ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Jan 15, 2021 at 6:59 AM
    #4381
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    I ended up with sway bar interference in two spots:
    1) the relocation blocks pushed the sway bar into the driver side radiator support
    2) the lower sway bar link bolt was gouging the spring on the driver and passenger sides. Just some things to look for. Easy fixes. I ended up taking the sway bar completely out, but I have 700# springs (post #4491). Your truck looks very good!
  2. Jan 15, 2021 at 7:04 AM
    #4382
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    the sway bar was still hitting the spring even with the relocation plates they provided? It is a nice kit, love it, rides good well now, I did end up messing up a sway bar bolt, because when I installed it, I did one side at a time, and I did not disco the sway bar from both sides like I should have, lessons learned. So when I installed one side it was giving me major issues, ended up getting the passenger side in no problem, but the driver side I had to finiagle it a bit, one thing working against me as well is my bumper framle support mounts, the grade 8 bolt head protrudes past the frame which hits the reservoir mount. but next week I will be picking up my new CBI bumper, so this will be removed and wont be used for the new bumper.
  3. Jan 15, 2021 at 7:06 AM
    #4383
    vorkuta775
    Texas
    tesla truck
    As you can see the head of the bolt. Works for now. But next week it's coming odd. Alightment will be getting done today and I will be hitting shooting steel again this weekend . It's a bit of a trek in the truck well see if I have any rubbing issues etc
  4. Jan 15, 2021 at 7:13 AM
    #4384
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    The lower end link bolt was hitting the spring (the tip of the bolt), not the sway bar itself. It can be shortened with a grinder.
  5. Jan 15, 2021 at 7:15 AM
    #4385
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    You gotta take the flat washers out. I think I used the supplied bolts.
  6. Jan 15, 2021 at 7:17 AM
    #4386
    vorkuta775
    Texas
    tesla truck
    Oh I did, I just test fit it and bolted it on, I put the bracket up first, then then everything else, its on secure, it came with the supplied bolts to attach the bracket to the relocation bracket. That was the only pain in the ass part of the install. Hopefully it will not rub and I wont have any issues but well see this weekend when I go out and tinker in the mountains.
  7. Jan 15, 2021 at 7:28 AM
    #4387
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    I'm taking mine out this weekend too. Have you adjusted the ride height at all yet?
  8. Jan 15, 2021 at 7:29 AM
    #4388
    vorkuta775
    Texas
    tesla truck
    no, left it as is, I dont think they sent me the spanner wrench to do that
  9. Jan 15, 2021 at 7:39 AM
    #4389
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    yeah they don't include that. I bought some cheap HF pin punches that have a variety of sizes, one of which fits the little holes in the adjustment ring well. I heard spraying them with wd40 helps lube them up.
    JKU3000 and Dirk Diggler like this.
  10. Jan 15, 2021 at 10:57 AM
    #4390
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Dude, hell yeah! I got my setup figured out right after we chatted that day!
  11. Jan 15, 2021 at 5:07 PM
    #4391
    vorkuta775
    Texas
    tesla truck
    Bad ass man! Well got an alignment. Max caster both sides. But it seems the front has settled and is sagging like my 5100. I found some spanner wrenches on the ads website. I guess I should have bought some or adjusted according before. Didn't think it was that much of a difference
  12. Jan 15, 2021 at 5:12 PM
    #4392
    SpeySquatch
    2016 TRD OR DCSB
    what coils? 13” or 14” ext?
    650lb or 700lb
  13. Jan 15, 2021 at 5:18 PM
    #4393
    vorkuta775
    Texas
    tesla truck
    600lb, Its enough for my needs. I am switching to a CBI front bumper , eventually a winch in time. I can always swap the coils then.
  14. Jan 15, 2021 at 5:32 PM
    #4394
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    I would recommend the 700 pounders if you switch. I have them and glad I did. Your bumper looks heavy af
  15. Jan 15, 2021 at 5:33 PM
    #4395
    vorkuta775
    Texas
    tesla truck
    It's
    Only 80lbw over stock
  16. Jan 15, 2021 at 5:41 PM
    #4396
    SpeySquatch
    2016 TRD OR DCSB
    what do you mean by “your needs?”
    The stock coils on the 3rd gen OR are 700lb because the nose/engine combo of the truck weighs more than the 2nd gen by almost 300lbs. Probably why you are experiencing sagging. I have a lo-pro bumper and sagged 1-2” after a year with 700# 14” coils.
  17. Jan 15, 2021 at 5:47 PM
    #4397
    vorkuta775
    Texas
    tesla truck
    really. 700lbs eh , I do not want to have a 700lb coil when I do not have alot of front end weight. I also dont want it to ride like shit.
  18. Jan 15, 2021 at 5:50 PM
    #4398
    SpeySquatch
    2016 TRD OR DCSB
    your bumper is huge! 600# is way too light for these trucks stock
    this is what I’m running at 130lbs with winch, but since I run 14” extended coils I will be switching to 650lb coils on my next rebuild to test. It takes about 1000-2000 miles to break in coils depending on driving style so they will all seem different until broken in. My truck drives like a caddy now even with the 700# ers
  19. Jan 15, 2021 at 5:54 PM
    #4399
    vorkuta775
    Texas
    tesla truck
    LOL dude trust me, its looks big, but it does not weigh shit. now my new CBO bumper, that will be a bit heavier .
    https://www.metaltech4x4.com/metal-tech-2016-tacoma-blackbird-front-bumper-stage-1/
    switching from that to DIS
    https://cbioffroadfab.com/product/toyota-tacoma-3rd-gen-adventure-series-front-bumper-2016-2020-2/
  20. Jan 15, 2021 at 5:58 PM
    #4400
    SpeySquatch
    2016 TRD OR DCSB
    ok, but even with a winch (+/- 50-60lbs) you will be pushing 175-200lbs with that bumper.
    my bumper weighs 75lbs without the winch:
    https://c4fabrication.com/collectio...tacoma-front-lo-pro-winch-bumper-3rd-gen-2016
    just trying to help bro. You will want those 700#’ers for the long term.
    Also, valving makes for a rough ride, not so much coils unless you have drastic ranges. You don’t want the front of the truck going up and down like the bow of a boat on water. A little more stiffness will make it handle better too.
    you have ADS shocks so valving won’t be an issue, but balancing the correct coil for handling and correct braking will be important
