ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Apr 7, 2019 at 3:32 PM
    #2861
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Yeah missed that. I keep mine sprayed down with wd-40 and have had them for 3 winters and they still look new. But i do live in cali but they have seen their fare share of snow and water no salt though.
    Pella likes this.
  2. Apr 7, 2019 at 3:34 PM
    #2862
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    That looks bad for any manufacturer. Pretty uncharacteristic for ADS coilovers. If it were me, I'd probably just rebuild them and have the bodies and rod ends nickel plated.
  3. Apr 7, 2019 at 3:35 PM
    #2863
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Screw that. That’s way more work then I have time for.
    Dirk Diggler likes this.
  4. Apr 7, 2019 at 3:41 PM
    #2864
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Well are you going to just trash them when they need a rebuild? I don't know if you wheel, but you can double down on the time by getting it done when you have them rebuilt. One of the nice things about having rebuildable shocks. Not quite sure on how much it costs but I would hope it'd be cheaper than buying all new coilovers and smoothies.
  5. Apr 7, 2019 at 3:48 PM
    #2865
    jowybyo
    Joe
    Baltimore, MD
    Oh yea. When they need rebuilding I’ll consider coating them. But I’m not taking them apart just so they don’t look terrible.
  6. Apr 7, 2019 at 3:49 PM
    #2866
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Aside from the obvious being posted, how do you like ADS ?
  7. Apr 7, 2019 at 4:12 PM
    #2867
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Shit, that looks terrible! I’m currently planning on buying ADS due to all I’ve heard about how well they hold up!
    Anyone else have similar experiences? Or, alternative recommendations?
  8. Apr 7, 2019 at 4:29 PM
    #2868
    jowybyo
    Joe
    Baltimore, MD
    I like them. The ride quality is top notch.
    ready6delta likes this.
  9. Apr 7, 2019 at 4:31 PM
    #2869
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Yeah typically I've seen them hold up pretty good. I bought mine used after 30k from someone back east, and they have wear and tear yes, but they don't look like @jowybyo 's. I honestly wonder if ADS had a bad batch or maybe the company they use to source or coat the aluminum bodies had a bad batch? Unclear.
    Yeah, I wouldn't take them apart now. A coating would probably hold up a lot better to the elements too. In the mean time, if you have access to a spring compressor you could buff them a bit and use a stronger oil to prevent greater damage.
  10. Apr 7, 2019 at 4:39 PM
    #2870
    SpeySquatch
    2016 TRD OR DCSB
    Is your front hoses rubbing the coil? I see some wear marks...
  11. Apr 7, 2019 at 5:19 PM
    #2871
    jowybyo
    Joe
    Baltimore, MD
    It was for a little bit. I’ve since adjusted the hose.
    SpeySquatch[QUOTED] likes this.
  12. Apr 8, 2019 at 8:32 AM
    #2872
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Odd how just the ads shock components are corroded, but not the truck parts around it, even where there is wear. Was the same spray applicator ever used with anything else in it previously?
  13. Apr 8, 2019 at 8:36 AM
    #2873
    jowybyo
    Joe
    Baltimore, MD
    Yes. I put Fluid Film on my truck before every winter. The entire underside of the truck, inside the frame and all the suspension components get a treatment.
  14. Apr 9, 2019 at 9:09 PM
    #2874
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    The bodies are steel, not Aluminum. They are zinc plated with clear cerakote. I have seen the cerakote react with some of the road salt differently, also, any type of purple cleaner can make the clear coat do weird stuff.
  15. Apr 9, 2019 at 9:11 PM
    #2875
    M C M
    Matthew
    Sin City, Nevada
    Some ADS porn from an install today.
    2.5" With Clickers
    MCM Fab UCAs
    Deaver U402 Stage 2
    MCM Fab Spec ADS Bypasses
  16. Apr 9, 2019 at 9:28 PM
    #2876
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    I just ordered my ADS fronts today.
  17. Apr 10, 2019 at 2:53 AM
    #2877
    jowybyo
    Joe
    Baltimore, MD
    Ah that makes sense. I haven’t used any cleaner on them.
  18. Apr 10, 2019 at 11:10 AM
    #2878
    mightiestmouse
    mightiestmouse Well-Known Member
    Mine look roughly the same, especially the rear shocks. Omaha just went through one of the worst winters, but I still would consider the salt mild compared to the northeast. A bit disappointing that it took one winter for them to look like this, but I plan on hopefully finding a solution for protection when it is time for a rebuild.
    As a side note, I love the ride from these shocks. I would not go another route, I just wish the finish on these would have last a bit longer.
  19. Apr 10, 2019 at 12:27 PM
    #2879
    Theetrentmeister
    Theetrentmeister Well-Known Member
    I would consider that as a defect or something because I am here in Colorado and we had a bunch of snow and we use that terrible liquid salt. Mine look nothing like that after this winter. They look almost the same as day one.
  20. Apr 10, 2019 at 12:29 PM
    #2880
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    It's almost as if the person selling you things made statements that enticed you to buy things
    jowybyo likes this.
