ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Jan 4, 2016 at 5:17 PM
    #421
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    This looks much better then my design. I've decided I'm going to cut mine apart this summer and redo it.
    alphabravo[QUOTED] likes this.
  2. Jan 4, 2016 at 5:19 PM
    #422
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Did you make those shock mounts or are those the Total Chaos ones?
  3. Jan 4, 2016 at 6:04 PM
    #423
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    That is just the TC kit.
  4. Jan 4, 2016 at 6:06 PM
    #424
    PcBuilder14
    Brent
    Nor Cal
    Ah, gotcha!
    What leafs are you running and what length shocks are those?
  5. Jan 4, 2016 at 6:17 PM
    #425
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I will post the shock design sheet once I get everything fitted up but they are 10" shocks.
    The leafs are from Deaver and are pretty similar to their expedition pack I think. I got the Toytec adjustable shackles because I wasn't sure how much lift I would get from the springs. As it turned out I got a lot so I added a hole to the shackles to drop them down closer to stock length.
  6. Jan 4, 2016 at 6:20 PM
    #426
    PcBuilder14
    Brent
    Nor Cal
    Nice! You have pretty much the exact setup I want to throw in the back of mine some day.
    How much lift did you end up getting before you added the extra hole in the shackle?
  7. Jan 4, 2016 at 6:23 PM
    #427
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I'm pretty sure the springs are giving me about 3.5" with the bed off. The shackles are 1" longer than stock so add 1/2" at the axle for a total of 4" of lift. Once the bed is on I can measure to the wheel well and compare to my old height. I'm hoping it comes in at around 3".
  8. Jan 4, 2016 at 6:25 PM
    #428
    PcBuilder14
    Brent
    Nor Cal
    Cool, thanks for the info!
    I wasn't sure whether or not to keep my All Pro expos leafs are get the Deavers. I like my 4"+ of lift in the rear.
  9. Jan 6, 2016 at 5:23 AM
    #429
    SigGuy
    SigGuy Well-Known Member
    Sean
    Wilmington, Delaware
    2015 DC SR5
    ADS Coilovers & Camburg UCAs @ Front, Wheelers 5-leaf HD & 5100s @ Rear, Satoshi Grill, Pelfrybilt Rear Bumper, BAK Roll X, WeatherTech Floor Liners and Vent Visors, Wet Okole Covers, @mrmarv/Kenwood/HAT/Arc Audio system
    Here's a question, If I'm running the Wheelers HD pack, do I need extended length rear shocks? If so, how much extra length do I need to tell the dealer to have ADS add? Threads on the Wheelers Pack state that people are getting around 1.5-2.5" of lift from them.
  10. Jan 6, 2016 at 7:52 AM
    #430
    Jp450
    Jp450 Well-Known Member
    Vegas
    15 TRD OR
    ADS Suspension MCM FAB UCA'S Deaver leafs
    It might be in this thread some pages back but I think Matt @MCMFAB said he uses the 10 inch ones that were developed to use with the Deaver expo pack. If you don't find it just contact Matt @mcmfab he will help you out.
    SigGuy[QUOTED] likes this.
  11. Jan 6, 2016 at 7:53 AM
    #431
    SigGuy
    Sean
    2015 DC SR5
    Thanks for the reply, I'll go back through the thread.
  12. Jan 8, 2016 at 1:34 PM
    #432
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I don't think that ADS makes rear shocks for the OEM mounts. It might be best to work through MCM to get something custom made.
    Edit: @SigGuy I just noticed that you are second gen. Prolly disregard what I said about OEM mounts.
  13. Jan 8, 2016 at 2:02 PM
    #433
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    MCM has a dedicated ADS rear piggyback that fits in the oem mounts. Wont work with stock leafs though.
    Pretty sure he has oem travel as well.
    I just called him the other day to place my order. ADS on all 4 corners
    M C M, TaylorU[OP] and rob1208 like this.
  14. Jan 8, 2016 at 2:06 PM
    #434
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Where can I find more info on the ADS weld in front bump stop kit for the 2nd gen tacoma? I went on the ADS website and it had a small pic and a description, but nothing about pricing and install.
  15. Jan 8, 2016 at 2:09 PM
    #435
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Call them. And its a weld-in, gonna be custom mounting however you want..
  16. Jan 8, 2016 at 2:24 PM
    #436
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Definitely give Matt (@M C M) a call and he'll set you up.
    ChadsPride and Jp450 like this.
  17. Jan 9, 2016 at 1:14 PM
    #437
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Give me a call and I can get you set up with the brackets if you want. I've done it on quite a few Tacomas and have all the files saved. Will just require some minor grinding and trimming.
  18. Jan 9, 2016 at 2:13 PM
    #438
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    The rear shocks, IIRC , say up to 2 or 2.5in lift. What happens with a 3in leaf pack, like Allpro?
  19. Jan 10, 2016 at 1:30 PM
    #439
    M C M
    Matthew
    Sin City, Nevada
    I offer a version that works with the taller packs from deaver/all pro.
    ready6delta and REDdawn6[QUOTED] like this.
  20. Jan 10, 2016 at 8:09 PM
    #440
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Here are some shots of the rear shocks that Brian built for me. The fitup is looking pretty sweet so far.
    ChadsPride, AaronArf, Jp450 and 2 others like this.
