Adjustable coils
Discussion in '1st Gen. Tacomas (1995-2004)' started by saweetlou, Apr 9, 2010.
  1. Apr 9, 2010 at 6:41 AM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    I just recently bought a 02 Taco with Skyjacker front adjustable coils which are supposed to be able to give me 2in of lift, Im running 265/75/16 and cant even roll off my driveway without rubbing. I have tried to turn the top of the coil with that key but it wont budge. Do I need to do something to make it easier like jack it up to re leave pressure or something else.
  2. Apr 9, 2010 at 7:01 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    do not try to adjust the coils with the truck still on the ground. bad things will happen. jack the truck up.
    i'm not familiar with the skyjacker CO's but if they have a set screw loosen it and then adjust from there. the collar might be hard to turn so some lube might be needed. you can spray WD 40 on the thread and wait 10 min and that will help alot.
    where are you tires rubbing? 265/75 shouldn't be rubbing a whole lot or at all with a 2" lift. post up some pics so TW can help you out better
  3. Apr 9, 2010 at 9:52 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Coilovers are a bitch to adjust, like stated, jack up the front and let the wheels droop then adjust, UCA and wheels maybe in the way so take your time. Make sure to get an alignment after.
  4. Apr 9, 2010 at 10:13 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    easiest way to adjust them is to remove them from the truck. it's only 4 nuts and bolts. ..and the uca won't be in your way.
    i'd also add some anti-sieze to the threads while you're at it.
  5. Apr 9, 2010 at 10:38 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    if the coils are off the truck it's gonna be really hard to get the amount of leverage needed to adjust them if they are being a bitch and not turning.
  6. Apr 10, 2010 at 5:04 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Oh I didnt know about the set screw would it be an allen key, the coil is already wound down about 2in.The truck doesn't sit all that high, Im running Toyo M/Ts that are pretty aggressive so it rubs right where the mud flaps are SUPPOSED to be, the rear sits I would say about 2in higher than the front so Im trying to level it out a little.
  7. Apr 10, 2010 at 8:11 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    yeah, the set screw is the small allen key fitting on the collar. you can see it here just to to left of the uni ball on the UCA
    you might also want to try this...
    http://www.customtacos.com/tech/index.php?article=9
    what's the back spacing on your wheels?
  8. Apr 11, 2010 at 5:45 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    you must not have a vice ...or an imagination.
    i can think of a half dozen ways to keep the end stationary while i spin the adjustment collar.
    i'd also suggest you get a nice pair of gloves with knuckle padding if you plan on adjusting the coilover while it's on the truck.
