adjusting coilovers
Discussion in 'Suspension' started by asdf, Apr 30, 2009.
  1. Apr 30, 2009 at 6:30 PM
    asdf
    asdf [OP] Well-Known Member
    Charleston, SC
    03 PreRunner
    3" in front, stock in back, 285/75/16 BFG KM2,5% tint all around, UWS black low profile, DTRL,line-X, deckplate...
    ive got a friend that has a 98 4runner that has fox racing coilovers on it. he has them set at the setting they originally came with. he asked me to help crank them up so to speak and get allitle more hight from the front. my question is am i going to have to take the whole coil assembly out to do this or can i do it while on the truck? will a coil compressor be needed?
    any help appreciated..
  2. Apr 30, 2009 at 6:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Jack the front of the truck up to get the weight off. Take the wheels and tires off for more room.
  3. May 1, 2009 at 4:49 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2 on what chris said and no coil spring compresser is needed.just the 2 spanner wrenches to loosen them up.after adjusting set it down and drive around the block to let them settle in.measure and measure then adjust if needed.he will need to get an alignment then as well.good luck.
  4. May 1, 2009 at 4:50 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    oops a little late on that one.
