ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Apr 1, 2019 at 10:15 AM
    #2841
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    It does relate to what material characteristics to look for; the treatment and hardness of the shock shaft, Viton vs Buna N in the seal materials, and the seal construction, regardless of make. As for Fox vs King, the article would indicate Fox 2.0" shock uses better materials than 2.0" Kings. Not sure if the materials.change for King or Fox in the 2.5" size, or what materials are used in ADS, but does give you an idea of what to look for in comparison.
  2. Apr 1, 2019 at 10:26 AM
    #2842
    SpeySquatch
    2016 TRD OR DCSB
    It was interesting to see the tensile strength is higher in that of Fox vs Kings in the piston rods.
    I'm curious how ADS stacks up against these figs
    desertrunner24 and Pella like this.
  3. Apr 1, 2019 at 10:37 AM
    #2843
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    For my own application, temperature extremes and resistance to airborne gravel damage rank high on the list of things to consider. Just rebuilt my 2.0" diameter emulsion rear shocks, Walker Evan's brand, and interesting to see the seals and their material choices - used Viton on shaft Oring for sure, and I believe the cupped seal with wiping portion, though the 2nd primary wiping seal appears to be buna material. The shraeder valve used Viton with double Orings.
    SpeySquatch likes this.
  4. Apr 1, 2019 at 10:39 AM
    #2844
    SpeySquatch
    2016 TRD OR DCSB
    Makes me wonder if I should put the rubber boots back on over the shafts, but many say that that can cause more problems. I don't live in the rust belt though
  5. Apr 1, 2019 at 10:41 AM
    #2845
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  6. Apr 4, 2019 at 11:14 AM
    #2846
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Dirk Diggler, Tretiak30 and VE7OSR like this.
  7. Apr 5, 2019 at 9:45 AM
    #2847
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    I’m interested in ADS but not quite ready to purchase.
    As far as the difference between adjustable and non adjustable. What are most of you guys doing? I feel like for what I would end up encountering I don’t need the extra adjustability, but if I’m spending 3500, what’s another 600?
  8. Apr 5, 2019 at 10:17 AM
    #2848
    SpeySquatch
    2016 TRD OR DCSB
    I bought adjustable, glad I did because I use it all the time depending on terrain and load.
    How are you spending $3500? Are you getting a complete leaf pack and UCAs as well?
  9. Apr 5, 2019 at 10:26 AM
    #2849
    Superhulk LB
    Josh
    Oregon
    Thanks,
    Yes, from what I’ve been told I should do a full rear leaf pack and UCAs. I think that’s still debatable but trying to plan for everything. Comes in at $4100 with the adjusters at headstrong.
  10. Apr 5, 2019 at 10:27 AM
    #2850
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I'd shop around, that's seems pretty high
    desertrunner24 likes this.
  11. Apr 5, 2019 at 10:28 AM
    #2851
    SpeySquatch
    2016 TRD OR DCSB
    Message Marie at Headstrong and see if she has any discounts/deals going with any inventory leftover from last year. I got my rears for a lot cheaper that way
    El Duderino likes this.
  12. Apr 5, 2019 at 10:39 AM
    #2852
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    These won't help clear tires any more than stock. Your up travel is still the same. Unless you never cycle your suspension, then it will help.
  13. Apr 5, 2019 at 11:00 AM
    #2853
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I got the adjustors front and rear and am glad I did. The difference between each click is very noticeable. Even if you don't plan on adjusting them all the time, the adjustors allow you to dial in the ride to be perfect for your truck so you're not just stuck with the valving that ADS gives you.
  14. Apr 5, 2019 at 11:51 AM
    #2854
    Superhulk LB
    Josh
    Oregon
    When I get ready to buy I’ll see what is available. Maybe wait for a group buy or Black Friday sale. I’ve talked to Marie a few times and she has been super helpful.
    SpeySquatch[QUOTED] likes this.
  15. Apr 6, 2019 at 8:26 PM
    #2855
    SpeySquatch
    2016 TRD OR DCSB
    For anybody wondering. I measured my rear shocks today at full droop with my Dakar medium leaf pack and I had 10” of shock shaft showing from the cylinder to where the shock mount collar starts. Pretty darn impressive
    DoulosXP and desertrunner24 like this.
  16. Apr 7, 2019 at 3:26 PM
    #2856
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    This is what my shocks look like after one winter. I lubed them down twice this winter with fluid film. We use salt but it doesn’t snow that often here. Here are some pictures after I hot water pressure washed them today.
    Front:
    Rear:
    I heard these hold up to salt better than other brands. I would say that my ADS haven’t held up well. The aluminum bodies of all the shocks are oxidized. All of the hardware is rusted and both rear lower shock mounts are rusted.
    kakwvu, ready6delta and Pella like this.
  17. Apr 7, 2019 at 3:28 PM
    #2857
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    :eek: That looks bad
  18. Apr 7, 2019 at 3:29 PM
    #2858
    jowybyo
    Joe
    Baltimore, MD
    Yup. I think so for only one winter in a relatively mild state. I can’t image how they’d look after a Michigan or New England winter.
  19. Apr 7, 2019 at 3:29 PM
    #2859
    desertrunner24
    Jake
    Fresno , CA
    Some
    What did you coat them with?
  20. Apr 7, 2019 at 3:30 PM
    #2860
    jowybyo
    Joe
    Baltimore, MD
    Fluid film.
