ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Nov 9, 2019 at 9:45 AM
    #3561
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    It's a CV axle, they either suck because you don't know what your doing or they are super easy because you do.
  2. Nov 9, 2019 at 9:49 AM
    #3562
    Nachoandsarha
    Nachoandsarha Member
    Justin
    2011 white Tacoma SR5
    Exactly what hoarder23 said!
    It went smoothly for me, may not for others!
    SpeySquatch[QUOTED] likes this.
  3. Nov 10, 2019 at 12:58 PM
    #3563
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Another question. My LCA bolt will not fit through the lower bushings on the ADS shock. Anyone else have this issue? Not sure what I should do..
  4. Nov 10, 2019 at 1:10 PM
    #3564
    hoarder23
    Shay
    NJ
    Scratches
    Does it fit when the shock is not on the truck?
  5. Nov 10, 2019 at 1:13 PM
    #3565
    Gruber1922
    Tacoma, WA
    2015 Tacoma Sport
    Nope bushings are too small all together
  6. Nov 10, 2019 at 1:20 PM
    #3566
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    What’s the valving like on these out of the box? Or is special valving/tuning available from ADS?
    I’m trying to decide between ADS front coilovers from Headstrong versus Kings from Accutune.
    Accutune says with 650lb coils and their valving they can have my truck riding like a caddy on the road and top notch off road performance. Not sure if ADS would offer the same or better though?
    in the rear I am planning on a 63 swap with 14” Bilstein 5165 shocks. (5160’s with a standard top eyelet).
    truck has 150lb front bumper, winch, steel skid trio, sliders, and eventually a dual battery setup.
  7. Nov 10, 2019 at 1:21 PM
    #3567
    hoarder23
    Shay
    NJ
    Scratches
    Then you likely got a set of bushings for a 4runner or 1st gen. Call the vendor you got them from to get a replacement, or if you need to install them today find a local vendor that would have them in stock.
  8. Nov 10, 2019 at 1:22 PM
    #3568
    Gruber1922
    Tacoma, WA
    2015 Tacoma Sport
    Weird okay. I sent Headstrong Off-road an email as they are closed today. I’ll have to remove them and put my old suspension back on
  9. Nov 10, 2019 at 1:24 PM
    #3569
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I believe the valving is off the shelf from ads via headstrong. You can pay to revalve, or you can order straight from ads or accutune for a valving that matches your setup
  10. Nov 10, 2019 at 1:27 PM
    #3570
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Accutune only sells King and Fox. I’ll wait and see what Marie says about valving on ADS’s that match my setup. I sent her a PM already.
  11. Nov 10, 2019 at 1:56 PM
    #3571
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Accutune is a vendor that sells shocks and “tuning” services so what they throw at your shocks will be as custom as it gets without going out and participating in an actual tuning service.
    Headstrong just does resale, but they are great peeps regardless and will do you right. I second 650# springs either way you choose though. Not that it means much, I’m just a random guy on the inter webs.
    SpeySquatch and Dirk Diggler like this.
  12. Nov 10, 2019 at 1:58 PM
    #3572
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    All Tacoma's run a 14mm lower bolt and same width. 4Runner are the same 14 mm bolt 1996-2015ish when the lower mount got a few MM wider but the older width misalignments still fit just fine.
    I bet @Gruber1922 had normal 1/2" ID misalignments installed at ADS, accidents happen.
  13. Nov 10, 2019 at 2:28 PM
    #3573
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Accutune is no more expensive than other King vendors too, but a lot of people seem to be running ADS, so just curious what all the fuss is about.
    figure if Accutune recommends 650# springs, there must be a method to the madness.
    FWIW my Eibach pro truck springs are 742lbs and they are super smooth.
  14. Nov 10, 2019 at 2:33 PM
    #3574
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Not gonna lie I mix up mcm and accutune all the time. One of the sites has an in depth explanation as to what spring weight is recommended and why. Example the stock spring is rated at 717. Aftermarket vendors reccomend 600 and 650 for 3rg gens that are stock and slightly heavier up front ( skids, bumper, winch, battery ect.) Based off of a combination of spring and valving. Pretty brief but I'll try and find the link.
    https://accutuneoffroad.com/articles/coilover-spring-rates-for-toyota-tacoma-4runner/
    One of the many articles explaining reasonings for proper valving and spring rate for vehicles.
  15. Nov 10, 2019 at 2:59 PM
    #3575
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’ve read all the articles and fully understand. Basically what I’m asking is why should I choose off the shelf ADS over a set of Kings that I can basically get custom tuned, like @desertjunkie760 said above, for the same price?
    I haven’t found anyone who tunes ADS to the extend that Accutune or even Thuren does for Kings, yet everyone raves that ADS are so damn good with factory/shelf tuning.
    I think I know the answer to my question but was hoping someone in this thread with technical knowledge can chime in.
    desertjunkie760 likes this.
  16. Nov 10, 2019 at 3:39 PM
    #3576
    SpeySquatch
    2016 TRD OR DCSB
    I’m running a 700lb coil with a similar setup 135lb bumper/winch, sliders, bed box and mat with softopper). If you get adjustable resis then you can softer or firm it up at will. The valving is progressive compression and digressive rebound out of the box
  17. Nov 10, 2019 at 4:31 PM
    #3577
    desertjunkie760
    Shane
    Check My Sig.
    No it’s not.
  18. Nov 10, 2019 at 4:35 PM
    #3578
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  19. Nov 10, 2019 at 4:36 PM
    #3579
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    my front bumper alone is 150lbs and the winch is 60ish I think.
    ordering direct from ADS seems to be the only way to get any custom valving it seems like.
  20. Nov 10, 2019 at 4:57 PM
    #3580
    SpeySquatch
    2016 TRD OR DCSB
    Probably, but with the weight you are running sounds fine for 700lb coils and stock valving
