Addressing some common misnomers of the P0420 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caligula, Oct 20, 2015.
  1. Nov 16, 2024 at 11:19 AM
    #61
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Noticed that I do have a pinhole leak just after the down stream o2 sensor. Almost directly below it. Could this cause 0420? Or are leaks after the last sensor irrelevant??
  2. Dec 29, 2024 at 6:11 PM
    #62
    thorfinn
    thorfinn Member
    I have a 2001 Tacoma 3.4 v6 with the P0420 and P0505 code. Have replaced all vacuum lines and did a top pan and plenum gasket replacement. Tested both o2 sensors with my scan tool o2 sensor bank 1 sensor 1 has a voltage of 3.2v to 3.3v, while o2 sensor bank 2 sensor 1 fluctuates from 0.6v to 0.06v never constant. Need help gas mileage is 10mpg to 12mpg combined.
    Have also replaced mass air flow sensor, throttle position sensor, cleaned throttle body and replaced iac valve, replaced spark plugs, wires and coils.
    My idle is at 1050 when cold, 1250 when hot and 860 when in drive or reverse
    I keep seeing o2s inc and evap inc on the I AM readiness
    Need help
  3. Jan 7, 2025 at 7:00 AM
    #63
    TacoLover719
    TacoLover719 Tacoma whisperer
    Drake
    Blacked out ‘03 Tacoma 2.7l
    LCENGINEERING low boost SC LCENGINEERING long tube headers + EGR delete + MBRP muffler and custom made side dump 170k miles Puck lift Short throw shifter kit K02 tires on American Racing Baja wheels 220whp
    I had to take off my throttle body and clean out my IAC. also replaced the throttle position sensor and evap purge solenoid. Had been chasing a high idle since I replaced my fuel tank. Also had a bad pcv valve oiling up the inside of my intake and throttle body, I have a PO420 because I’m catless and it doesn’t change how the truck drives so you probably just have a bad cat, or downstream o2 is funky
  4. Jan 8, 2025 at 4:03 AM
    #64
    thorfinn
    thorfinn Member
    Thank you for the suggestions! I appreciate it. I've already cleaned the IAC, replaced the throttle position sensor, and ensured my vacuum lines are good. I will also replace the PCV valve and purge solenoid, as well as the fuel filter and coolant temperature sensor since I have those parts on hand, to see if there's a difference.
    Currently awaiting a new downstream os sensor from denso
  5. Jan 8, 2025 at 7:57 AM
    #65
    TacoLover719
    Drake
    Yeah the PCV was causing a slight misfire at idle for me and the throttle position sensor was sticking keeping m butterfly valve open just slightly
  6. Mar 13, 2025 at 6:01 PM
    #66
    Miniguy
    Miniguy Black Betty
    Norman
    Chiefland,Florida
    2002 Black Tacoma 4x2
    Intermittent wipers…so far
    I have replaced the front O2 sensor but the rear is VERY difficult for someone laying under the truck to do because of the heat shield is there a way to get the shield off without a lift? Mines also an 02
  7. Mar 13, 2025 at 6:15 PM
    #67
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    It’s doable just a bit more finicky.
  8. May 4, 2025 at 11:25 PM
    #68
    genuin1sequoia
    genuin1sequoia New Member
    1st gen Sequoia 2WD 325k all Denso,Aisin here.
    Besides my 20" Pro-Comp mags & Perelli Scorpion tires plus a quality 3,000 watt sound system she's all Toyota. I've replaced so many parts to make it a solid driving truck. Wrapped steering wheel with real leather cover, Struts, shocks, rotors, quality pads, full front end rebuild with urathane bushings, windshield, all door actuators, fuel injectors, coil packs, iridium spark plugs...all Denso. All soft fuel lines & vaccum lines new, New carpet kit. I cleaned the original white paint to as good as new.
    I'm a new groupie with my 2002 Sequoia. Today I can finally say I resolved my P0420 code. Like a moron I spent $3,000 on new CARB approved Magnaflow cats plus all 4 Denso O2's. Light came back in.....Coolant temp sensor, thermostat and $10 o-ring was next and light came back on....Finally I installed my set of Denso 4 hole fuel injectors and have driven 200 miles with the light staying off! My next thing was going to be the exhaust manifolds!
    Several people told me "it's your cats man"
    I am glad i didnt recycle my old cats bcause I know they are still good now! I met an older lady with a 2002 Sequoia just like mine and her cats were stolen about 6 months ago. Im trying to locate her now so I can bless her with my old set so she can register her truck. Im even going to make her a cat theft shield as well.She cant afford to buy new cats so Im going to be her santa this year!
    California and New York are mafia states with this CARB approved cats...48 other states are ok with basic Federally approved cats, why do I have to live in this one?
