ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Mar 3, 2021 at 6:58 AM
    #4641
    Burqueboy505
    Burqueboy505 Well-Known Member
    Albuquerque, NM
    2019 Cement OR DCSB
    Marlin should remind you via email. You need to put the Jesus CD in and bless them as well. If you don't, you're probably going to hell when you die.
  2. Mar 3, 2021 at 9:40 AM
    #4642
    rayofsi
    rayofsi Well-Known Member
    has anyone needed to do a rebuild on their shocks yet?
    i have a tad under 30k miles and my shop tells me i need a rebuild. i'm a mall crawler..
  3. Mar 3, 2021 at 9:43 AM
    #4643
    rayofsi
    full story. i have a 4runner, installed jdfab lower control arm pivots
    total chaos expedition series lcas
    icon heimed ucas
    king secondary shocks
    now the car feels a bit skiddish. shop attributes it to my front having so much more shock and my rear shocks needing a rebuild.
  4. Mar 3, 2021 at 9:49 AM
    #4644
    SpeySquatch
    2016 TRD OR DCSB
    dont the rears usually last longer before a rebuild than the fronts?
  5. Mar 3, 2021 at 12:58 PM
    #4645
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Here’s the truck after adjustments and a much needed wash! this is at about 2.25” lift with 285/70/17 tires.
  6. Mar 3, 2021 at 1:45 PM
    #4646
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I do mine whenever I grease the driveshaft. If you go through dirt and mud, greasing after can't hurt since that's when the most debris will get in there. Usually every 6-8k miles for me.
    Emptei[QUOTED] likes this.
  7. Mar 3, 2021 at 7:45 PM
    #4647
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    According to this page 22.25 extended and 17.75 compressed: https://www.tacomaworld.com/threads...tures-bs-thread.341630/page-191#post-22545998
    Add 1/2" for extended travel
    Curious to hear your results. I have a similar setup and the same observations as you. I pretty much accept it now. The worst is when I’m off-roading it tops out a lot when the wheel rapidly unload, especially when going up a steep slope and the front end is mostly unloaded. And my passenger side is worse than my driver side. I’m convinced I’m not harming it I just wish it weren’t so jarring. The ride quality is phenomenal and the handling in high speed desert terrain with the adjusters all the way in makes me giddy thinking about it.
    ETA: Missing link and correcting for extend travel
  8. Mar 4, 2021 at 6:09 AM
    #4648
    SpeySquatch
    2016 TRD OR DCSB
    arent the new setups (after 2018) supposed to have internal top out springs in them to reduce this?
  9. Mar 4, 2021 at 6:52 AM
    #4649
    Redbeardfifty
    Redbeardfifty Well-Known Member
    Ugh. I reached out to ADS to see if there was an update on my shocks....
    they said the company they use as a plater doesn’t have plating material and that’s why the shocks have been sitting since forever ago.
    Ugh. You’d think dealers would be on them to find a new plater... smh. How can you go a fiscal quarter with no shock delivery.
  10. Mar 4, 2021 at 7:36 AM
    #4650
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    Pretty sharp!
    Traction[QUOTED] likes this.
  11. Mar 4, 2021 at 7:39 AM
    #4651
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Does anyone know if ADS makes a 12 inch for a 12 inch rear conversion for the taco and what they may be valued at?
  12. Mar 4, 2021 at 7:45 AM
    #4652
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    I haven't done anything to these yet to address the issue. Honestly, I'm not sure if it's top-out or just the heavy ass tire slamming down on the ground. But yeah, same scenario as you when this happens. I may lessen the preload when I get around to it. When I installed them, I left the rings where they were from ADS and did not experience this. It was after I added a little preload and installed heavy load range D tires. When I get around to making more adjustments, I'll report back. I'll may need another alignment if I do so.
  13. Mar 4, 2021 at 8:04 AM
    #4653
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Keep in mind that it’s not just ADS having issues with lead times on shocks. I’m at 8 weeks since I ordered custom shocks from them and just received a shipping label notification. Hopefully they ship this week which is much better than the 8 month lead times I’m hearing about with King and Fox.
    the.sight.picture likes this.
  14. Mar 4, 2021 at 8:30 AM
    #4654
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    As far as I know mine do. They have the 45 degree fitting on the reservoir which I have heard indicates they have the top out spring. I put mine on in fall 2019. My billy 5100’s used to top out as well. So I dunno, maybe it’s just me :D
    I’ve always had some additional preload on mine. Right now I’m around 22.25 hub to fender so not a huge amount.
  15. Mar 4, 2021 at 8:31 AM
    #4655
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    I’ve only had these on with E load tires, two different sizes: 32” and 34”. Haven’t noticed a difference at all different tire pressures.
  16. Mar 4, 2021 at 9:15 AM
    #4656
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Have them Cerakote'd, last longer and looks better!
    I use Impeccable coatings in Yuma. He's got a 48 hour turn around.
    https://www.instagram.com/impeccablecoatings/
    Redbeardfifty[QUOTED] and TVH475 like this.
  17. Mar 4, 2021 at 1:37 PM
    #4657
    Burqueboy505
    Albuquerque, NM
    2019 Cement OR DCSB
    I spoke with Tyler (mullet guy) last week or maybe week before and he said they stopped including the internal bump-stop-top-out thingys a while ago
  18. Mar 4, 2021 at 2:13 PM
    #4658
    SpeySquatch
    2016 TRD OR DCSB
    well that sucks. Why the F would they do that? It’s pretty much standard technology in good coilovers isn’t it?
  19. Mar 4, 2021 at 3:57 PM
    #4659
    SpeySquatch
    2016 TRD OR DCSB
    So basically it isn’t needed if you aren’t having the issue when you rebuild?
  20. Mar 4, 2021 at 6:44 PM
    #4660
    Emptei
    Emptei Member
    Murrieta
    2021 TRD OR 4x4 Cement
    Got my alignment done today. Drives amazing. Also got my BMC as well.
