Adjusting Bilsteins while on the truck?
Discussion in 'Suspension' started by glock24, Sep 2, 2015.
  1. Sep 2, 2015 at 7:58 AM
    glock24
    glock24 [OP] Well-Known Member
    Is there a clever way to move the spring seat up or down, or does the coilover need to come off to do such things?
    I was hoping a spring compressor might hold the spring temporarily, but I have not tried it.
    Thoughts?
  2. Oct 3, 2015 at 2:00 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    Getting a spring compressor onto the coil while it's on the truck will probably be impossible. However, you can supposedly still safely decompress the coil while on the truck this way:
    1) Support the lower control arm with a floor jack, raise the suspension just a little to be sure of this, and remove the bolts securing the LCA to the steering knuckle. (NOT the castle nut.)
    2) Mark the alignment of the LCA bolts with a Sharpie and loosen them. (Don't remove them.) Sway bar may also need to be removed from the end.
    3) Remove the center nut on the strut's rod.
    The spring can't come flying out and kill you because the bottom of the strut isn't going anywhere (still bolted in) and because the top hat isn't going anywhere (3 bolts still left in).
    4) Lower the jack. The spring will decompress and by the time the strut rod comes down through the top hat the spring tension will be gone.
    There are a couple Gen 2 videos online, but in the comments people have said it works on Gen 1 also.
    https://www.youtube.com/watch?v=5E6u7dC7EHg (see also Part 2)
    one more, https://www.youtube.com/watch?v=vkVLBOnAifc
  3. Oct 3, 2015 at 8:31 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    However you decide, the coil has to be de compressed before any kind of adjustment of clip is done...
  4. Oct 9, 2015 at 8:25 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    My only thought is to jack under the LCA to fully compress the spring then wrap 1-2 hundred zip ties around it so it stays compressed. Then jack up the frame somewhere so the shock decompresses all the way and maybe you'll have enough room to adjust the clip. I'm 60% joking.
  5. Oct 9, 2015 at 5:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    If ya have a good jack & some mech. skill you can do struts without the compressor, done this a few times
