ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Mar 31, 2019 at 11:48 AM
    #2821
    scleaf
    scleaf Well-Known Member
    Torrance, California. USA
    2013 Silver Tacoma TRD 4x4
    SaBellCo's Tailgate Lock :), Cable mod
    No regrets here on ADS, love them the only thing I have not figured out is the TC UCA, I get a slight tick when I back up, it is driving me batty, I have torqued and re-torqued and it is starting to become a PITA, might change to different UCA. Suggestions????
    El Duderino likes this.
  2. Mar 31, 2019 at 11:49 AM
    #2822
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Jba all they way
  3. Mar 31, 2019 at 11:57 AM
    #2823
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Are you sure it's the UCA? Sway bar isn't contacting the coil? Torqued the uniball?
  4. Mar 31, 2019 at 12:10 PM
    #2824
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    I’m in the market for some front coils. ADS is an option. Why ADS over King? Do the ADS hold up to corrosion well? Any problems having the ADS adjusted to 3” with 700lb spring? Ive got bamf sliders, rci skids, just ordered a front bumper and winch, so the weight is getting up there. I’ve got total chaos uppers and 5100’s on 887’s right now and the time has come to switch out the 5100’s.
  5. Mar 31, 2019 at 12:16 PM
    #2825
    scleaf
    will take a look. thanks
  6. Mar 31, 2019 at 12:17 PM
    #2826
    scleaf
    2.5" is what is advertised.
    Pella[QUOTED] likes this.
  7. Mar 31, 2019 at 12:18 PM
    #2827
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    You'll definitely want 700# coils. Not sure about the max lift, but I believe 3" is doable.
    As for corrosion resistance, from my research, ADS has the best reputation. All coilovers will corrode in the salt states, but ADS is know for having some of the best coatings and resistance .
  8. Mar 31, 2019 at 12:18 PM
    #2828
    desertrunner24
    Jake
    Fresno , CA
    Some
    ADS is more gooder than blings(kings)
  9. Mar 31, 2019 at 12:23 PM
    #2829
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    What is the cost to rebuild both fronts? Thanks for the quick responses.
    2.5 would work for me if it were a true 2.5 after weight and settling. Clearing 285’s the important part.
    This is good to hear.
    But why is that?
  10. Mar 31, 2019 at 12:27 PM
    #2830
    SpeySquatch
    2016 TRD OR DCSB
    I have almost the same setup with 700# coils. With 1” of preload I get 2” of lift which is ideal. They drive awesome and have a better corrosion coating than King. Component-wise I think they are as good if not better than King. King is a big brand with blue shocks everyone knows
    El Duderino and Pella[QUOTED] like this.
  11. Mar 31, 2019 at 12:27 PM
    #2831
    SpeySquatch
    2016 TRD OR DCSB
    o_O
    “Gooder”?
  12. Mar 31, 2019 at 12:28 PM
    #2832
    desertrunner24
    Jake
    Fresno , CA
    Some
    Because they just are thats why. J/k. I had a set of kings on a 99 tacoma and they were fine. They are acctually still on that truck and its been through the baja 1000 a few times. But i wanted something that all the "bros" didnt have so i found these and am glad i did. They ride like a cloud. And the customer service from ADS is outstanding
  13. Mar 31, 2019 at 12:31 PM
    #2833
    SpeySquatch
    2016 TRD OR DCSB
    Is your truck that’s gone through the Baka 1000 a trophy truck? They don’t just let any truck go through that race...
  14. Mar 31, 2019 at 12:31 PM
    #2834
    desertrunner24
    Jake
    Fresno , CA
    Some
    Gooder is better than more better :crazy:
    SpeySquatch[QUOTED] likes this.
  15. Mar 31, 2019 at 12:33 PM
    #2835
    desertrunner24
    Jake
    Fresno , CA
    Some
    No it was a 99 tacoma built for it with a TC kit and a full cage inspected by score.We werent even close to competing but it was a great experience
    Pella likes this.
  16. Mar 31, 2019 at 12:38 PM
    #2836
    SpeySquatch
    2016 TRD OR DCSB
    Fuggin sweet dude. I had friends do that race as well
  17. Mar 31, 2019 at 12:42 PM
    #2837
    desertrunner24
    Jake
    Fresno , CA
    Some
    Was definitely a lot of work to get ready for. But was a blast doing. This was back in 05 and 06. We were still kids but made it. We never have finished the whole 1000 miles. The furthest we did go was about 400 till something would brake and take us out of competition. I definitely want to try to do it again someday. But life has gotten in the way for now.
  18. Mar 31, 2019 at 12:44 PM
    #2838
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  19. Apr 1, 2019 at 10:03 AM
    #2839
    Theetrentmeister
    Theetrentmeister Well-Known Member
    I am here in colorado and corrosion resistance is one of the reasons i purchased ADS and i haven't any issues with them this winter and we have had a lot of snow so they have put down a lot of that spray on salt and that stuff is harsh. Not 100" sure on adjusting to 3". I have the 700lb springs and when I installed my 200lb front bumper, my winch, and weld on sliders it didn't drop my front end at all if it did it was maybe 1/8th an inch or something like that. I love my ADS so far and can't wait until spring melts the snow in the mountains so i can get back to wheeling.
    Pella[QUOTED] and SpeySquatch like this.
  20. Apr 1, 2019 at 10:12 AM
    #2840
    SpeySquatch
    2016 TRD OR DCSB
    Not sure this is really a good comparison because they are 2.0’s and Fox vs Kong’s are not in the same category. Fox seems to be in a lower tier than King’s Overall quality. A pro shop I visited said they have way more issues with Fox than other brands unless you go with their higher end race line stuff
