Adjust idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by mte, Sep 28, 2022.
  1. Sep 28, 2022 at 7:11 PM
    mte
    mte [OP] Well-Known Member
    1999 Tacoma v6
    1999 Tacoma V6...is it possible to adjust idle up a few clicks?
  2. Sep 28, 2022 at 7:34 PM
    mte
    1999 Tacoma v6
    I should have researched a little further before posting...all roads lead to no can do.
    Ok, another question...do I have to dig into the throttle body to replace IAC?
  3. Sep 28, 2022 at 8:40 PM
    02hilux
    Planet: EARTH
    Yes. You'll need to remove the tb to access the iacv
  4. Sep 29, 2022 at 8:27 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Out of curiosity, why are you trying to idle up? If you have a low idle- it's a sign that some other system is outta wack. IAC would be a good start, but I'd also consider MAF (clean it using only MAF safe cleaner), TPS, and O2 sensors. The manufacturer of those sensors is crucial if you go to replace them. OEM or Denso are safe. Random parts store brands cause more issues than they fix.
    As a hack though- you can artificially increase the idle by over-tightening the throttle cable- essentially the same as always pressing the gas pedal just a little. It's not advisable, but possible.
