lights. Window tint.
    Interesting thread and lots of info. My .02 and experience.
    Have had the 420 code three times on my truck. About every 100k. Solution each time has been a new gasket on the junction before the cat. It breaks down and allows ambient air into the system. 324K with original Cats and O2 sensors.
    Edit
    Mistyped. After second cat before second O2 sensor
    ztwatson and Rastopher like this.
  6. Aug 22, 2023 at 9:05 PM
    #46
    SeaHorse
    SeaHorse Member
    Dana Point, CA
    2001 Tacoma PreRunner 4 cyl, 2.7 L Double Cab
    grntruck, can you be more specific about that location of the bad gasket that pops the P0420 code, in your case? Are you talking about the flanged junction located after the first (front) cat, but before the second (rear) cat? Or somewhere before the first (front) cat?
    ztwatson likes this.
  7. Aug 23, 2023 at 9:15 AM
    #47
    grntruck
    Flange after the second cat, before the second O2 sensor.
  8. Aug 23, 2023 at 12:09 PM
    #48
    SeaHorse
    SeaHorse Member
    Dana Point, CA
    Thanks for that reply :)
    For what it's worth, my 2.7 was pulling a lone, intermittent P0420 for awhile, which, over a few months, became more frequent.
    Turns out, I found an exhaust leak at the flange joint between the two cats. I ordered a $12 gasket for it, but in the meantime, slopped some Muffler Weld all around the flange joint to seal the leak - then cleared the code, performed the required drive cycles afterward, and just passed CA smog with flying colors this morning.
    It buys time, and keeps me on the road legally until I can get to the gasket repair. 320K-ish miles, both original cats, and so far, $2000 richer. Hoping that's the end of it. The thing simply will not die :)
    ab_1280, wayupnort and grntruck like this.
  9. Aug 25, 2023 at 6:38 AM
    #49
    Lucky_Gargoyle
    96 DLX 2.7 4x4 5spd
    Just a recap on my p0420. It was a bad thermostat. It was stuck open. Replaced and haven't had the code pop since. Realized that my truck was taking to long to warm up.
    wayupnort likes this.
  10. Sep 8, 2023 at 6:51 AM
    #50
    jabberjawmash
    jabberjawmash Well-Known Member
    Jackerz
    95Tacoma
    Lots of good 420 insight in this thread! Might revisit my 420 code I’m still dealing with on my 3.4l now. Yay!
    ab_1280 likes this.
  11. Dec 8, 2023 at 12:14 PM
    #51
    ab_1280
    ab_1280 Well-Known Member
    Alan
    2000 Silver Tacoma TRD 4x4 3.4L V6 X-Cab Manual 413K
    Great info in this thread. Thanks to all. I have a few months to chase my p0420 code before I need to smog. I'll look at the simpler stuff first. My cats are aftermarkets put in about 150,000 ago. Have 401,000 now and the truck runs great other than that dang code.
  12. Dec 11, 2023 at 6:14 PM
    #52
    fxst85
    fxst85 New Member
    carlos
    Austin, TX
    02 PreRunner TRD SR5
    Read somewhere about using a shop vac to find exhaust leaks. Worked! I cut out a round piece of foam to fit snug in the tail pipe, then cut a hole in the center using the shop vac hose as template. Used the vac in the blow vs. Suck mode. Then used soapy water in a spray bottle to wet the flange junctions. Leaks confirmed at both flanges. Used rtv and so far so good, no more cel.
    TRD493, ab_1280 and ztwatson like this.
  13. Dec 19, 2023 at 6:42 AM
    #53
    jabberjawmash
    Jackerz
    95Tacoma
    I did a similar method but used a bicycle tube cut down with a shop vac! Worked pretty decent and found a few pinholes that I welded up. Still got a pesky 420 code :/ really do not want to pay for new cats. Tossing new exhaust manifold gaskets on next, will report back
  14. Dec 24, 2023 at 1:11 AM
    #54
    awilson301
    awilson301 New Member
    Brian
    2002 Tacoma 4x4 5 Speed
    I wish I found this before I started trying to fix the problem a couple years ago. First a cleared the code and it stayed gone for a couple months. Then I cleared again and it came back right after I started the truck up. Then I bought an ebay Cat replacement kit and new O2 sensors.... But damn was it hard to remove that aged/rusted bolts up top of them converters. Had to use a blow torch and angle grinder. then I ended up just getting an entire MBRP exhaust since I was going through all the trouble already.
    I fell for all the post about reduced MPG and could cause power loss etc so I just replaced everything.
    great information.
    #54
  15. Dec 24, 2023 at 8:49 AM
    #55
    Chrisdot
    Chrisdot New Member
    2003 Tacoma 2wd
    Not a reply but a question..... Could it be that my catalytic converter needs to be replaced?. I only have 490,000 or so miles on it.....
  16. Dec 28, 2023 at 5:38 PM
    #56
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Just replaced the downstream O2 sensor with a Denso. Next day drove 500 miles from Sacramento to San Diego and the CEL has stayed off.
    :fingerscrossed:
  17. Dec 28, 2023 at 5:59 PM
    #57
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Did OP get banned ?
  18. Jan 6, 2024 at 2:12 PM
    #58
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    aaaaaand it’s back..
  19. Jan 6, 2024 at 8:41 PM
    #59
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Pain. Sorry to hear that.
  20. Jan 8, 2024 at 12:20 PM
    #60
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I've been chasing this on my truck with 208k miles for the past year. I recently replaced the rear O2 but the code came back after a few weeks. I also have been fighting an exhaust leak at the header to cat connection, but that one is currently sealed. I connected an air compressor on low pressure to the tail pipe using this: https://amzn.to/48odQmY
    I haven't found any obvious exhaust leaks, but it definitely sounds like I have one at certain RPMs while driving. I'm hoping there's not a crack on the collector of my LCE header. I will try to see if I can get some soapy water in there and an inspection camera at the same time.
