ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Nov 15, 2019 at 5:17 PM
    #3621
    SpeySquatch
    2016 TRD OR DCSB
    With a bumper and winch? Really?
  2. Nov 15, 2019 at 5:18 PM
    #3622
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    little preload is not a bad thing either, helps them wheels stick to the road :thumbsup:
    TBH, my 700s are worn out a bit, I have them preloaded 2" and it does handle quite well. But @Gilmorec61 said he didn't want much preload.
  3. Nov 15, 2019 at 5:27 PM
    #3623
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    No, I was just confusing @Gilmorec61 even more.
  4. Nov 15, 2019 at 5:29 PM
    #3624
    SpeySquatch
    2016 TRD OR DCSB
  5. Nov 15, 2019 at 7:05 PM
    #3625
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Matthew,
    Sent an email few days ago requesting information on rear bump stops. Just wondering if you've received it.
    Thanks
  6. Nov 17, 2019 at 5:28 AM
    #3626
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    bump can anyone comment on the extended travel portion?
  7. Nov 17, 2019 at 6:45 AM
    #3627
    SpeySquatch
    2016 TRD OR DCSB
    I have ext on all 4’s and only have longer brake lines in the rear...the amount of travel will depend on your leaf pack. Running a Dakar would put the stock brake lines too tight at full droop IMO
    HappyGilmore[QUOTED] likes this.
  8. Nov 17, 2019 at 6:54 AM
    #3628
    HappyGilmore
    Huntsville, AL
    Yes
    Gotcha! What’s your setup bump stop wise front and rear to keep the ext shocks from internally bottoming out?
  9. Nov 17, 2019 at 7:05 AM
    #3629
    desertjunkie760
    Shane
    Check My Sig.
    You will not need extended brake line for the front. Even with extended travel, the suspension droops does not limit out the OE brake lines.
    I agree with @SpeySquatch (that’s twice this week :cheers:) you will need get them for the rear. The rear travel will still be limited by the shock regardless of leaf pack but you will gain a couple inches of down travel that will exceed the limit of the rear lines.
    SpeySquatch likes this.
  10. Nov 17, 2019 at 7:13 AM
    #3630
    desertjunkie760
    Shane
    Check My Sig.
    Also, to touch of rebuild intervals.
    This is based purely off your use. If you’re doing 99% street miles with the ocasional fire road you’ll be able to push the 50k limit (yes, people have exceeded that number but I’ve worked on enough shocks to not recommend it. It’s just not worth it.)
    If you hit the dirt more often, or you driving style is rather aggressive when you do hit the dirt, then that interval will drop. Being in SoCal, most guys around here hit the desert or similar style of driving which really works a shock. I personally recommend 30k service intervals for most people. It will make sure you maintain the best performance of the shock while also protecting them from damage of parts failure.
    Superhulk LB and JKU3000 like this.
  11. Nov 17, 2019 at 7:39 AM
    #3631
    SpeySquatch
    2016 TRD OR DCSB
    rdpoe likes this.
  12. Nov 17, 2019 at 7:44 AM
    #3632
    SpeySquatch
    2016 TRD OR DCSB
    :cheers:
    I let mine full droop in the rear with stock lines and it was scary tight to the point I only let it for a few seconds before reducing the droop. Added +4” lines and it looked much happier. That being said, the extended length of the rear shocks showed 10.2” of shock shaft. Just for anyone wondering
  13. Nov 17, 2019 at 9:43 AM
    #3633
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    JKU3000 likes this.
  14. Nov 18, 2019 at 11:10 PM
    #3634
    tacochep
    tacochep Well-Known Member
    Phoenix AZ
    2019 S White Taco DCSB TRD 4x4
    scs ray 10's, demello sliders, meso stuff
    still debating 650 coil or 700, as of right now I have sliders,skids. but my future plans are to add a bedrack/rooftop tent/hybrid bumber/winch, any input on this?
  15. Nov 19, 2019 at 6:44 AM
    #3635
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I’m currently running 700lb coils on my 3rd gen with skids, sliders, second battery, bed rack, and RTT. Does completely fine and isn’t too stiff at all.
  16. Nov 21, 2019 at 5:33 AM
    #3636
    Kings
    Kings Well-Known Member
    Cole
    Ontario, Canada
    2018 Tacoma TRD OR MGM
    17x8.5 SCS Ray 10s, 265/70/17 BFGoodrich KO2s, 2.5" ADS Ext. Travel coil-overs and shocks with compression adjusters, ICON tubular Delta Joint UCAs, Extended brake lines front and rear, OME medium duty Dakar leaf pack, Locked Offroad hydraulic rear bump stops
    So I went 650lb springs, just because I'm lighter when I'm going to work etc. Hybrid bumper, sliders, skid plates and rear bumper.
    It rides really well for me, obviously I'm not taking off the armor but I DD my rig and and I'm still on a ground tent so I can remove a lot of weight. 700lbs would be the choice if you're going to be loaded up all the time with dual battery, RTT, bed rack, full armor. Just my 2¢
  17. Nov 21, 2019 at 11:49 AM
    #3637
    SpeySquatch
    2016 TRD OR DCSB
    Let us know if you see sag after a year. When I asked ADS they recommended 700#. Will be interested to hear back
  18. Nov 21, 2019 at 12:38 PM
    #3638
    tacochep
    Phoenix AZ
    Yeah I went with 700lbs just because I'm gonna be fully loaded for a good portion of the year when I have everything going. Thanks for all the input
  19. Nov 23, 2019 at 7:38 PM
    #3639
    The Boat Oar
    The Boat Oar Well-Known Member
    2014 Blacked Out TRD Off-Road
    I am trying to install the rear shocks extended travel.
    1. How do I compress them?
    2. Where does the tophat go? Does it go below the upper shock mount or above. Which way does the curve face? What goes on top of the shock mount? The OEM pad that was up there?
    Thank you, please help!
  20. Dec 3, 2019 at 7:07 PM
    #3640
    cynicalrider
    cynicalrider #NFG
    Jersey
    Any first gens running 35’s and mcm mounts with tc coil bucket gussets?
