adjusting e-brake handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by SCSPerformance, Sep 12, 2011.
  1. Sep 12, 2011 at 9:32 PM
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    how do you adjust the e-brake handle? i drove an '04 taco over the weekend and the e-brake handle on that truck was a lot tighter than my '02. mine seems to pull out further and when i disengage it, it likes to hang(still showing "brake light") until i push it in a couple of time.
  2. Sep 12, 2011 at 9:41 PM
    Catcrazed
    Catcrazed Save a horse ride a Railroader
    Bryan
    NW Oregon
    91 Flatbed 3.4
    91 Toy flatbed,4.88's ARB,285's,3.4 V-6 Swap
    U adjust the rear brakes. There not in proper adjustment causing u to have to pull out far for the shoes to come up against the drum. Take your drums off clean everything with brake cleaner the adjust your star wheel so the shoes go out testing the drum so it just barley slides on by hand. If ur feeling real ambitious take the star wheels out clean and apply a small another of anti seize to threads. It will help them stay in adjustment. As far as the light not sure that mite fix it or there is prob sum adjusting on the switch under the dash.
  3. Sep 12, 2011 at 9:56 PM
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
  4. Sep 12, 2011 at 10:03 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
  5. Sep 12, 2011 at 10:05 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    thanks for the info guys. just what i was looking for.
  6. Sep 13, 2011 at 12:36 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Your E-brake light sensor connection might be lose.
    Crawl under the dash and look at the sensor. I've also heard of the tabs bending on the E-brake handle from slamming them in, so the tab wouldn't hit sensor.
    Sometimes the sensor is faulty. You push in the button and contacts hit..but light doesn't come off.
    You can just unplug the sensor if you don't care about the light.
    If not, replace sensor.
