ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Jun 23, 2015 at 9:17 AM
    #221
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    only 2.5's. they offer a piggyback or remote reservoir. the piggyback is a easier fit.
  2. Jun 23, 2015 at 10:48 AM
    #222
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Okay, what length of travels do they have?
  3. Jun 23, 2015 at 11:22 AM
    #223
    Lakeside, Ca. 92040
    I belive its around a 9" travel shock. its designed for 0-1.5/2" of lift. they can build custom lengths if that's something you needed. you would just need to supply the measurements. extended and collapsed.
  4. Jun 23, 2015 at 11:57 AM
    #224
    ALBtacoma
    ALBtacoma Well-Known Member
    Pete
    Red deer AB, Canada
    07 trail limo trd sport
    I have 10" Travel with the expo leaf pack
  5. Jun 23, 2015 at 12:47 PM
    #225
    Lakeside, Ca. 92040
    ya, they can build to fit any lift for the most part.
  6. Jun 23, 2015 at 1:30 PM
    #226
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    DSM, what is the stroke on the TC +2 specific coilovers?
  7. Jun 23, 2015 at 1:37 PM
    #227
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Pretty sure it's just a 8" short body (threaded cap)
  8. Jun 23, 2015 at 2:09 PM
    #228
    ckeene9
    Chesterfield, VA
    See Build Thread
    Hmmm I was under the impression that ADS built a specific coilover for that kit vs just using a 8" made for the +3.5.
  9. Jun 23, 2015 at 3:37 PM
    #229
    gray223
    SE Missouri
    2014 Tundra Limited
    Does that cost more for them to be custom made?
  10. Jun 23, 2015 at 3:38 PM
    #230
    Lakeside, Ca. 92040
    Per Brian at ADS, he has never installed their LT shock on a +2 kit. But with that being said, every other manufacturer uses the same shock for the +2 as well as the +3 kit, you just don't use all the shocks down travel due to the kit not cycling as much.
    ADS's shock is a 8" shock or 7.5" above the rubber bump, built to the bolt in LT kit specs.
    XPOTRON likes this.
  11. Jun 23, 2015 at 3:53 PM
    #231
    ckeene9
    Chesterfield, VA
    See Build Thread
    Thanks!
  12. Jul 6, 2015 at 6:49 AM
    #232
    freddirt
    freddirt Well-Known Member
    Clint
    Southern Utah
    Usedtahave'21 CMNT GRY DCSB TRD OR 4x4
    Wheels: Helo HE900 17x9 -12 offset. Tires: Toyo open country AT3 265/65. JLT catch can. RSG sliders. Diff breather mod. Wheelers extended rear brake lines. LED interior lights. Front suspension: Accutune King 2.5 ext travel w/ adjusters, Icon tubular uca w/ delta joint, Wheelers super bumps. Rear suspension: Accutune Tundra 2.5 remote resi Kings w/ adjusters, Icon RXT leaf pack, U Bolt flip w/ Wheelers super bumps.
    FINALLY got to try out my new ADS set up off road last night... I couldn't be more stoked! Took a "scenic" drive home after dinner with friends, a fast dirt road with a little bit of everything. Every aspect of the ride is so much better! More controlled on stutter bumps/wash board (wasn't expecting too much, but was blown away with the control), soaked up everything I was willing to throw at them, and also super plush. On road ride is awesome as well... I can now destroy rain gutters and speed bumps with out batting an eye lol.
    I did notice one thing, not really to do with the ADS shocks though. Seems my UCA's contact the inner fender on hard hits. I did some research on here, and discovered the super bumps may be the culprit for this... Caught me by surprise, and I don't want any more hits like that with everything else being stock. I came over a crest into a small G-out at like 50-55, and BAM! It sounded like the tires hit... But I'm running stock tire size. I pulled over to check to make sure I didn't jack anything up. Found that the UCA's hit the inner fender. It doesn't look like the C/O even bottomed out, which is good right? Having the shock's or C/O's as the limiting factor is bad as far as I know... I saw a post about a guy adding some washers to the bumps to aid in the issue, gonna have to give it a try, and take it easy!
    XPOTRON likes this.
