Adjustment hole rear drum brakes 2017 Tacoma
Discussion in 'New Members' started by Tacoma Outlaw, Jul 22, 2019.
  1. Jul 22, 2019 at 6:23 PM
    Tacoma Outlaw
    Tacoma Outlaw [OP] Member
    I've been in the automotive business for almost 30 years and have worked on mainly North American vehicles and adjusting rear drum brakes was usually pretty standard but on my 2017 Tacoma when u remove the rear rubber grommets to gain access to the starwheel adjuster the teeth on the adjustment wheel aren't visible.Anyone run into this?
  2. Jul 22, 2019 at 6:24 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    They aren't directly visible. It's kinda off to a side...screwdriver needs to be angled in the hole.
    Taco critter and irayfz6 like this.
  3. Jul 22, 2019 at 6:26 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  4. Jul 22, 2019 at 6:31 PM
    Tacoma Outlaw
    Wow are u serious!I guess they must want to sell Starwheel adjusters because over time thats gonna chew the teeth off sooner than later!Its something so simple to position that adjustment hole in the correct place but thats not the first time i ran into that,...on the early 2000's Pontiac Sunfire's the adjustment hole was incorrectly applied to.Anyway thanks for the info!!!
    Taco critter likes this.
  5. Jul 22, 2019 at 7:35 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  6. Jul 22, 2019 at 8:07 PM
    Tacoma Outlaw
    Thanks lol!
  7. Jul 22, 2019 at 8:11 PM
    Bishop84
    Bishop84 Well-Known Member
    I use a small pry bar with a 45 degree bend, but most drums I simply adjust when the the drum is off. I only adjust through the service hole when the customers drums are ridged.
  8. Jul 22, 2019 at 8:20 PM
    Tacoma Outlaw
    When u say ridged u mean an outside edge left on the drum as result of the shoes wearing the drum?
  9. Jul 22, 2019 at 8:30 PM
    Tacoma Outlaw
    And the prybar with 45 deg bend u mean u use out in front of the drum between the drum and backing plate to pry it off.If so thats good when its new or maybe with bolt holes on the front of the drum u could use a proper 2 bolt puller with bracket to remove the drum but i guess i thought like normal adjustment holes in the rear of the backing plate the teeth on the starwheel adjuster would directly in front of u so u could use ur small prybar/brake adjustment tool to roll the shoes back with ease instead of over time when things start to get a lil seized chewing the teeth off the starwheel by having to roll them in on an angle and if u can do that by prying on the front or using a puller u could wreck the hold down springs.
  10. Jul 23, 2019 at 4:18 PM
    Bishop84
    Yes
    To back off I use a long pick, and ram the star wheel in reverse, it helps that I work on a lot of Toyotas.
  11. Jul 23, 2019 at 4:30 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have got to ask why do you think you need to adjust the brakes on a 2017? My last one was a 97 with 300K never had rear brakes adjusted or replaced. The 2011 has over a hundred K never have had the brake plugs out.
  12. Jul 23, 2019 at 4:34 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Normal per Toyota
  13. Jul 24, 2019 at 1:34 PM
    Tacoma Outlaw
    Thank you to all who gave advice i really appreciate that!!!!!
  14. Jul 25, 2019 at 12:19 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
