Adjusting Eibach kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Seanxnj, Apr 20, 2022.
  1. Apr 20, 2022 at 2:38 AM
    Seanxnj
    Seanxnj [OP] New Member
    Gen-2 Tacoma
    Not sure if this is in the right place. This is my first post so I apologize if so. I just installed an eibach pro lift stage 1 on my 2015 trd pro. It was set at the factory notch giving me roughly 2.5” of lift.I then added an N-fab front bumper weighing it down a bit, so I’d like to raise the coils to the next notch. Is it possible to do this while keeping it on the vehicle? Using a spring compressor or another trick? Any help would be appreciated.
  2. Apr 20, 2022 at 7:39 AM
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    I'm not sure how you'd get to the notch ring safely with the shock inside the coil spring. Removing the preload with a spring compressor can be done and I've heard people doing with floor jack even, but there is no way I would put my fingers or hand tools anywhere near a compressed coil unless its in a press. Initial install is a different story, and can be done safely. It's not worth losing a finger or hand over. Call around and find someone with a press, and even take them out yourself to save some bucks, but IMO it's a Darwin award move to try to compress them and work on them while installed. Others may have had better luck.