  13. Jul 11, 2015 at 8:35 AM
    #233
    TaylorU
    TaylorU [OP] KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Awesome to hear you're enjoying it! Did you weigh your bed down at all to test it out? I've learned that it makes a huge difference for me, likely because I just have an AAL. And yeah, my UCA has smacked the fender a couple times as well and scared me quite a bit the first time haha.
  14. Jul 11, 2015 at 10:08 AM
    #234
    gray223
    SE Missouri
    2014 Tundra Limited
    I think wheelers actually make shims for there super bumps. Guess washers would work too.
  15. Jul 11, 2015 at 8:37 PM
    #235
    freddirt
    Clint
    Southern Utah
    @TaylorU - Yea I tried the sandbag trick... much better! When I went out the other day, I had two people in the back seats and one in the front passenger, so I took the sand bags out to see how it rode off road with people weight. I think I am just gonna leave the sand bags in... people weight is too far fwd, and not over the rear axle. So it was still a bit stiff. But yea, I am super stoked with everything so far!
    @gray223 - Thanks! I will have to look into that for the shims, or I could be a cheap @$$ and just do washers lol.
    TaylorU[OP] likes this.
  16. Jul 12, 2015 at 8:11 PM
    #236
    TaylorU
    Taylor
    Flagstaff, Arizona
    Good to hear!
    On a side note, I was watching The Mint 400 today on NBC. I dont think any of the trick trucks were running ADS, but I saw them in the background a few times with their big booths/tents set up and even shots of spectators reppin ADS apparel. Just thought it was kinda cool.
    Biscuits and XPOTRON like this.
  17. Jul 12, 2015 at 9:17 PM
    #237
    freddirt
    Clint
    Southern Utah
    I want some ADS gear! Guess I better give them a call to find out how to get some.
    XPOTRON likes this.
  18. Jul 13, 2015 at 3:07 AM
    #238
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Just for viewing pleasure :cool: ADS 2.5 Resis with Compression Adjusters on 650lb PAC Racing Springs and Dirt King Heimed Uppers and Uniball Lowers!
  19. Jul 13, 2015 at 3:13 AM
    #239
    freddirt
    Clint
    Southern Utah
  20. Aug 2, 2015 at 7:31 PM
    #240
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Finally got around to lifting my 2014 Tacoma TRD OR. After chatting with @STiLL WILL for months about what setup to go with, he convinced me to go with ADS. He put me in touch with Matt at @M C M and based on my future plans (overlanding type of rig), he suggested the following setup:
    Wheel Spacers (needed since I'm still running on stock wheels/tires at the moment)
    In addition, I had Matt add:
    TC Spindle Gussets
    CMC
    Since I was heading out to Vegas for my cousin's 21st bday and Matt quoted me a great price for install, I drove the truck from the SF Bay Area out to Matt's shop for the install. I dropped the truck off at about 8:30am on Friday, July 24th. Matt was able to schedule the alignment for Saturday morning so he said I would have the truck back by noon Saturday.
    Before:
    I have to say Matt has some awesome customer service. His shop is only a few minutes from the strip so he offered to drop me off and pick me up at the hotel. I wasn't expecting to hear from him until sometime Saturday morning but to my surprise, he sent me some progress pictures throughout the day on Friday.
    Driver Front
    Passenger Front:
    Driver Rear:
    Passenger Rear:
    After:
    I couldn't wait to get the truck back and see how she drives. Matt gave me a call the next morning and picked me up around 11:30am. He drove me back to the shop and I was able to see the taco in all her glory!
    After Vegas, I drove to Tucson, AZ, then to Anaheim, then finally back to the bay. I put on 1200+ miles on the new suspension after the install. I have to say the truck rides amazingly. I love the added height it gives me and the suspension feels solid. It rides smooth over bumps, potholes, and speed bumps and is definitely a huge upgrade over the stock setup. Now I need to hurry up and get my new wheel and tire setup soon.
    Here are some more miscellaneous pics of the suspension
    Thanks again to @STiLL WILL for the help and @M C M for the install. I HIGHLY recommend hitting up Matt if you have any questions or are interested in some ADS products!
    Mtnflyer, Biscuits, JuansTaco and 7 others like this.
