ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Jul 24, 2019 at 6:44 PM
    #3221
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Thanks man super pumped!
  2. Jul 24, 2019 at 7:21 PM
    #3222
    SpeySquatch
    2016 TRD OR DCSB
    Must’ve
    I’d double check they gave you the right brackets
    ready6delta[QUOTED] likes this.
  3. Jul 24, 2019 at 7:47 PM
    #3223
    ready6delta
    JACOB
    I just wrote them to see.
    SpeySquatch[QUOTED] likes this.
  4. Jul 24, 2019 at 9:38 PM
    #3224
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Don’t keep us in suspense...
  5. Jul 25, 2019 at 4:57 AM
    #3225
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Pun intended?
    Well, I made the choice to send them back to ADS to be retrofit. They are going to out in a 700lb spring as well as a preemptive fix for bumper/winch addition.
    Hawk373[QUOTED] likes this.
  6. Jul 25, 2019 at 4:57 AM
    #3226
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    That’s the same bracket I got with mine
  7. Jul 25, 2019 at 8:33 AM
    #3227
    SpeySquatch
    2016 TRD OR DCSB
    Weird. Mine are different, smaller.
  8. Jul 25, 2019 at 1:20 PM
    #3228
    ready6delta
    JACOB
    Weird they must have just updated. Do you have pics of how yours is mounted?
  9. Jul 25, 2019 at 1:25 PM
    #3229
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    rob1208 and ready6delta[QUOTED] like this.
  10. Jul 25, 2019 at 1:36 PM
    #3230
    ready6delta
    JACOB
    Awesome man thanks. that is how I thought they attached. Too easy I appreciate the quick pic. Looks good as well.
    rdpoe[QUOTED] likes this.
  11. Jul 25, 2019 at 1:47 PM
    #3231
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Wonder if the new mount takes care of the hose fitting that attaches to the resivior. People were saying they had to loosen it and rotate to make it not rub. Anyone with the new mount can you comment on this ?
    ready6delta, not_nick and TACOVRD like this.
  12. Jul 25, 2019 at 2:14 PM
    #3232
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    I did not make adjustments to the hose with mine. Not sure if there is a difference between adjusters and no adjusters.
    One thing to note with the bracket, if you are removing the sway bar you still need to install the relocation block the move the resi mount down and forward
  13. Jul 25, 2019 at 2:23 PM
    #3233
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    The bracket should go against the frame, there should be no need to use the relocation bracket if not using the sway bar, if there was some clearance issues please let me know so I can address it.
    The Tacoma shocks were updated to use the same brackets as the 4 runner, so there is a new hose configuration.
  14. Jul 25, 2019 at 2:27 PM
    #3234
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    There was a clearance issue with my install. Bracket would not sit flush and absolutely needed the sway bar relocation bracket. Both sides
  15. Jul 25, 2019 at 2:29 PM
    #3235
    M C M
    Matthew
    Sin City, Nevada
    Message me some pictures if you can so I can get it addressed.
  16. Jul 25, 2019 at 2:31 PM
    #3236
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    I’ll do my best. It’s been a month since I installed and I didn’t taken pictures at the time. I figured it was designed to work with the relocation bracket.
    If I remember correctly, the resi mount was too tall and basically interfered at the top of the wheel well. Didn’t allow the bolts to fully seat in the frame. If I get time tonight I’ll go monkey around with it and take a few pics
    Before we make too much of it I’m curious how it goes for @ready6delta when he installs
    ready6delta likes this.
  17. Jul 25, 2019 at 2:33 PM
    #3237
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I checked out a set yesterday and they have the same brackets as those in the picture. I also ordered mine(should be here tuesday) with 700lb coils
    What is everyone doing for initial setup?
    ready6delta and JKU3000 like this.
  18. Jul 25, 2019 at 3:05 PM
    #3238
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Glad to see the changes! A mid-travel setup seems to be as far as one can go while keeping a true bolt-on, minimal maintenance, and minimal problem IFS setup. Seems ADS realizes this and is making their product work as such so props to them and whomever is relaying info or reading through here!:hattip:
    RoaminRoman and ready6delta like this.
  19. Jul 25, 2019 at 3:59 PM
    #3239
    SpeySquatch
    2016 TRD OR DCSB
    What do you mean by initial setup?
  20. Jul 25, 2019 at 4:12 PM
    #3240
    SpeySquatch
    2016 TRD OR DCSB
