Adjustable roof rack scene pods/flood lights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cameron172, Apr 30, 2022.
  1. Apr 30, 2022 at 5:29 PM
    cameron172
    cameron172 [OP] Well-Known Member
    VA
    2017 Super White TRD Sport MT
    I’m looking to get adjustable scene pods/flood lights to add to the roof rack with low profile mounts. I’m thoroughly overwhelmed by all the websites and mounting options. Any recommendations?
    I’d like to use them as ditch lights while driving then adjust them to scene lights once stopped.
    What is the best way to wire these to the battery?
  2. Apr 30, 2022 at 7:42 PM
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I'd be curious to see what products meet these specifications. I'm only aware of fixed-mount options that point perpendicularly from the longitudinal axis of the truck. Depending on your rack, you could get fancy with 3d printed mounts. I designed my own but they're still fixed perpendicularly.
    As for wiring, there's many ways you can go about it, but the smartest way, I'd argue, is to build/buy an auxiliary fuse panel. That mounts in the engine bay (typically), connects to the battery, and you can connect a number of accessories to the panel. Neater, cleaner, funner. Check this thread if you'd like to know more about a DIY-route: https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/
