ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Apr 10, 2019 at 12:44 PM
    #2881
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Wonder if fluid film degrades or dissolves the coating?
    Dogg23 likes this.
  2. Apr 10, 2019 at 12:49 PM
    #2882
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Mine came out of the box with a little corrosion on the shock body...not too bad, but still there! I'll try and snap a picture later.
  3. Apr 10, 2019 at 12:53 PM
    #2883
    TRD493
    Dave
    Texas (DFW)
    So nice! Might be picking up a 2004......ADS again!?
  4. Apr 10, 2019 at 1:36 PM
    #2884
    SpeySquatch
    2016 TRD OR DCSB
    No, she compared all shocks and I could have bought Kings, Fox, or any other. I was actually on the fence with the Bilstein 8112's. Im not sucker for marketing
    El Duderino and Pella like this.
  5. Apr 12, 2019 at 7:43 AM
    #2885
    Wedge
    Wedge Well-Known Member
    Yves
    Kebekistan
    17 OR DCSB MGM
    Bestop supertop Bronze Method roost 255/80/17 toyo open country RT Interior LED XenonPro HID low beam
    This is really discouraging me from getting them im in northern Qc Canada and >I dont think they would last up here maybe with a coating plus a neoprene cover like icon, I know somme people do it here and it seems to work, but after just one winter they are like that ??? Maybe fluid film has somehting to do with it its crazy !
  6. Apr 13, 2019 at 1:53 PM
    #2886
    SpeySquatch
    2016 TRD OR DCSB
    Anyone know where to find rear shock shields vs boots for the 2.5 shocks? I only see 2.0 fox shields
  7. Apr 15, 2019 at 10:19 PM
    #2887
    Wu tang
    Wu tang Well-Known Member
    Reno
    So with the hose rubbing on the coils, how did you guys adjust it away? How much can you loosen the nut?
  8. Apr 16, 2019 at 5:06 AM
    #2888
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    You can loosen it just enough to turn the hose away from the coil. I think it was somewhere close to tight but was still able to turn
    Wu tang[QUOTED] likes this.
  9. Apr 16, 2019 at 10:06 AM
    #2889
    TRD493
    Dave
    Texas (DFW)
    It doesn't take much.
  10. Apr 16, 2019 at 10:56 AM
    #2890
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Quarter-turn, if that. I didn't lose a drop of fluid.
    Wu tang likes this.
  11. Apr 16, 2019 at 11:16 AM
    #2891
    Wu tang
    Reno
    That’s good to know.
  12. Apr 16, 2019 at 8:09 PM
    #2892
    Theetrentmeister
    Theetrentmeister Well-Known Member
    Easy to adjust but be careful and have something on the fitting that you can quickly tighten just in case you end up doing what I did and spray yourself in the face with oil. It was all going fine until i started to turn the hose and it must've loosened it just barely enough to give my beard a nice spray of oil and the taste wasn't too good either, it also didn't help that in the panic of trying to get it tightened again that I twisted the fitting the wrong way before realizing what I was doing. Called ADS to ask if it would be any issues or anything and they said it was no big deal unless I lost a large amount.
  13. Apr 19, 2019 at 4:52 PM
    #2893
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    9EE1FC48-8BBC-48DA-8A10-A83649DA9BC0.jpg I just got my front ADS coilovers, with resi's and no adjusters. I’m trying to avoid the kinked hose issue a lot of people have had. What did some of you with 3rd Gens do? Did you remove the sway bar for the reservoir bracket? Seems like a lot of people are saying the hose is too long.
  14. Apr 19, 2019 at 5:09 PM
    #2894
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    From the looks of your hoses and the angle of the fittings at the top, you'll be just fine. The non-clicker resi's are less prone to "kinking" as the hose comes right out the end. The clicker versions, the hose has a 90° fitting that causes the hose to get pointed in a bad direction.
    I have the exact same coilovers... my advice is to install the resi in the mounting bracket (ADS logo facing out) and then move the whole bracket and resi into position. Whether you keep the sway bar or not has zero effect. If you keep it, be sure to use the relocation brackets. I also had to trim a portion of my fender liner, for the resi mount to sit flush against the frame.
    Pella[QUOTED] likes this.
  15. Apr 19, 2019 at 5:10 PM
    #2895
    SpeySquatch
    2016 TRD OR DCSB
    Those look like they r ready to rock...
    Taking the sway bar off will allow you to configure the resis just right. Have the mount on and your clamps loose after you have the coilovers already put in the truck. The hose length is fine as long as you have the brackets slid all the way forward to the front of the truck.
    Observe how the mounts go below. The angled edge goes forward. Make sure the hose doesn’t rub on the coil.
    In this pic I have about 1/4” from the coil
    Also make sure the hose is rotated inward towards the engine as best as possible so your tire doesn’t hit it at full turn
    Bertw192 likes this.
  16. Apr 19, 2019 at 5:15 PM
    #2896
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Ditched the sway bar
  17. Apr 19, 2019 at 5:49 PM
    #2897
    SpeySquatch
    2016 TRD OR DCSB
    How are you liking it driving highway? I tried it for a day, but it seemed dangerous with a child in the truck.
    Have you got some miles on the truck without it so far?
  18. Apr 19, 2019 at 5:54 PM
    #2898
    El Duderino
    Jeremy
    HI->PNW
    Yea been off since I had them installed. Took a week or two getting use to and I can’t really tell the difference honestly. There may be a little more play hitting a bump but nothing crazy. Got about 2-3k without it
  19. Apr 19, 2019 at 7:19 PM
    #2899
    SpeySquatch
    2016 TRD OR DCSB
    More play hitting a bump? Seems like there would be less bump-steer with a full independent suspension. Do you feel like bumps are more or less noticeable?
  20. Apr 19, 2019 at 7:30 PM
    #2900
    El Duderino
    Jeremy
    HI->PNW
    Just a little bit of wheel play that’s what I meant. Bumps aren’t more noticeable.
