ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Jan 10, 2019 at 8:06 PM
    #2461
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    No noise for me... I cranked my rears down pretty tight to avoid having them turn on me and contact my leafs.
    El Duderino[QUOTED] likes this.
  2. Jan 10, 2019 at 8:15 PM
    #2462
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Are you sure its not the valve stack of the clickers opening and closing over the bumps???
  3. Jan 10, 2019 at 8:35 PM
    #2463
    SpeySquatch
    2016 TRD OR DCSB
    It could be. Does it really squeak like that? Hasn’t done it for a week, now starts?
  4. Jan 10, 2019 at 9:16 PM
    #2464
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I'm not sure the exact sound you're hearing but the valve stack will make a slightly muffled squeak going over bumps which is totally normal. Usually I only notice it going low speed over bumps with the windows down.
  5. Jan 10, 2019 at 9:27 PM
    #2465
    SpeySquatch
    2016 TRD OR DCSB
    Is it something that happens as the shocks break in? Does it get louder or stay the same sound over time?
  6. Jan 10, 2019 at 9:29 PM
    #2466
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    On mine the sound is static - doesn't change with time.
    SpeySquatch[QUOTED] likes this.
  7. Jan 11, 2019 at 8:08 AM
    #2467
    FishTacoJon
    FishTacoJon Well-Known Member
    Jon
    AZ
    2012 Tacoma TRD Sport DCSB
    Was reading through the instructions on the 3-leaf AAL install and was wondering if anyone had issues with the two notes here? Specifically the cutting of the center pin.
    geekhouse23 likes this.
  8. Jan 11, 2019 at 8:19 AM
    #2468
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Nope. I cut the center pin and grind it smooth. No issues. I would recommend leaving some threads (4-5) exposed beyond the nut. Otherwise, feel free to cut.
    FishTacoJon[QUOTED] likes this.
  9. Jan 11, 2019 at 8:32 AM
    #2469
    FishTacoJon
    Jon
    AZ
    Nice! Guess I forgot to specify, but this was for the HeadStrong 3leaf. The threads are already pretty short so maybe I won't need to cut it. We'll see.
    https://www.headstrongoffroad.com/s...eafs_with_u-bolts_(PAIR)_-_HS-TOY055-3AL.html
    geekhouse23[QUOTED] likes this.
  10. Jan 11, 2019 at 8:36 AM
    #2470
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Hey ADS people, I am deciding between ADS level 1 with Dakar’s or BP51s on my 3rd gen. I Didn’t really see much comparing them directly. I can get bps for nearly the same cost and most of what I’m doing is longer mild to medium off roading since I’ll have a kid with me most of the time. Any input would be great but I can’t quite spend the extra for level 3 and the clickers unfortunately... thanks!
  11. Jan 11, 2019 at 9:03 AM
    #2471
    SpeySquatch
    2016 TRD OR DCSB
    The BPs are 51mm shock whereas ADS is larger (61mm I believe).
    Not really comparing apples to apples since EMUs are traditionally overland shocks and ADS are race shocks.
    Depends on your use, but after owning EMUs I’m not a big fan due to how stiff there regular stuff can be (not BPs).
    Honestly the best top shocks in my opinion are ADS, King, or Bilstein 8112 (if you haven’t seen these yet check em out). Emu isn’t in this class or level of shock
    ffemt2987[QUOTED] likes this.
  12. Jan 11, 2019 at 9:08 AM
    #2472
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    Did you end up going on that 5000 mile road trip? If you did how did suspension perform? Curious to hear how these performed on Rocky Mountain trails.
  13. Jan 11, 2019 at 10:03 AM
    #2473
    ffemt2987
    Austin
    Golden
    Thanks man, I appreciate the input. I realize they are bigger but I just wonder when the size becomes more important than the adjustability.
  14. Jan 11, 2019 at 10:05 AM
    #2474
    SpeySquatch
    2016 TRD OR DCSB
    ADS is adjustable if you get the clicker rests (buy from Headstrong)
  15. Jan 11, 2019 at 10:11 AM
    #2475
    ffemt2987
    Austin
    Golden
    Right, but you have to get the highest level stuff and add them right? I would do that but it’s significantly more money then...
  16. Jan 11, 2019 at 10:21 AM
    #2476
    SpeySquatch
    2016 TRD OR DCSB
    you should hit up Marie at Headstrong to see if she has the inventory sale going, there is a pretty good price cut. I just purchased the external rests with the clickers for valving adjustment. You can also adjust lift height on any of their shocks.
    Which set are you looking at from ADS exactly?
  17. Jan 11, 2019 at 10:36 AM
    #2477
    ffemt2987
    Austin
    Golden
    I’ll give her a shout.
    I want solid suspension for the life of my truck that will work well running around the forest service roads in colorado and support the weight of camping gear etc. My last setup was Icon /Dakar’s and thought it was OK but not great. I definitely like the “buy once cry once” saying but I also don’t NEED the top end stuff since I most likely won’t be mobbing through the trails.
    But with that said my stockish set up is garbage...
  18. Jan 11, 2019 at 10:41 AM
    #2478
    SpeySquatch
    2016 TRD OR DCSB
    I would run ADS or those Bilstein 8112's if you want a buy once, cry once. The biggest problem with aftermarket coilovers is the service on them (pain in the ass to remove, put old shocks on, wait for service, and put back on).
    Having said that, the rumor is ADS and the Bilstein 8112's are supposedly lasting longer on average between typical services intervals (abuse and wear dependent of course).
    ADS has an amazing corrosion resistance on their shocks which may be better if they salt the roads in CO. The shocks can take just about anything (7" rocks at 35mph) so I'm sure, based on your needs you would be impressed.
  19. Jan 11, 2019 at 10:53 AM
    #2479
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    As someone that has pulled their shocks several times to have them rebuilt, it's only a pain in the ass if you are passing someone else to do it. I just swapped them out the other day in 2 hours and most of that way drinking beer and BSing with friends. All shocks are going to wear at a similar rate based on usage, ADS or 8112s aren't going to last longer magically than Kings or Icons, just likely that more street queens are running them.
    TMFF and SpeySquatch[QUOTED] like this.
  20. Jan 11, 2019 at 10:56 AM
    #2480
    SpeySquatch
    2016 TRD OR DCSB
    Are you servicing them yourself? Do you have a vehicle lift?
