ADS coilovers - Life in the Midwest/rust belt
Discussion in 'Suspension' started by geekhouse23, Jan 9, 2018.
  1. Jan 9, 2018 at 5:43 PM
    geekhouse23
    geekhouse23 [OP] The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    First off, yes I know what a search bar is and yes, I used it. Here are some examples of links I found using the search bar:
    https://www.tacomaworld.com/threads/closed-ads-group-buy.475653/
    https://www.tacomaworld.com/threads/nj-b-s-thread.274779/page-2995#post-16465314
    https://www.tacomaworld.com/threads...racing-coilovers.203714/page-65#post-16217904
    https://www.tacomaworld.com/threads/life-with-kings-vs-fox-vs-icon.504463/page-3
    https://www.tacomaworld.com/threads/fox-and-ads-bypass-shocks.502823/#post-15847130
    https://www.tacomaworld.com/threads...ocks-in-northern-states.500182/#post-15566266
    Other threads included people that live in Florida or Arizona; not what I am looking for.
    Here are two posts that stood out to me the most and somewhat answered my question:
    AND
    My question to those that have been running ADS shocks and are above or in the rust belt, how have they held up to winters, salt and the abuse and punishment that we take? Stories, pictures, mishaps and misfortunes with other brand coilovers that perhaps prompted the switch to ADS coilovers are all welcomed!
  2. Jan 10, 2018 at 10:55 PM
    BlackTacosMatter92
    BlackTacosMatter92 Well-Known Member
    Jay
    2017 DCLB Tacoma
    King Suspension SPC UCA's Dakar Medium Leaf Packs Nitto Ridge Grapplers 255/75/16 VTX Vipers 16x8 (-12) Mobtown CMC plates Mobtown Sliders Smittybilt X20 10k Synthetic Factor 55 Fairlead & Flatlink MBRP Off Camber Fabrications Front Bumper MBRP Black PowderCoat Exhaust RX350 Projectors TRD Pro tail lights Truxedo Lo Pro QT Tonneau RCI Bed Rack Total Chaos Bed Stiffeners ARB CKMA12 CustomCarGrills Grille Line-X'd Grille 20% Window Tint (Front/Back) 75% Windshield 5% Visor Debadged
    Email from Headstrong:
    ADS utilizes similar components in their OE lines as they do their race lines so that is a nice benefit. ADS comes standard as a standard travel (they can be built at extended travel) and a reservoir and have optional compression adjustors. The come built with a 650 lb spring rate but can be built with a 700lb spring rate at no extra charge. They have steel body and aluminum components. From the feedback I do have from people who have run a variety of these coilovers most feel like these stood up to road salts better than some of the other brands listed. I cannot personally speak directly to this since I am not located in an area that contends with salt but people seem to like the ADS’s coating better than others. Their OEM bolt in Tacoma coil-overs are digressively valved on the rebound side and run progressive valving on the compression. The main reason for this is to give you the stable ride for on road and less of the harshness when traveling off-road. They come preset to provide around 2.5" of lift on the 05-15's and around 1.5" on the 2016+ models. They can be adjusted to provide more or less lift depending on what suits your needs. Keep in mind, whenever adjusting a coilover you need to make sure that they are not adjusted to a point that will cause coil bind on compression.
    RoaminRoman, SR-71A and Jmad1997 like this.
  3. Jan 11, 2018 at 6:16 AM
    geekhouse23
    Thanks. I already reached out to Marie and got the same information:
    https://www.tacomaworld.com/threads...-overland-build.302427/page-152#post-16858740
    RoaminRoman likes this.
  4. Jan 11, 2018 at 6:21 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  5. Jan 11, 2018 at 6:29 AM
    geekhouse23
    Banned.
    rmepilot and ChadsPride[QUOTED] like this.
  6. Jan 11, 2018 at 6:30 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
  7. Jan 11, 2018 at 6:31 AM
    ChadsPride
    All I can say is...My buddy has a full ADS setup with Resis and the truck rides like a dream.
    The same bumps that cause my truck to sound like the dash is going to explode....his truck literally floats over.
  8. Jan 11, 2018 at 6:34 AM
    geekhouse23
    Thanks for the input Chad.
    ChadsPride[QUOTED] likes this.
  9. Jan 11, 2018 at 6:34 AM
    ChadsPride
    Anytime :thumbsup:
  10. Jan 28, 2018 at 6:20 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Hey, that’s me! Woot!
    Months installed and I’ve forgotten what it is to slow down for bumps and dips :)
  11. Jan 28, 2018 at 6:38 PM
    geekhouse23
    Interesting. I have heard the opposite about Fox shocks.
    @G.T.
    ChadsPride likes this.
  12. Jan 29, 2018 at 3:04 AM
    ChadsPride
    :woot::headbang: :jellydance: :mudding:
    riz_atx[QUOTED] and Synergy001 like this.
  13. Jan 29, 2018 at 3:45 AM
    G.T.
    G.T.
    CONUS
    Depends on the model. Mine are the Factory series which are steel.
    DaveInDenver and ChadsPride like this.
  14. Jan 29, 2018 at 4:52 AM
    geekhouse23
    @jeff b which model do you have? See above reply from GT..
  15. Jan 29, 2018 at 5:19 AM
    geekhouse23
    Damn I wish I had triple bypass monies..
  16. Mar 22, 2018 at 6:46 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    I have ADS and live on the Florida coast where rust is common. No rust issues at all. I’ve had King, Icon, and Fox and they all rusted.
    Wedge, ready6delta, rmepilot and 2 others like this.
  17. Mar 30, 2018 at 8:19 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
  18. May 5, 2018 at 6:59 AM
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    Just ran across this and hope the input helps. I live around St Louis and have had ADS for two winters. They look brand new still. Never used fluidfilm or anything like it. Everyone else does in the group and still has some form of rust issues. I'd have to look back for the exact info but ADS used a specific coating on theirs. The Fox 2.0 have less rust issues vs the Fox 2.5 steel. OEM, Blistein, Icons.... they all have rust problems in my area. ADS so far is holding strong fighting off rust. I have zero complaints about them.
    Slashaar, rdpoe, Wedge and 4 others like this.
  19. May 5, 2018 at 7:13 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    In Alabama and have been running ADS for 19 months. Great ride and no rust.
    ready6delta and geekhouse23[OP] like this.
  20. Aug 28, 2018 at 6:09 AM
    Wedge
    Wedge Well-Known Member
    Yves
    Kebekistan
    17 OR DCSB MGM
    Bestop supertop Bronze Method roost 255/80/17 toyo open country RT Interior LED XenonPro HID low beam
    Im leaning towards ADS as well didnt get them yet, but i will be able to tell you if its Canada winter proof. If it is it'll last anywhere.
    PoweredBySoy and rmepilot like this.
