ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Nov 13, 2019 at 6:08 AM
    #3601
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    That makes sense. The passenger side is very tight and doesn’t move
  2. Nov 13, 2019 at 8:00 AM
    #3602
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Butt Dyno. Hehe
  3. Nov 13, 2019 at 10:07 AM
    #3603
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I stand corrected.
  4. Nov 15, 2019 at 8:52 AM
    #3604
    Mtnflyer
    Mtnflyer I'm big in Japan
    Las Vegas
    I've been on ADS for 3 years now, 80% street driving, and they have held up really well. they have about 60k miles on them now and I'm finally bringing them in to be rebuilt, only because my truck got totaled and now I have a reason to take them off :). If you want a daily driver setup that has excellent quality and will perform off-road when you need it, I definitely recommend these. My off-roading experience has been a mix of pre-running, jeep trails and rock crawling and I've had no issues driving to work on them after. The ride quality will really be determined more by the spring weight you get up front and the leaf pack in the rear, coupled with whatever weight you have on the truck.
  5. Nov 15, 2019 at 9:16 AM
    #3605
    SpeySquatch
    2016 TRD OR DCSB
    Pretty much same situation here. Agree with everything you said. If one gets the chance I recommend to hit some open desert roads and open the throttle up, experience how well these “float”.
  6. Nov 15, 2019 at 10:11 AM
    #3606
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Throttle up + Turning them clickers up = Got Dang Goodness Man!! Try it out if you havent
  7. Nov 15, 2019 at 12:59 PM
    #3607
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    Hey guys, looking at getting some ADS on all 4 corners through Headstrongs group buy. Currently looking at their extended travel setup with remote resi's and clickers front and rear. Debating 650lb or 700lb springs.
    My truck is a 2013 supercharged DCSB 4x4. I have an all pro aluminum front bumper with Smitty X2O winch with syn line. I have full steel 3/16 skids and steel sliders. In the rear i have a steel HC bumper with no swingout. This is my DD of 70+ miles a day with an almost weekly off-road/camping trip. Off-road trips can consist of slow rock crawling to high speed bashing down washed out gravel roads. I occasionally tow a 5000# landscaping trailer as well. I currently have OME nitro's on all 4 corners with 885's up front and an AAL in the rear. I currently experience the front end dipping horribly under braking on the street as well as immense squatting in the rear(and im sure axle wrap) under hard acceleration.
    A couple questions:
    1) With the extended travel, do I need extended brake lines front/rear or both?
    2) Will there be any issue running these with OEM LCA and SPC UCA's?
    3) Im planning on running an OME Dakar leaf pack in the rear with timbren bump stops. Will I need to worry about bottoming out the shaft internally with this setup on the rear?
    4) Stock bump stops up front, will i need to worry about bottoming out the shaft internally with extended shocks, or should i get front bump stops?
    5) What am i looking at realistically for rebuild? I've only had my truck 10 months and have already put 20k miles on it. I'm not looking to rebuild these every year. I've seen ranges from 30k-60k.
    I am still somewhat debating King vs ADS but i believe i have been pretty convinced to go with ADS due to overall quality/performance/finish durability. I was told by Marie at Headstrong that the ext travel ADS are actually extended travel vs Kings extended travel being a spacer internally removed hence some of my questions above. I knew this beforehand about the Kings, and just kind of assumed that the ADS was similar, but then was presented with the new above info, is this correct?
    What do you guys think about the proposed setup with all the above factors? Any tips or info you guys may have on my questions are greatly appreciated! I have read through some of this thread and learned alot, however have not had time to go through the nearly 200 pages so please forgive me for that.
  8. Nov 15, 2019 at 2:48 PM
    #3608
    SpeySquatch
    2016 TRD OR DCSB
    With your setup being a 2nd gen and your aluminum bumper. 650lb coils
    Front brake lines should be fine. Extended rears if your leafs permit that much downtravel
    HappyGilmore[QUOTED] likes this.
  9. Nov 15, 2019 at 3:23 PM
    #3609
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Additionally, get front bumpstops. The stock bumps aren't doing anything for you.
    I've been extremely happy with DuroBumps, I dont even feel them
    HappyGilmore likes this.
  10. Nov 15, 2019 at 3:27 PM
    #3610
    SpeySquatch
    2016 TRD OR DCSB
    Agree with this. Have front and rears. They are great and cheaper than most
  11. Nov 15, 2019 at 3:27 PM
    #3611
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    Baller, yeah, I have front and rear DuroBumps. They are sublime!
    SpeySquatch[QUOTED] likes this.
  12. Nov 15, 2019 at 3:48 PM
    #3612
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    If you don't feel them how are you happy? I mean if there’s a benefit you would feel it, no?
    SpeySquatch likes this.
  13. Nov 15, 2019 at 3:55 PM
    #3613
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    The benefit is not feeling the LCA impact a hockey puck that barely compresses (stock front bump).
    Having good quality rubber absorb and slow the impact has been noticable.
    In this case, the benefit is not feeling it. It's part of the system, gradual and controlled instead of jarring
    Silver02Taco and SpeySquatch like this.
  14. Nov 15, 2019 at 4:29 PM
    #3614
    HappyGilmore
    Huntsville, AL
    Yes
    Do you think 650 is still okay if i am trying to achieve 2.5-3" of lift? I do not want to have to pre-load the springs too much.
    Im with you in regard to the ride, however are the front bumps required to keep the shock from internally bottoming out on itself?
    ill look into them!
  15. Nov 15, 2019 at 4:30 PM
    #3615
    desertjunkie760
    Shane
    Check My Sig.
    I must not wheel hard enough. :thumbsup:
    hoarder23 likes this.
  16. Nov 15, 2019 at 4:41 PM
    #3616
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I'd go 700 since you're aluminum front + winch. If it were just the bumper, 650 would be plenty, but as they settle I think you'll be happier with 700lb.
  17. Nov 15, 2019 at 5:01 PM
    #3617
    SpeySquatch
    2016 TRD OR DCSB
    Yes, with extended length. 650# should be cherry. However, 2” max is the sweet spot for a functional lift IMO
  18. Nov 15, 2019 at 5:02 PM
    #3618
    desertjunkie760
    Shane
    Check My Sig.
    :duel:
  19. Nov 15, 2019 at 5:05 PM
    #3619
    SpeySquatch
    2016 TRD OR DCSB
    2nd gen. 650#
    3rd gen 700# without question
    But @Supra4x4 may have a point since he actually owns a 2nd gen. I went from 1st gen to 3rd gen
  20. Nov 15, 2019 at 5:12 PM
    #3620
    desertjunkie760
    Shane
    Check My Sig.
    Leave me out of this. I say 14”x 600s FTW! :stirthepot::burp:
