Adjustable Proportioning Brake Valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chadabear, Jul 7, 2017.
  1. Jul 7, 2017 at 7:06 PM
    chadabear
    chadabear [OP] Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    So I've owned my 08 DCSB since new. Always hated the braking, even after slotted rotors, performance pads, steel braded lines, and adjusting the rear shoes...the initial mushiness of the pedal always bothered me. I know it's been narrowed down to mostly rear slop in the drum clearance, but this is what I've been wondering...
    I'm no idiot when it comes to performance stuff, I've been around drag racing my whole life. Had 8 sec street legal cars. All of them have had an adjustable Proportioning valve for the brakes. It just seems to me there is too much valving initially to the rear. Am I over thinking this? Or would this allow a more balanced initial pressure to hit the front first, then rear after, taking out the degree of movent of the shoes???
    http://www.jegs.com/i/JEGS/555/6302...65_G4MSGkwTO0OyEBTcngd9uQ_2CjTlpLjxoCHZXw_wcB
  2. Jul 7, 2017 at 7:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It may do just what you want. You will more than likely have to have adapters to metric...
    Try it and let us know your results.
    My personal feelings are that it is not needed and the brakes are just fine on every Tacoma that I have driven. But if you feel it is needed for you, by all means get one and try it out.
    JoefromPTC likes this.
  3. Jul 7, 2017 at 8:27 PM
    Muddinfun
    Muddinfun Well-Known Member
    A proportioning valve limits the max pressure to the rear brakes to prevent rear brake lockup. I don't see how changing the max pressure is going to affect initial brake aplication.
  4. Jul 7, 2017 at 11:21 PM
    Sgt BadA
    Sgt BadA Active Member
    Fort Worth TX
    2018 TRD offroad quicksand
    Icon 2.5 coilovers and Dakar leafs, caliraised ditch lights, TRD intake, 16x8 TRD Trail Team rims with 33in BFG KO2 tires
    I would have to agree with the statement above. Unless you have converted the rear brakes to disc it doesn't make a lot of sense to mess with it. From my experience of messing with the brakes on my xrunner (converted to Tundra front brakes) is that the master cylinder bore is kindof small for the 4 piston brakes on the 6 lug Tacoma. It's even smaller on the tundra caliper. I'm currently in the process of buying a master cylinder and booster to convert it over for better braking response.
    Tex-Tac likes this.
  5. Jul 8, 2017 at 11:02 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    :popcorn:......sub'd....... :burnrubber:
  6. Jul 8, 2017 at 3:20 PM
    chadabear
    Chad
    Louisiana
    2018 DCSB 4x4
    It just seems to me that the master cylinder valving is bass awards. If the slop is coming from the rear, then the initial hit of the brakes should be on the front. The slack in the distance between the drums and shoes is what causes the delay. The proportion valve would change the pressure to allow less of the fluid pressure to hit rear. In reality, 80-85% of the braking is on the front, and the rears should take over after that. Optionally, it shouldn't hit rears at all, unless it's a hard brake.
  7. Jul 8, 2017 at 4:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    10mm x 1.0.
    Do the www.sosperformance.com rear disk swap. Join the cool kids club. :cool: Be and outsider like the few of us. Lol.
  8. Jul 8, 2017 at 9:41 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    My question is with 4 channel ABS where are you going to install this?
  9. Jul 9, 2017 at 9:30 PM
    Sgt BadA
    Fort Worth TX
    The rear brakes should activate before the fronts do. On a drum setup at least, the rear shoes should barely be braking before the fronts start to begin to brake. It keeps the truck balance
