Adjustable Tire Deflator Kit
Discussion in 'Off-Roading & Trails' started by SCSPerformance, Mar 14, 2013.
  1. Mar 14, 2013 at 9:52 PM
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    Does anyone have any personal experience with these type of adjustable tire deflator? I'm looking for something to make airing down a little quicker. I've seen some deflators that takes literally 10mins to air down each tire on their own.
  2. Mar 14, 2013 at 9:55 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Ive got the little cheep red ones it takes about 5min or less to air mine down but they don't stop you have to remove them.
  3. Mar 14, 2013 at 9:56 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2015 Tundra Double Cab
    Kings:Camburg:BFG
  4. Mar 14, 2013 at 10:01 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
  5. Mar 14, 2013 at 10:03 PM
    PLC721
    Patrick
    Chandler, Az
    Kings:Camburg:BFG
    Less than a minute probably, its very easy and quick. i recommend it :thumbsup:
  6. Mar 14, 2013 at 10:03 PM
    MYT4CO
    MYT4CO Well-Known Member
    mark
    TX
    MYT4CO
    2012 taco, 92 toyota pickup, 95 4runner
    The arb is badass it actually removes the valve stem to let air out real quick
  7. Mar 14, 2013 at 10:06 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Sweet, just what I was looking for. Thanks guys.
  8. Mar 14, 2013 at 10:10 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I don't like those staun types. ARB or Currie ez-deflator works the best that I've seen.
  9. Mar 14, 2013 at 11:16 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Good to hear, thanks. I'm going to pick one up.
  10. Mar 15, 2013 at 6:43 AM
    JLee
    Jerry
    Bay Area NorCal
    Thats not a per tire thats for all 4 your not going to get much faster the 4 min. even with the arb you have to do one at a time so it takes about the same time as my 6.00 dollar ones thats air down all 4 at once. I wheel with guys that have the arb and it wasn't faster.
  11. Mar 15, 2013 at 7:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you looked at Oasis Tire Deflators?
    http://www.oasismfg.com/
    http://aircompressors.oasismfg.com/viewitems/tire-deflators/automatic-tire-deflators?&forward=1
    We still have a set that we've used on the Jeep.
    Ours are RED and you can adjust between 5-20lbs. They're easy...just screw them on (all 4 of them) and you can drive while they're deflating. The only hiccup - if I remember correctly, if your tire deflators are set to 15lbs.... the pressure in the tires needs to be 30lbs+ for them to work. The initial air pressure of the tires triggers a valve inside and opens them up to start deflating.
  12. Mar 15, 2013 at 7:47 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    The Oasis Trailheads are the ones I have used for several years, they are a little bit of a pain to initailly setup, but once they are done, they're done. They don't take long to deflate to a preset pressure, and you aren't sitting there with your gauge holding the valve down, f@*k that.
    Brandon
  13. Mar 15, 2013 at 8:09 AM
    Janster
    Jandy
    Lancaster, PA
    I'll sell you the set I have....$45 includes shipping. If interested, I can take photos ..etc.
  14. Mar 15, 2013 at 8:27 AM
    DevL
    DevL Well-Known Member
    You don't hold anything down with the ARB. The real key is knowing how long to wait as you only can use the pressure gauge when it is NOT deflating. So if you want to run say from 30 to 15 psi you need to count x seconds. If you stop 10 times to check pressure each tire it takes longer. After your first use you will only check pressure for small adjustments once or twice. It is very fast AND very precise. I am super impatient and do not want anything faster. Now inflating.... that is slow and tedious without CO2.
  15. Mar 16, 2013 at 8:24 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I have these and i am happy with them. I used a wheel barrel tire to make the initial adjustment to set them all at 18 psi. Ever since I set them at 18 they work perfectly. Just screw one into each wheel and they shut off in a few minutes.
  16. Mar 16, 2013 at 8:28 PM
    PLC721
    Patrick
    Chandler, Az
    Kings:Camburg:BFG
    Power Tank FTW
  17. Mar 17, 2013 at 11:59 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Thank you for all the info guys. I decided to go with the ARB kit. I like the fact that there's an accurate pressure gauge to go off of.
    The real $taun brand deflator seem to work well from what I've researched and I like that you can basically screw all 4 in then sit back and wait. Even though it only needs to be set one time, I know I would still check it with a tire pressure gauge just to be sure.
    The cheaper copycat staun type deflator all seem to have an issue with leaking even though it's set. This makes it unreliable and time consuming imo.
  18. Mar 17, 2013 at 12:08 PM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    05 Speedway Blue PreRunner TRD Off Road
    3 inch lift OME 885, 2in AAL, 5100's, Black Badges, Fog anytime, ABS on/off, window vents, Blacked grill and rear bumper, Afe pro s dry drop in filter.
  19. Mar 18, 2013 at 6:57 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Love my Staun deflators. Split a set of 4 so only paid $40 for 2. Takes less than 5 minutes to do all the tires.
  20. Mar 18, 2013 at 8:07 PM
    BeeRadd
    BeeRadd ANTI-DARK Vendor
    Brad
    Fountain Valley, CA
    2008 DCLB 4x4 TRD Sport
    Mag light mod, ABS Kill switch, On board air, tail-gate theft mod, Redline hood struts, Shovel mount, Rubberized undercoated frame, CB radio w/lil wil magnet antenna, LED interior light, Shocker 228 Train horns, black valence, fog lights anytime, black hood scoop, eyelids, anti-seatbelt chime hack, weathertechs,
    Whats the difference between 20 - 5 and 40 - 15?
    I normally run about 35-40 PSI and wheel with 15 psi
