Adjust headlights after lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Millertime187, Nov 25, 2012.
  1. Nov 25, 2012 at 5:27 PM
    Millertime187
    Millertime187 [OP] I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I have a 2012 tacoma and now that it getting dark at 6 I have been getting people light checking me. Are the stock lights that bright or has my 3 inch lift affected the angle causing it to be in people face? I also hit a big buck in the ass tonight. Thank god for the great brakes on the truck. I just clipped him in the butt with my front passenger bumper. No damage. Lucky cause I was rolling.
    So is there a way to adjust headlights?
  2. Nov 25, 2012 at 5:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Nov 25, 2012 at 5:33 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Yes, search on here if you need to see where the adjustment points are. You'll use a long Phillips head screw driver for up down/left right. I also hit a deer with my car last night (civic) and same thing happened I braked and managed to scrub off enough speed before impact. I hit her legs out from under her and had fur under my headlight but no damage. At the time of impact I was going less than 10, I really got lucky. With I was in the truck with my ARB!
  4. Nov 25, 2012 at 5:34 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Holly cow! That's a lot of crap to do to adjust them. Guess people will just have to deal with it.
  5. Nov 25, 2012 at 5:35 PM
    rawdog
    rawdog Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    stupid deer are running all over the road at this time of year. Everyone needs to get out and start hunting!
    And yes, its definitely your lift.. as your lights are 3" higher and your truck is probably level now so the lights go straight forward rather than slightly down.
  6. Nov 25, 2012 at 5:37 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Definitely adjust them down a little.
  7. Nov 25, 2012 at 5:37 PM
    AzogSS
    Andy
    Soda City, SC
    If you can turn a screw driver you can adjust them.
  8. Nov 25, 2012 at 5:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Welcome to the problems of lifted vehicles.
    Yes, the headlights must be adjusted any time the suspension is changed.
    Now for the bad news.
    It's not going to help as much as you hope.
    The problem is, the proper headlight aiming reference changes with the height of the headlights.
    Stock, say your headlights are 24" above the ground. The low side of your cutoff should appear at 22" on a wall 20ft ahead of the truck.
    Lift the truck 6", and now the headlights are 30" above the ground. The aim point moves up to 28".
    Theoretically, you only need to correct for any difference in lift between the front and rear (and be sure to check it from time to time as the springs settle in).
    Adjusted properly, your view down the road will be slightly improved, and you shouldn't be getting people flashing you, but when you pull up behind someone, you need to be aware that you may be blinding them from behind.
    If you aim the lights lower than they should be to avoid blinding people in front of you, then you end up really hurting your range on low beam.
  9. Nov 25, 2012 at 5:38 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :rolleyes: Adjust your lights
  10. Nov 25, 2012 at 5:38 PM
    Spoonman
    Jamie
    Alberta
    It's very simple. Locate the vertical adjuster and lower the beams little bit. Turn them both the same amount of turns. Done in 5 minutes.
  11. Nov 25, 2012 at 5:39 PM
    OZ-T
    Peter North
    British Columbia
    Yeah , this
    The pdf I posted just was to show you where the adjusters are
  12. Nov 25, 2012 at 5:44 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    As long as the bumper cover doesn't have to come off I will do it. So a long screwdriver will get to a screws? To easy then!
  13. Nov 25, 2012 at 5:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Seriously... it's a 15 minute job.
    Park behind the local Lowe's and use their wall.
    20ft from the wall, measure to the center of your headlight (center of the bulb's glare shield), lay a piece of tape on the wall 2" below that.
    Unplug one headlight and adjust the other, then swap plugs.
    reallifedog and REDdawn6 like this.
  14. Nov 25, 2012 at 5:50 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Good thinking on the lowes wall. Was wondering where to do it cause my drive way is a hill. Thanks everyone I shall do this week!
  15. Nov 25, 2012 at 5:51 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I guess I have to move south to get longer days. It was getting dark by 4pm here today.
  16. Nov 25, 2012 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
    Same here
  17. Nov 25, 2012 at 5:56 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Can't wait till spring. I hate this time of year with the short days and cold weather.
  18. Nov 25, 2012 at 5:57 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Woot woot I'm not a junior member no more!
  19. Nov 25, 2012 at 6:04 PM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    If your state requires yearly inspections (they do here in Texas) then any place that does them can adjust your headlights to be in compliance. Even if your state doesn't, please adjust them down as suggested by Oz and Rich.
  20. Nov 25, 2012 at 6:06 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    No state inspections in kentucky. I am going to adjust this week.
