Adjusting Dirlogic Coilovers
Discussion in 'Suspension' started by cbcs1987, Sep 17, 2010.
  1. Sep 17, 2010 at 7:55 AM
    cbcs1987
    cbcs1987 [OP] Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    I'm in the middle of adjusting my coilovers right now, but think I'm doing something wrong.
    I followed directions according to Fabtechs website for adjusting them, but I didnt think it would be this hard to adjust.
    I've loosed the set screw, and cranked a couple times with the spanner wrench. I'm having to put nearly all my weight into it to turn it. Is this normal or is something not right? I was thinking it was supposed to be fairly easy.
  2. Sep 17, 2010 at 7:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Is the front of the truck lifted off the ground?
  3. Sep 17, 2010 at 7:59 AM
    cbcs1987
    Cody
    East Tennessee
    Yes completely.
  4. Sep 17, 2010 at 8:07 AM
    cbcs1987
    Cody
    East Tennessee
    It is even relatively tough with a cheater bar. The threads I have already cranked passed appear to be fine, so I don't think that could be the issue
  5. Sep 17, 2010 at 8:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you spray any lube on the threads?
  6. Sep 17, 2010 at 8:24 AM
    cbcs1987
    Cody
    East Tennessee
    I let them soak in wd40 for about 10 minutes
  7. Sep 17, 2010 at 8:29 AM
    cbcs1987
    Cody
    East Tennessee
    Also, the entire coil is turning. Is that normal>
  8. Sep 17, 2010 at 8:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. You may want to spray some lube on the coil seats.
  9. Sep 17, 2010 at 8:34 AM
    cbcs1987
    Cody
    East Tennessee
    Thanks. I have to take one side entirely off because the shop pre adjusted them and the set screw is in the back. I might just go ahead and take the other side off to adjust it as well.
  10. Sep 17, 2010 at 8:39 AM
    ibengineer
    ibengineer Well-Known Member
    California
    00 Tacoma TRD 4x4
    Dirt Logic 2.5" Coilovers, Camburg UCA's, Icon 3 Leaf add-a-pack, billy 5100's in the rear, Custom front Plate bumper, XRC 8500 lb winch, lots of little mods
    Put some muscle into it! :D
    I adjust mine without it jacked up. I just turn the tire all the way to the left for the Left side ,and all the way to the right for the right side. No lube/grease required.
    I have it down to a system (because the camburg uca's get in the way a bit).
    Get a hole where you can use the spanner....then follow the pull #1, push #2 procedure I show below...the holes should always line up perfectly for the next push or pull.
  11. Sep 17, 2010 at 8:41 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Ya mine were hard as hell to adjust too. It is the hardest coil i have ever had to adjust. I think it is just because the fabtech coils arent the best of quality.
  12. Sep 17, 2010 at 8:51 AM
    cbcs1987
    Cody
    East Tennessee
    I guess ill use both spanner wrenches instead of one lol. I couldnt figure out why he gave me 2
    edit- nvm. Only one will fit on there at a time. I'm using a TEIN spanner. The way its designed only lets you use one at a time.
  13. Sep 17, 2010 at 8:51 AM
    cbcs1987
    Cody
    East Tennessee
    how is your lift at that setting in the pic?
  14. Sep 17, 2010 at 8:52 AM
    Chachie
    Justin
    Nor Cal
    Who me? lol
  15. Sep 17, 2010 at 8:55 AM
    cbcs1987
    Cody
    East Tennessee
    No lol. IBENGINEER. His looks like its cranked WAY down
  16. Sep 17, 2010 at 8:55 AM
    ibengineer
    California
    00 Tacoma TRD 4x4
    i lowered it about 0.5 from what you see there.
    I orig had them set to like 2.75 - but it was providing me with like 4 inches of lift, so i freaked out and reduced it to only lift me ~ 2.75 to 3" overall. I think the coilovers are at around 2.25 now, if you measure thread. ride is great, my rear suspension sucks though.
  17. Sep 17, 2010 at 8:57 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I had to jack mine up to get the UCA out of my way. Another tip: I put in the spanner wrench and then tapped the end with a hammer to get it moving, that helped a lot if it got gummed up or got stuck.
  18. Sep 17, 2010 at 9:05 AM
    Chachie
    Justin
    Nor Cal
    and are you running a db lift or do you just have the coils?
  19. Sep 17, 2010 at 9:12 AM
    cbcs1987
    Cody
    East Tennessee
    Alright yall Im in the process of removing the passenger side shock right now. Truck in the air, lower control arms hanging freely, sway bar removed, castle nut removed that holds the ball joint to the spindle. But I can't get the two to seperate. Any suggestions?
  20. Sep 17, 2010 at 9:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hit the side of the spindle, or the UCA near the ball joint with a hammer.
