Adjust Parking Brake Tension, 2010 Prerunner??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RV7Garage, Sep 17, 2009.
  1. Sep 17, 2009 at 7:59 AM
    RV7Garage
    RV7Garage [OP] R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Hey gang- I tried searching for threads relating to this, but failed.
    Does anyone know how to adjust the parking brake on a Manual Trans 2nd gen, to make it stiffer? I have a mild hill for a driveway, and really have to yank on the e-brake to get her to hold. Thanks mucho :)
  2. Sep 17, 2009 at 8:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    First - take it to the dealer and have them adjust it / check it.
    Afterall, it could be something else and perhaps the rear drums need checked too.
  3. Sep 17, 2009 at 8:25 AM
    RV7Garage
    Paul
    Ill Annoy
    OK, while I'll admit that what you say is possible, the truck doesn't even have 500 miles on it. I really think I just need to tighten up the e-brake cable to suit my taste/needs... and don't want to sit at the dealer waiting... but I don't know how to do it. Thanks, though :)
  4. Sep 17, 2009 at 8:33 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Dealer.. 500 miles, And you dont think it's right... The parking brake should hold firmly about 14.16 clicks out. Also, check the manual.. this book is handy...
  5. Sep 17, 2009 at 8:44 AM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Jack up the rear wheels so both are off the ground, then on the back of the rear wheel drums you'll see a rubber grommet near were the brake line attaches (its about 1 inch long grommet). Remove the grommet and shine a light in there, you'll see the adjuster that has teeth on it, use a flat screwdriver and adjust in a upward manner (you'll here it click as you adjust). Adjust it a couple a clicks and then spin the wheel your adjusting to see how freely it spins. Typically we adjust it till you here a very slight drag between the drum and shoe, hope this helps
  6. Sep 17, 2009 at 9:29 AM
    RV7Garage
    Paul
    Ill Annoy
    cjimenRR- that's the info I was looking for- thank you! Thanks to al others for their input as well. :)
  7. Sep 17, 2009 at 3:47 PM
    Janster
    Jandy
    Lancaster, PA
    It's not the point..... You paid $$$$ for a new truck and it's not right. Something could be wrong from the factory. That's what warrantee is for....
    Personally, I'd just take it in because if something happens with the brakes later on...and you actually need warrantee work......they might discover that you were adjusting things and deny warrantee coverage. That's worse case scenario...but something to think about.
    You can adjust brakes a couple different ways....
    What cjimenRR suggested is only an adjustment on the shoes and could be temporary. These drum brakes should be auto adjusting and you shouldn't need manually adjust them like that..... something could be wrong with the adjuster mechanism. Also, the ebrake cable could be out of adjustment from factory.... You really don't know for sure what is wrong.
  8. Sep 17, 2009 at 5:13 PM
    RV7Garage
    Paul
    Ill Annoy
    OK, Janster- fair enough! You make a good point. I'll give 'em a call. ;)
  9. Sep 17, 2009 at 5:20 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    You never know what could happen as it goes down the line during production. I am a firm believer of doing it yourself, but when its free and since it is new, let them do it and have them do the whole safety check of the brake system, etc. :)
  10. Sep 17, 2009 at 5:38 PM
    cjimenRR
    North Hollywood, Ca
    Kinda making a big deal out of this aren't you guys? They ship these trucks with the e-brake at it's highest (while still within spec) brake clearance so that if water enters the drums during shipping for whatever reason the drums don't get stuck to the shoes. Same reason they put cardboard cut outs on the front rotors, so they won't rust or seize onto the pads.
    RV7 save yourself a trip and loss of your valuable time by adjusting them the way i mentioned, I've been doing this on my Toyota's and customers Toyota's for the last 10 years at my job and you have nothing to worry about. I would adjust them till I get about 5-6 clicks on the e-brake handle, too much adjustment and you could overheat the rear brakes. If that don't put you at ease then by all means take it to the dealer but be prepared to leave the same way it came in because if they find the e-brake to be within Toyota's spec they wont adjust them
  11. Sep 17, 2009 at 7:19 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I didnt like mine either, so i parkd on a steep hill and applied the park brake with a moderate pull. It held. Taht 14-16 cilcks sounds like a good check, thank s Janster.
  12. Sep 17, 2009 at 8:04 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Never did like that T handle parking brake on the MT. They always seem to get loose too quickly.
  13. Oct 2, 2010 at 2:34 PM
    mr2crazed
    mr2crazed Well-Known Member
    Morro Bay, CA.
    06 DC PreRunner SR5
    Sorry for dragging up an old thread.
    I removed the grommet and I can't see the where the adjuster is. How far in is the adjuster? Anyone else successfully do this?
  14. Oct 2, 2010 at 3:04 PM
    JKD
    JKD Well-Known Member
    NEVERMIND, zombie thread, no point in replying.
