ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Sep 6, 2015 at 4:58 AM
    #281
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Literally almost anything the other manufactures make, ADS will have or can build for your specific needs
  2. Sep 6, 2015 at 5:00 AM
    #282
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    My mock ups to use until my 2.5 16" Triples are finished ;) Showcase model 2.5 16" 4 Tube bypass and a smoothbody/unfinished 2.5 16" shock
  3. Sep 6, 2015 at 5:29 AM
    #283
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Sweet thanks
  4. Sep 6, 2015 at 9:33 AM
    #284
    TaylorU
    TaylorU [OP] KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Edited the OP to include contact information and some other stuff.
    Can't wait to check out Stefen's rear end when the surgery is complete:thumbsup::anonymous:
    XPOTRON likes this.
  5. Sep 6, 2015 at 10:45 AM
    #285
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Stefen's getting ass implants?
    XPOTRON and Acerwin like this.
  6. Sep 6, 2015 at 10:48 AM
    #286
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    How are the ads shocks when it comes to southern weather? We have a good bit of salt on the roads during winters (not as bad as others).
  7. Sep 6, 2015 at 11:38 AM
    #287
    TaylorU
    Taylor
    Flagstaff, Arizona
    :fingerscrossed:
  8. Sep 6, 2015 at 1:35 PM
    #288
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    So when adjusting coilover preload do u have to loosen the hex nuts on the spring cap or can you just turn the cap?
  9. Sep 6, 2015 at 2:32 PM
    #289
    TaylorU
    Taylor
    Flagstaff, Arizona
    My guess would be good, but honestly I'm in a climate where we don't need road salt.
    Loosen those hex nuts then turn the cap.
  10. Sep 8, 2015 at 2:52 AM
    #290
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks sometimes I wish I was. When someone knows if it does stand up to southern weather please let me known b/c I would like to give ADS a shot!
    XPOTRON likes this.
  11. Sep 8, 2015 at 3:02 AM
    #291
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Go to the first page of this thread and check out @STiLL WILL build. He lives in Cali close to the ocean and said ADS has held up perfectly
    STiLL WILL and Acerwin[QUOTED] like this.
  12. Sep 8, 2015 at 3:14 AM
    #292
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks! I'll have to check it out.
  13. Sep 13, 2015 at 10:45 PM
    #293
    Jp450
    Jp450 Well-Known Member
    Vegas
    15 TRD OR
    ADS Suspension MCM FAB UCA'S Deaver leafs
    Installed my suspension today. Finished late will post some pics of whole thing tomorrow. Test drive was awesome the ADS and deavers ride great. Matt @mcmfab was awesome and his recommendation on the suspension was spot on. Just waiting on the bumpstops for rear to come in. Added a pic this morning.
  14. Sep 14, 2015 at 2:50 AM
    #294
    Lava rocks
    Lava rocks Well-Known Member
    Hilo,Hi.
    2000 Sr5 xcab 4x4 v6 auto
    Boy I'm gonna have to get some of those ADS for my ride.
  15. Sep 14, 2015 at 6:31 AM
    #295
    Jp450
    Vegas
    15 TRD OR
    Do it!!! You won't regret it.
    rob1208 likes this.
  16. Sep 14, 2015 at 2:27 PM
    #296
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Hi guys. Is it normal for the resi coilovers to make a short hiss sound when going slow over hard speed bumps? The sound doesn't bother me and there is no sign of leaking gas/fluid, just wanna make sure.
    TIA
  17. Sep 14, 2015 at 2:29 PM
    #297
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Hiss or squish?
    Hiss sound is an indication of a leak. Squish sound is normal. Only real way to tell is to hook up a gauge and check/refill nitrogen pressure. Warning...because the nitrogen cavity is so small, even checking the pressure will cause it to drop 10+ psi...so not recommended to do at home unless you have a way to top it off.
  18. Sep 14, 2015 at 3:36 PM
    #298
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    more a squish i guess. I'll post a video if i can capture the sound. it makes sense that the fliud/gas moving through the resi and valve would be audible.
  19. Sep 15, 2015 at 6:51 AM
    #299
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Just teasing with these "mock ups" :cool:
    Then the pair on top are my "Pogo Sticks" to get me by until my triples are done :D
  20. Sep 15, 2015 at 3:20 PM
    #300
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    What are the ADS options for a rear shock?
    I'm guessing:
    -single cylinder
    -single cylinder w/ remote resi
    -double, triple bypass?
    -resi mounted on cylinder?
    Are the resi styles adjustable?
