Adjusting timing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chief1959, Jan 11, 2017.
  1. Jan 11, 2017 at 9:02 AM
    Chief1959
    Chief1959 [OP] Well-Known Member
    James
    Springfield, Louisiana
    2023 Tacoma SR5
    Is there a way to adjust the timing on my truck? 2007 Base, 2.7. Unless I run 91 or higher octane, the engine pings when you lug the engine; also after you slow down for traffic or a turn, and then hit the accelerator - it pings when I run 87 (Regular). So back to my question, can the timing be adjusted so that it doesn't ping? I assume this is pre-ignition (plugs firing prior to soon). I assume the dealer has a machine to do it. Or, maybe the engine is just old. 265,000 miles on it.
  2. Jan 11, 2017 at 10:33 AM
    tgear.shead
    tgear.shead Well-Known Member
    That's a lot of miles.
    Maybe just don't lug it?
  3. Jan 11, 2017 at 10:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spontaneously combustion prior to spark plug ignition. To lean a fuel mixture is the most likely reason here.
    Have you replaced your fuel filter or pump ever?
    Have you checked your vacuum hoses for cracks and leaks?
  4. Jan 11, 2017 at 1:06 PM
    Chief1959
    James
    2023 Tacoma SR5
    Thanks! I will check those three things.
