Adjustable bed racks for Retrax
Discussion in 'Tonneau Covers, Caps and Shells' started by Brawwp, Mar 30, 2022.
  1. Mar 30, 2022 at 5:18 AM
    Brawwp
    Brawwp [OP] Well-Known Member
    Oahu
    2022 white SR 4x4
    Are there any adjustable bed rack options for the Retrax? I know there’s the Yakima, but it already starts out higher than the cab from the images I’ve seen. I’d ideally have one that begins lower than cab height for RTT to be out of wind and lower, but can also adjust to just above the cab for long board surfboards or anything else long.
  2. Mar 30, 2022 at 5:36 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    I have the uptop truss that goes into the retrax. You have two options. 1 full height of cab and 2 half height for folks like you.
  3. Mar 30, 2022 at 5:38 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Sounds like he wants a rack that can be adjusted in height.
  4. Mar 30, 2022 at 5:39 AM
    Brawwp
    Oahu
    2022 white SR 4x4
    Yeah I saw that one. The Yakima is almost perfect if only it was mid height then adjustable to over cab, instead it seems like it’s lowest setting is already at the height of the cab. So not real sure why it’s even adjustable.
    I need over cab for longboards. I also hate the idea of having a RTT that high for when we go camping. Plus we have a dog so having the RTT lower would be ideal for multiple reasons
  5. Mar 30, 2022 at 5:40 AM
    Brawwp
    Oahu
    2022 white SR 4x4
    Exactly. Do you guys make anything like this? Or that could be easily swapped from mid to high? Like I said, the Yakima is adjustable, but it’s adjustment makes no sense to me being it’s lowest setting is already cab height.
  6. Mar 30, 2022 at 5:42 AM
    virginiamarine
    Northern Virginia
    I see what you're looking for now. It would be nice to have an adjustable one for sure! I wouldn't think it would be too hard, but you are placing a lot of weight up there at one point or another. I'll keep an eye out for you!
    Brawwp[OP] likes this.
  7. Mar 30, 2022 at 5:45 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We make one adjustable rack, but it may not be the “overland” style that you’re looking for:
    https://www.max-modular.com/toyota-tacoma-years-2005-to-present-11/utility-rack-for-tonneau-covers
    Aside from that, we make racks 10”, 14”, 18”, 22”, and 24” in height, and they are all compatible with Retrax covers.
