adjusting 5100s with a spanner wrench
Discussion in 'Suspension' started by reywasneb, Sep 3, 2011.
  1. Sep 3, 2011 at 12:46 PM
    reywasneb
    reywasneb [OP] Active Member
    ben
    wenham, MA
    tacoma
    all pro skids and rock sliders, toytec ultimate 3" lift with 5100s, goodyear duratracs
    i recently had a lift put on my truck with 5100s front and rear. the front is adjustable and is sitting a tad lower than the rear. i have the two wrenches needed but dont kno which one to use first. do i have to jack the truck up to get the wheel off the ground?
  2. Sep 3, 2011 at 1:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    You have to jack the truck up, take the wheel off, then take the front shock assembly off to adjust the 5100s, since the 5100's adjust ability comes from the seating of the coil perch on the 5100's rings.
    Someone with more mech prowess will hit this up, but thats my .02
  3. Sep 3, 2011 at 1:02 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    dont need a spanner wrench. take everything out then you have your 5100 and coil 2gether. then you have to take spring compressors compress the coil, then take off the top plate bolts. pull out the strut and there is the spring plate. just take needle nose pliers and put the little clip thingy lol at the notch you want it at.
  4. Sep 3, 2011 at 5:13 PM
    reywasneb
    ben
    wenham, MA
    tacoma
    ultimate.................thanx guys
