Adhesive Removal Help
Discussion in 'Detailing' started by kai_uhl, Jun 21, 2015.
  1. Jun 21, 2015 at 3:54 PM
    kai_uhl
    kai_uhl [OP] New Member
    Kyle
    I recently took off a chrome trim piece on my door and am having trouble removing the adhesive residue. I have tried GooGone but it does not seem to be that effective. Any ideas on how I can remove the leftover adhesive?
    -Thanks
  2. Jun 21, 2015 at 4:08 PM
    CaptainReverso
    CaptainReverso Well-Known Member
    Cory
    Gardena
    2015 TRD off road 4x4 DBL cab Magnetic Grey
    Off Road Stuff
    Googone works well for me. But for stuff like that you need to let it soak and seep in for full effect. Try to take a rag or paper towel soaked in goo gone and hold it on there for 5 min or so. The oil I'm the goo gone will eventually eat away at the adhesive. Another product that works, but is a little more harsh is orange 90. I've never used on car paint, so use at your own caution
    ToyoTaco25 likes this.
  3. Jun 25, 2015 at 2:08 AM
    nismo14
    nismo14 Well-Known Member
    Hawaii
    2015 4x4 DCLB TRD Sport
    go to your local auto paint store and ask for a 3m rubber wheel, pin stripe remover, etc. Some people refer to them differently.
    Mount it to your drill and go for it. It's just a big eraser and will get ALL the sticky stuff right off. I used it when I debadged my tacoma and removed all the emblems and TRD stickers. 5min total, and just wipe off the eraser shavings with a dry microfiber, apply sealant, done...
    http://www.amazon.com/gp/product/B0..._m=ATVPDKIKX0DER&pf_rd_r=1Z5BVXC26T1R91NQ0GQ0
  4. Jul 9, 2015 at 6:45 PM
    Dbl Taco
    Dbl Taco Hard Taco
    Virginia Beach,Va
    2013 X-Runner Supercharged/2001 4Runner sport
    Urd intake Urd stealth pulley Djm 3/4 DTLT headers Urd o2 sim Urd trac bar Afe 3" cat back Xii performance stock coils
    Lacquer thinner
  5. Jul 9, 2015 at 6:54 PM
    TacomaDarth
    TacomaDarth Well-Known Member
    Randy
    Northern Michigan
    2015 TRD Off Road in it's infancy
    C-Clamp Theft Deterrent System (with bonus heat shrink protection), FJ Trail Team Wheels with Duratracs, WeatherTechs. TRD Exhaust, Access Limited Tonneau Cover, Rear Diff Mod to Taillight
    Believe it or not WD-40 is far and away the best adhesive remover I've ever tried. I've used goo gone and 3M stuff and good ole WD-40 works the best and won't mess up the paint in my experience. Use it for all my debadging. My two cents.
    HondaGM likes this.
  6. Jul 9, 2015 at 6:56 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Ditto.
  7. Jul 9, 2015 at 6:57 PM
    Dbl Taco
    Dbl Taco Hard Taco
    Virginia Beach,Va
    Yes wd-40 is the least aggressive
  8. Nov 28, 2022 at 5:11 PM
    Tacomabro7
    Tacomabro7 Active Member
    2016 Red Tacoma TRD Off-Road 4x4 Automatic
    Hi-line front bumper 305/60R18 tires
    I had taken the clear paint protection film off the hood of the truck and it left a very sticky glue residue on the hood. Nothing touched it. We tried mineral spirits, brake parts cleaner, alcohol, 3M general adhesive remover, turtlewax, everything; yet nothing came close to touching it. I went by a graphics shop and they put me on “Rapid remover” and that stuff works!!! Using that along with a plastic squeegee and it came right off. This is commercial grade stuff and not the dilute store bought stuff. This is the stuff to use for stubborn glue residue. I’ll post before and after pictures.
  9. Nov 28, 2022 at 5:19 PM
    bruhman
    bruhman Well-Known Member
    PDX
    '22 White TRD Pro MT
    SnugTop canopy
    This^. I've used it to remove decal residue many times with ease (and caution).
  10. Nov 28, 2022 at 5:41 PM
    koditten
    Kirk
    Central Michigan
    I'm curious what it's composition is.
    Can you do a finger test?
    Place a drop on your finger. Rub your thumb on the drop. Is it slippery and doesn't evaporate fast?
    If yes, then this is a caustic cleaner. It has a high pH.
    The reason it feels slippery is because it is actually removing your dead skin on your finger tips.
    Just rinse your hands good and you will have no issues.
    If you don't feel like answering, I'll understand.
  11. Nov 28, 2022 at 5:46 PM
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    Was the residue you had smooth to the touch when you ran your finger over it? I’m having a similar issue after removing a bug deflector. I’ve tried 3M, clay bar, and most recently meguiars ultimate compound.
    Tacomabro7[QUOTED] likes this.
  12. Nov 28, 2022 at 10:24 PM
    Tacomabro7
    Some parts were very smooth while others were very rough. Took every bit of it off! Order that rapid adhesive remover in my picture, and get a plastic razor blade squeegee thing from Amazon or wherever. Here’s a link to the plastic razor squeegee on Amazon: https://www.amazon.com/FOSHIO-Scrap...c7b-4b93-a8f2-6fe565597248&pd_rd_i=B076BBW1WM
    Here is a link to the Rapid Remover on Amazon: https://www.amazon.com/Remover-Spra...357-43e2-9bed-b27ef37f4f53&pd_rd_i=B01MSFD50H
    Spray it on the area and leave for about 60 seconds. Then scrape it off. Eventually the layer of glue will get thin enough to just rub it off with a microfiber towel after spraying more product. Will take just a little elbow grease but it cuts it doesn’t take long at all with this stuff!! Just tape up your headlights and rubber at the front of the hood because I hear it can deteriorate it. The adhesive in my picture was completely removed in under an hour and there was a BUNCH of it! Best of luck!!
    junkyarddogg[QUOTED] likes this.
  13. Feb 17, 2023 at 10:39 AM
    DannyR
    DannyR Well-Known Member
    Daniel
    El Paso, TX
    2020 Quicksand TRD Off Road 4x4 DCSB
    Pick up some 3M General Adhesive Remover, just don’t get it on textured plastics or headlight lenses.
  14. Feb 17, 2023 at 10:42 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Ive used WD 40 to...just have to let it soak for awhile
  15. Feb 17, 2023 at 10:43 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
